Old 04-06-2013, 03:31 AM   #2116
frenchchris's Avatar
Thumbs up good stuff
hello ,
thanks Christian for so good stuff.
i set my RSD 6 evo 2 , and last practice cession was a real pleasure even if the track is bumpy and got poor grip.
this sunday will race in hpi french trophy i hope i can bring the car to the top level
here after some pics of the body with reflex sticker.other pics of the roller with modification list will follow
have a nice week end all
chris
Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)-a5-rsd6-3.jpg
Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)-body-rsd-2-.jpg
frenchchris is offline   Reply With Quote
Old 04-06-2013, 04:10 AM   #2117
Wink
Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)-rear-rsd6-evo2.jpg
Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)-rsd-6-ev0-2.jpg
Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)-rsd-6-evo2-general-view.jpg
Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)-rsd-6-evo2-adustable-battery-holder.jpg
Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)-sam_0296_converted.jpg
i use full rsd parts for shock , screw , dial a grip blocks, zeppin c hub 4.5 , integgy aluminium streering block those were designed for the tc5 by work really well on tc6.1.
if some reader got some of these part to sell let me know
using allow prevent the slop onto the plastic stock part , i got the issue running mod
rsd spool end
rsd arm , motor, spur gear screw
zepping rear hub aluminium carrier 2.5 degree + some shim to reach higher value
i ran in hpi serie so need the stock esc and 13.5 k4 motor
ceramic bearing acer or boca
last point : i made using some rsd part and ae parts an adustable battery older this allow to run several battery height without dismanteling and shimming the rsd main older
just need to be firmly screwed when driving mod.
i know i m a lazy guy
Old 04-06-2013, 11:13 AM   #2118
Michael@USPN's Avatar
Originally Posted by frenchchris View Post
hello ,
chris
Attachment 1052782
Attachment 1052783
What body is that? Nice job!
NORCAL HOBBIES | FAST PACE RACING | INSIDE LINE RACING
U.S.P.N. PAINTBALL | DAVIS PAINTBALL | NORCAL P.F.O.A.
TAMIYA EX05V2 | TC6.1 WC (2013 Reedy 17.5 A-main) | AWESOMATIX A700Lx2 17.5 & VTA
R1 Wurks Motors, Batts & Fans! | Tekin RS Gen2 | R1 Wurks Servos | Reflex Racing RSD Upgrades
Michael@USPN is offline   Reply With Quote
Old 04-07-2013, 10:16 PM   #2119
Originally Posted by CristianTabush View Post
Hi Guys, a lot of folks have been asking for a set-up sheet for the new short towers.
This is the new set-up I am using on my car. I feel it is a good starting point for Medium to high grip asphalt as I have tested it on different surfaces.
https://reflexracing.3dcartstores.co...ort_Shocks.pdf
Also, as a little update, we have been doing a bit of testing with the T4 lately and have learned a lot more about chassis flex and how and why it should flex in certain ways. This has led to an all new design of chassis.
The chassis is still being prototyped as we speak, we are not sure if we will produce it, but if there is enough interest, we will. The thing is, this is a very expensive project as it is a chassis that includes 4 bulkheads, New layshaft bulkheads, new vertical stud mounts, new motor mount, new bottom and top deck, shock towers F/R and suspension mounts. It still comes with dual bell crank steering and servo holder.
We are trying to price it out, but as it is a near complete re-design of the TC6 it will probably be 2x the price of the 6.2 EVO. On a coolness factor, we have designed it to be able to be used with XRAY or AE Plastics by just orienting the suspension mounts in an opposite direction.
What would be the interest in an all new re-design? Please voice your opinions here.
Any chance of a different mount system for the arms to the chassis and for adjusting front and rear toe? Something like tamiya and yokomo are using with toe blocks?
ATXPro4 is offline   Reply With Quote
Old 04-07-2013, 10:41 PM   #2120
CristianTabush's Avatar
No. It is not planned like that. It is more like the XRAY.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 04-07-2013, 11:30 PM   #2121
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Good to hear. I much prefer that style of mounting.
Old 04-08-2013, 05:55 AM   #2122
hello
thanks
it is Audi A5 dtm body from XCEED, good neutral stuf, adding some good pressure on the whole roller ,
no really expensive try it you will be convinced
Old 04-08-2013, 07:52 PM   #2123
hanzo3's Avatar
Trader Rating: 55 (100%+)
Reflex has great customer service! Thanks
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 04-08-2013, 09:19 PM   #2124
Default Update
Hi guys, just an FYI, the other spring to complete the T4 carpet spring set should be here before the end of the week.
We also are nearing the completion of our T4 Bladders.
As a question, would you like to see 2 different types of bladders, or just a soft bladder like the 10mm ones?
Old 04-08-2013, 09:39 PM   #2125
B00t13g's Avatar
I'd be happy with a bladder the same as stock, but doesn't swell as quickly.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 04-08-2013, 09:42 PM   #2126
Just soft for me. Makes it easier to bleed dead and creates less pressure inside the shock body, which I would think would reduce the likelihood of blowout/blow-by of the lower o-ring.
Old 04-08-2013, 10:36 PM   #2127
erchn's Avatar
Originally Posted by andrewdoherty View Post
Just soft for me. Makes it easier to bleed dead and creates less pressure insure the shock body, which I would think would reduce the likelihood of blowout/blow-by of the lower o-ring.
+1
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 04-09-2013, 03:46 AM   #2128
RCW
Trader Rating: 17 (100%+)
++1
RCW is offline   Reply With Quote
Old 04-09-2013, 02:14 PM   #2129
jag88's Avatar
Cristian, can you give an update on the TRG112 F1 ? Last I read was that you were building one to test.
Car looks great, just wondering how does it run ?
Thanks.
Edit: sorry, I posted this in the wrong thread.
should of been in the Reflex 112 thread.
jag88 is offline   Reply With Quote
Old 04-09-2013, 05:57 PM   #2130
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Thanks.
I drove a TRG F1 Saturday it was blast I test drove a friends TRG, it's fast handles great it didn't step out once. I'm impressed in the performance of the car! Car had the base setup second time on the track first race it is a real winner.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
