Old 02-25-2013, 12:41 PM   #2026
CristianTabush's Avatar
Ethan, what are you trying to do? The Spec R clips should work on our DCJ's and vice versa. If the large clip on our DCJ is a little loose, you can either Crimp them, which works or you can use the small silver clip on the big side and use black clips on the small side.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 02-25-2013, 12:42 PM   #2027
Tommy R's Avatar
Trader Rating: 19 (100%+)
Originally Posted by CristianTabush View Post
Tommy, yes, you would need 4x 5x10x3mm bearings and a new crush tube. What I usually do is I take a couple of old 5x10x4mm bearings and cut them to get only the inner race. This works as a perfect crush tube.
Awesome, thanks! Order placed.
Tommy R is offline   Reply With Quote
Old 02-25-2013, 01:52 PM   #2028
erchn's Avatar
I'm interested in replacing the clips from spec-r on the spec-r DCJs with your clips. I would buy new DCJs from you guys, but the ones I haven't aren't that old, and work ok other than the clips kinda sucking.
Sounds like I should just pick up a set of clips from you guys and try it out.
Thanks,
E
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 02-25-2013, 02:02 PM   #2029
alloyslash's Avatar
I recieved my new DCJs thursday, got them assembled and on the T4 for some Friday Night VTA racing. Being a tight track that requires alot of steering, I noticed a big difference over stock axles. I used Hudy graphite grease on them. My large clips were a little loose, but I just squeezed them together with needle noses and they fit fine.
When are the battery hold downs gonna be back in stock for the Xrays?
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 02-25-2013, 02:05 PM   #2030
The Battery hold downs should be ready middle of next month. Along with the other goodies.
In a few days, we should have the TC6 rear bumpers back in stock and in about 10 days we should hopefully have the springs for the XRAY T4.
Old 02-25-2013, 11:12 PM   #2031
Thanks,
E
Ethan I think you should pick up a set and if they don't work you can always given to me
f1o7x9 is offline   Reply With Quote
Old 02-28-2013, 06:30 AM   #2032
Tommy R's Avatar
Hey Christian,
I received and built my RSD071 wide DCJ axles last night (thanks for the fast shipping!) and installed them into my TC6. I had some other brand DCJs installed previously so my caster blocks were already opened up for more clearance. However, it appears the RSD units are rubbing. Best I can tell, it looks like more material needs to be removed.
Before I start wallowing them out with my unibit and do a bunch of trial and error, I was curious if you (or anyone else here) knew what size I should target that would provide the proper clearance? I'd rather not remove any more material than needed, of course.
Thanks in advance!
Tommy
Old 02-28-2013, 08:12 AM   #2033
Should be between 10.5-11 mm
Old 02-28-2013, 11:56 AM   #2034
KC10Chief's Avatar
I widened mine out to 10mm and rounded the corners on the outside. Plenty of clearance!
AE TC6.1 WC w/RDS 6.2 Chassis; AE TC4
AE RC8T w/Tekno V4 electric conversion
2ea SC10; 2ea Losi Mini 8ight
TLR Ten-SCTE 2.0 (On Order)
KC10Chief is offline   Reply With Quote
Old 02-28-2013, 12:12 PM   #2035
Tommy R's Avatar
I took a 13/32" unibit and it looks like it's going to work out nicely. Should know for sure later tonight when I finish the installation.
Old 02-28-2013, 05:53 PM   #2036
jag88's Avatar
I just received my V2 DCJs for Xray. The one problem I had was that the narrow bearing would not slide all the way down the axle. I think I could of forced it the rest of the way but I don't think I would have ever got it back off. That and the larger clip needed some bending but that was no big deal. Other then that I think for the price it's a good deal.
jag88 is offline   Reply With Quote
Old 02-28-2013, 06:11 PM   #2037
Pit-racer's Avatar
Christian are you going to have opt. upgrade parts for the spec-r cars or a cross reference listing that will work with the kit. I've got an S1 which I plan for the vta eos races.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 Red
Pit-racer is offline   Reply With Quote
Old 03-01-2013, 04:29 PM   #2038
Pit, if you go on the website and you look at the parts category for the R1/S1 then you can see the parts that are compatible. In other words, if the part is listed, it works.
On another note, TC6 Carbon Fiber rear bumpers are back in stock!
Old 03-01-2013, 05:05 PM   #2039
hanulec's Avatar
Trader Rating: 27 (100%+)
Any news on the foam bumpers? Love those things..
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-01-2013, 05:09 PM   #2040
Nope, no news. China just as barely started to work and we are still trying to source the right material. The old source dried up
