Old 10-04-2013, 10:29 PM   #2371
Brady_21x's Avatar
Trader Rating: 28 (100%+)
Christian, check your PM's sent you a question about a few orders/backordered parts!
Brady_21x is offline   Reply With Quote
Old 10-04-2013, 10:55 PM   #2372
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Just got my RX4 kit and WOW. The graphite on this chassis looks fantastic. Well cut too. Looking forward to running it soon.
AWD
Old 10-08-2013, 01:23 PM   #2373
elee32's Avatar
Trader Rating: 18 (100%+)
Building the rx4 and was wondering, what is a good starting combination for the front and rear inserts.
Eric Lee, sponsored by shipping and handling..
elee32 is offline   Reply With Quote
Old 10-08-2013, 01:29 PM   #2374
rc pete's Avatar
Just wanted to report that the V2 DCJs are working awesome on my TC6.1 WC.
I had struggled with keeping the V1's together... the pins would slip out after a couple of runs even with the "by the instructions" rebuild with shrink wrap and all. Had to keep tightening them regularly.
Two weekends on the V2's now with no problems.
Also, the narrow option is the way to go... direct fit, and the blade doesn't bottom out in the one way.
Thanks Cristian.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 10-08-2013, 02:26 PM   #2375
erchn's Avatar
The RX4 kit should have come with initial recommendations. The sheet that came with mine said front inserts should be single dot outside ff and fr, and 2 dot inside for rf and rr. My measurements show the recommendations sheet being pretty dead on with stock T4 in the front, and more toe in the rear ~.5 degrees.
That said, here's a sheet I made up that represents what I have seen and measured, I've not measured 100% of the positions, but it should extrapolate well. I am running the stock XRAY settings as indicated on the sheet, available here. Note, slight variations in tightening down the blocks can cause a bit of skew, so use these as a reference, YMMV.
Ethan
RCAmerica ; Team Powers USA ; Reflex Racing ; RC≥ RC Crew Chief ; Bezerk RC
erchn is offline   Reply With Quote
Old 10-08-2013, 03:00 PM   #2376
Trader Rating: 27 (100%+)
AWD
Keep us updated, Andrew. I'm really interested in this kit for my T4 but I'd like your input on how it handles on our carpet.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 10-08-2013, 03:04 PM   #2377
elee32's Avatar
Ethan
Cool, thanks Ethan! Got my kit from a buddy who decided not to use it so I didn't get the recommendation sheet
Old 10-09-2013, 10:17 AM   #2378
Trader Rating: 24 (100%+)
Default Rsd springs
Are the rsd orange springs softer or stiffer than XRay 2.7. Thanks
Rob Gleason
sponsors: NemoracingUSA, Agama A215,Agama A215e, Beta tires
triplejracer is offline   Reply With Quote
Old 10-09-2013, 12:14 PM   #2379
elee32's Avatar
Stiffer. There is a spring chart on the rsd website that shows all of the different springs and rates
Old 10-09-2013, 12:33 PM   #2380
erchn's Avatar
Are you asking about the T4 short springs (20mm) or standard length springs?
Old 10-09-2013, 02:05 PM   #2381
T4 thanks
Rob Gleason
Old 10-09-2013, 02:20 PM   #2382
They're quite a bit stiffer. They aren't on the chart, but they're 16.7lb according to the product info.
I find they give prodigious front-end grip, especially under braking. But I struggle with being overly loose in sweeping corners when I use them.
-Mike
Old 10-09-2013, 04:51 PM   #2383
CristianTabush's Avatar
Hey guys, we have some new stuff starting to trickle in over the past week.
I will list the products tonight and over the next couple of days.
We have coming:
-12th scale center springs
-12th scale front springs
-12.5lb Carpet spring (slightly softer than XRAY 2.3)
-16.0lb Asphalt Linear Spring (2.8)
-14.7-15.2 lb Progressive Asphalt spring (between Yellow and Silver)
We have 1 more spring rate coming and we will re-do our asphalt and carpet spring set.
The new 16lb (2.8) spring will be available by itself for now. Perhaps we will include it in the carpet spring set.
Our closed, lowered layshaft bulkheads will be here by the end of the week finally.
On another note, the Orange springs are my spring of choice with the RX4 in the front on carpet. If the car is unstable, it probably means it is under-dampened. Try going up in oil. It is a 16.7lb spring. I will start testing with the 16.0 this week to see if I like them more.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 10-11-2013, 10:20 PM   #2384
Default New Items
RSD112 20mm 16.0lb Spring (light blue)
RSD111 20mm 12.5lb Carpet Linear Spring (White)
RSD110 20mm 14.7-15.5lb Progressive Spring (Gold)
Old 10-11-2013, 10:22 PM   #2385
Default 12th Scale Springs
RSD1205 RSD 12th Scale/F1 Soft Center Spring Set
RSD1206 5.5lb Spring (Yellow)
RSD1207 6.5lb Spring (Green)
RSD1208 7.5lb Spring (Red)
RSD1209 8.5lb Spring (Purple)
RSD1210 RSD 12th Scale Front Medium Spring (similar to CRC .50)
RSD1211 RSD 12th Scale Front Soft Spring
SEO by vBSEO 3.5.0
