Old 07-17-2013, 10:08 AM   #2266
Trader Rating: 57 (100%+)
I am newer to onroad and am wanton to try the rsd chassis and was wanting to know what springs and pistons to run on indoor carpet track? I will be starting in vta class but may move up when I get used to onroad again also running a tc 6.1 worlds car
josh_todd is offline   Reply With Quote
Old 07-17-2013, 04:16 PM   #2267
CristianTabush's Avatar
There are some set ups here:
http://www.reflexracing.net/RSD6-Tech_ep_55.html
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 07-17-2013, 04:18 PM   #2268
I have some V3.1s on the way. I need to start stocking these deeper !
The Hobbywing mod motors are still awaiting approval from ROAR before they go into full distribution according to Falcon Sekido. This is what I was told 2 days ago by my sales rep.
Old 07-24-2013, 02:29 PM   #2269
what are the rates of the old rsd spring set that was offered for the tc6?
going to try my spec r r1 on asphalt for the first time tomorrow, will start with std springs but want to try rsd springs too.. any good idea what springs to try first? low/med asphalt, car is setup almost std, just more flex added to topdeck and chassi
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 07-24-2013, 02:48 PM   #2270
erchn's Avatar
This should answer the question.
http://www.reflexracing.net/RSD-Univ...art_ep_58.html
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 07-24-2013, 03:01 PM   #2271
oooh good stuff!
Old 07-24-2013, 08:34 PM   #2272
The rsd springs are too long to fit well on the R1. At least they are with hpi x-pattern tires at 5mm height.
-Mike
Old 07-27-2013, 10:36 AM   #2273
Robby368's Avatar
Trader Rating: 14 (100%+)
Hey folks, has anyone had an issue with RSD AE TC6.1 Dual Cardan Joint V2narrow axle (RSD070)? The retainer clip on one came off after just two laps on the track. I made sure to separate the longs from the shorts, and crimped them exactly like the website showed. All 4 snapped in tight so I don't see where there could have been an error in installation. Any ideas?
Before you judge someone, walk a mile in their shoes. Then you'll be a mile away and have their shoes.
Robby368 is offline   Reply With Quote
Old 07-27-2013, 10:45 AM   #2274
erchn's Avatar
A couple things. Ensure the clips are installed so the clip spins with the leading edge towards the back of the car. On the TC6, I believe there is very little room in there, and with a little bit of slop the clip can catch and pop off. If I were running a TC6 I wouldn't hesitate to use some heat shrink over the clips.
Old 07-27-2013, 11:01 AM   #2275
chevtech23's Avatar
Been running the v2 DJCs on a 6.1 all summer with no issues, havent had to touch them, two things i think help, shrink wrap over the clips, and clearancing the caster block with a unibit.
chevtech23 is offline   Reply With Quote
Old 07-28-2013, 03:11 PM   #2276
vabroom's Avatar
Cristian, I know that the RSD DCJ V2 couplings are compatible with Xrays escs but what size roll pins does it use? If it's the 2mm which roll pin do I need?
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 07-29-2013, 06:40 PM   #2277
DARKSIDE's Avatar
is this all that's needed to change over my Tc6.1
http://www.reflexracing.net/RSD-20mm...T4_p_1755.html
http://www.reflexracing.net/RSD076-R...it_p_1734.html
ygpm too
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
Southern Indiana RC Raceway
Independance On-Road Bash
July 1,2017
DARKSIDE is offline   Reply With Quote
Old 07-29-2013, 06:52 PM   #2278
mtbboy's Avatar
Hey all
I'm running the rsd inner camber mounts on a tc6.1.
If I am using ae setups on this car what is the height difference between the two?
Thanks.
See y'all in Vegas.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 07-29-2013, 07:14 PM   #2279
Cristian,
If you feel that you can produce XRay T4 ballast weights (particularly for the middle of the car) with interesting features (like multiple screw holes for moving them forward/backward, or as an adjustable battery stop), at a more compelling price point than XRay's own parts, then please do so.
-Mike
Old 07-29-2013, 09:58 PM   #2280
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Sounds like something I might like, Mike.
