Old 05-03-2013, 07:48 AM   #2176
Autocratic's Avatar
Trader Rating: 26 (100%+)
Cristian,
Do you have any springs that are compatible with the new TRF417V5 Premium shocks?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 05-03-2013, 11:05 AM   #2177
snoopyrc's Avatar
Anybody have links to some youtube videos that would help a guy understand setting the roll center and why you would change it?
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 05-03-2013, 04:14 PM   #2178
Bigz84's Avatar
Trader Rating: 17 (100%+)
not sure if this will help you, not youtube, but very helpful...:
post number 1124
Xray T3 2012
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs: Motiv : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 05-03-2013, 04:21 PM   #2179
R Doyel's Avatar
Originally Posted by Jeff Cuffs View Post
Run a 1/2 mm spacer between the out drive and spool. I think they pinch alil bit when tightened. Loosen it up and see if its free.
Thanks for the tip on this, but that didn't work. The axle is still a press fit, even when the outdrive is completely removed.
CT, are you out there?
R Doyel is offline   Reply With Quote
Old 05-03-2013, 06:07 PM   #2180
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Christian is at Paved Nats this week, but will be back to the shop Monday.
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 05-03-2013, 07:26 PM   #2181
R Doyel's Avatar
Old 05-04-2013, 07:19 PM   #2182
elee32's Avatar
Trader Rating: 18 (100%+)
Ran the T4 asphalt springs for the first time today. 17.5TC, green fronts, silver rear, 350 oil all around. Car was dialed! Made my first A-main on pavement. Thanks RSD!!
Eric Lee, sponsored by shipping and handling..
elee32 is offline   Reply With Quote
Old 05-04-2013, 10:58 PM   #2183
Johnny Than's Avatar
Trader Rating: 91 (100%+)
Yep, I highly recommend these springs! They make the car transition through the corners a lot faster than the stock springs. More steering, but still provide good grip throughout! Silver/ Silver works best for me in stock at my track.
Johnny Than is offline   Reply With Quote
Old 05-05-2013, 07:59 PM   #2184
snoopyrc's Avatar
post number 1124
Xray T3 2012
It does help. Thank you. Plus I can print that and pack it in the pit bag.
Old 05-06-2013, 02:53 PM   #2185
gazza's Avatar
What pistons did you use Eric?
Kyle Majikas E-Town posse, Pro One R/C, TQ wire, SpeedMerchant, MC˛ Racing, Hobbywing North America
gazza is offline   Reply With Quote
Old 05-06-2013, 04:04 PM   #2186
elee32's Avatar
4 hole 1.1mm
Old 05-10-2013, 05:02 PM   #2187
B00t13g's Avatar
I was able to run your fan mount as well as your new hard bumper for the t4 today for the first time. Both worked flawlessly as expected and I would recommend both. The new bumpers are even better than the last ones! Great products!
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 05-13-2013, 03:42 PM   #2188
erchn's Avatar
Wow, the new bumper is niiiice....good work Cristian.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 05-14-2013, 04:11 AM   #2189
evochick's Avatar
I don't know if this helps or not, but I had the same problem with older axles, once I put new ones in they fit fine,
I think the older axles get slightly out of round with age. A quick hit with the wet and dry on older axles where they were rubbing and they were also fine.
Just ordered a couple of sets of DCJ's, does anyone know of any other manufacturer's hex wheel clamp and pins fit ??? Cristian was out of stock
Beth.
UnRetired
evochick is offline   Reply With Quote
Old 05-14-2013, 04:53 AM   #2190
CristianTabush's Avatar
Beth, any industry standard M2x10 pins will work as well as hex clamps. So hpi, xray, tamiya, etc will do the job.
We will have more in about 10 days.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
