Old 02-05-2013, 07:44 PM   #1981
Budman's Avatar
Trader Rating: 22 (100%+)
Oh, I forgot you will have to grind the right side of the servo saver off.
Cooper Motorsports, Team Trinity, T-Rex Racing, GFRP, MSA, VBC Racing, Track Attack, Tekin and Frost-bite Graphics
Budman is offline   Reply With Quote
Old 02-07-2013, 01:22 PM   #1982
wtcc's Avatar
Hi Christian,
I was doing some refinements on my four wheel steering conversation. I also simulated the VCS3-Shocks (TC6 & TC6.1) on the shocktower for the short shocks (the one I designed for the T4 shocks & short TShox). I then asked myself which length your new springs will have. In my simulation 20mm seems to be a good choice.
One thing I see problems upcoming is the travel with the actual spring cups. These limit the uptravel to 3.6mmwith the TC6 shock shaft ball cup (31249) which are even shorter than the turnbuckle eyelits (31305) the TC6.1 uses.
Can you leak some news on your upcoming tuning parts for the "short shock" conversation for us TC6 drivers
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 02-07-2013, 03:16 PM   #1983
CristianTabush's Avatar
Our new Short Springs are 20mm in length.
The conversion prototypes arrived today. I have to do some testing in order to see which towers work best before we go into production. I am testing them fully tonight.
The conversion will basically be 2 shock towers, some new spring cups and some new shock ball cups and ball ends. With the 20mm springs and the other items, the conversion still has about 3mm of uptravel when the chassis is fully bottomed out front and rear.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 02-08-2013, 05:26 PM   #1984
DARKSIDE's Avatar
ygpm
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 02-08-2013, 09:42 PM   #1985
B00t13g's Avatar
I have a solid few hundred packs on my rsd v2 dcjs with no failures or issues to report. Very smooth and not too much slow. Very comparable to the hudy ecs at a much cheaper cost. Looking forward to your new products for the t4.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 02-08-2013, 10:20 PM   #1986
KC10Chief's Avatar
Same here. I love my DCJs and as for upgrades to my TC6.1, it's probably the most noticeable difference in how the car handles. I started out with the V1s and they were great. I did eventually have a couple of issues with them mainly due to me completely neglecting them and abusing them every single weekend. The set screw would eventually loosen up and one of the roll pins would work its way through the heat shrink tubing. But now I have the V2s and they're great! There's no set screw and no shrink wrap! I can neglect them for way longer with no issues. I just ran a two hour enduro and had to drive about 80 minutes of it because my team mates were having issues with their cars. No issues at all with my DCJs. They still look great.
KC10Chief is offline   Reply With Quote
Old 02-08-2013, 11:12 PM   #1987
wtcc's Avatar
Nice!
Will there be a full line of 20mm springs (from teal to orange)? I would like to see them offered as a complete set as I am going to upgrade my two TC6
AE / Reedy / RSD
Old 02-09-2013, 11:58 AM   #1988
The springs are coming, but they are different springs all together. The rates will start around 13.5 lbs all the way to 17.0. If we find a need for softer, we'll look into it.
The new springs are also going to be "carpet recommended" and "asphalt recommended". It does not mean they won't work on the other surface, it just means that they are optimized for the surface stated.
Macki, that's great news. I am glad they are working well for you.
Old 02-09-2013, 06:34 PM   #1989
JustWill75's Avatar
Send a message via AIM to JustWill75
Great I just placed a big order like 30 mins ago.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 02-09-2013, 07:35 PM   #1990
Pit-racer's Avatar
What do you have for the spec-r s car kit? Sorry wrong car.
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 02-09-2013, 08:18 PM   #1991
Pit, sorry, I don't quite understand the question. Can you elaborate?
Old 02-12-2013, 11:59 PM   #1992
hanzo3's Avatar
Trader Rating: 55 (100%+)
I placed an order and received a wrong part. They haven't returned my email. What is the best email to use?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 02-13-2013, 01:16 AM   #1993
scoyle's Avatar
I am thinking about moving from my trusty TC6.1 to give the Yokomo BD7 a try - I have the TC6.1 V2 DCJ with narrow axle/bearings - would this fit in the Yokomo does anyone know as I like the build of the reflex ones (and I already have them).
Web Site: http://www.rcracingreviews.net
Sponsors: XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 02-13-2013, 07:32 AM   #1994
jag88's Avatar
I would like to use the V2 dcj's in my Xray T3.
What is the ball diameter on the half shaft ?
Can I use the Xray blades ?
What half shaft lengths are available ?
Which axle, short/wide, would I need for a normal setup ?
Thanks.
jag88 is offline   Reply With Quote
Old 02-13-2013, 07:42 AM   #1995
Jag, we make specific XRAY DCJs now. I prefer the narrow axle ones because I use the RSD spool cups as well these are roughly equivalent to a 51mm assembly. The wide ones are dimensionally nearly identical to 52mm ECSs.
Sorry, our bone will jot fit the Yokomo unless you use and AE spool. However, our couplings and axles work with Yokomo bones, so you can still get the benefits of the captured pin design.
