Old 01-14-2013, 10:17 AM   #1906
Trader Rating: 49 (100%+)
It's hard to tell from the pictures, but Caster is a measurement that can be taken using these, correct?
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 01-14-2013, 05:13 PM   #1907
I've been using a 3-racing setup station for a few years. Never compared it against Hudy, but it's been repeatable. I especially like the thumb screws for securing it to the car.
The caster measurement is only tick marks on the outside... You'd have to have something on the car as reference points for the measurement. I'd guess that the trick people are using on the awesomatix thread with the hudy station would work fine with the 3racing one, too.
-Mike
Old 01-14-2013, 06:49 PM   #1908
Thanks Mike and that is the reason I need it, caster was never an issue with my TC6 and isn't with my xray, now with my awesomatix I need to be able to measure it. I know I can measure caster using a set of calipers, but I'd probably be better off with a set of setup tools that will do it consistently.
SpeedMerchant Rev7
Old 01-14-2013, 08:30 PM   #1909
hanulec's Avatar
Trader Rating: 23 (100%+)
any word on when front bumper blanks might be back in stock??
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-14-2013, 11:00 PM   #1910
CristianTabush's Avatar
Unfortunately, not yet. I am awaiting a couple of quotes from different places at the moment.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 01-15-2013, 07:36 AM   #1911
Johnny Wishbone's Avatar
I thought the Awesomatix guys where using a phone app that would give them caster.........might be something to check into.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-19-2013, 02:21 AM   #1912
KC10Chief's Avatar
I took my TC6.1WC with my new 6.2 Evo chassis out to race tonight. It is definitely a nice difference! I don't really understand how it all works. I just know that it does. I really like how well it handles and I definitely like the bell crank steering.
KC10Chief is offline   Reply With Quote
Old 01-22-2013, 08:27 PM   #1913
bhambrent's Avatar
Any instructions for the new V2 DCJ.
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 01-22-2013, 09:12 PM   #1914
DARKSIDE's Avatar
Originally Posted by DARKSIDE View Post
RSD AE TC6.1 Dual Cardan Joint V2 (narrow axle with bearings) - 2 pcs
http://www.reflexracing.net/RSD-AE-T...cs_p_1671.html
Thank you RSD.....best thing on my TC6.1 WC...after fighting with the V1's....I installed the V2's...and Im very pleased...no trimming, and the didnt come apart...no broken c-hubs...great add-on to the RSD line of poducts...
also thanks for the stickers...
Myron Kinnard
some instructions for the new V2 would be good too
Cristian ygpm
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is online now   Reply With Quote
Old 01-22-2013, 09:31 PM   #1915
They're kind of simple, did not think there was a need for them, however I will shoot some pictures later on in the week and write a little tutorial.
A little run down:
1. Insert your barrels inside the Bone And the Axle.
2. Use the short pin and insert it in the narrow coupling side and the bone side.
3. Use the long pin and insert it in the wide side of the coupling.
4. Take the smaller diameter clip and insert the bent side into one of the holes that is not being used on the coupling. Pull the clip over so that it clips into the channel machined into the barrel.
5. Repeat step 5 in with the larger diameter clip.
When finished, the clips should hold the drive pins securely in place. Make sure the wire from the clip is seated in the channel.
Old 01-22-2013, 09:49 PM   #1916
CT, will you be putting out any versions of your springs in a shorter stack now since a few of the cars are coming out with short shocks?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-22-2013, 09:54 PM   #1917
Johnny, why YESSSS
We already have 6 different spring rates for the shorter shocks in production. They should be here in 2-3 weeks.
They will be essentially identical to, except shorter than the :
HPI Blue
RSD in between
HPI Silver
HPI Pink
Yokomo Pink and
Yokomo Blue
Old 01-22-2013, 10:16 PM   #1918
erchn's Avatar
Originally Posted by CristianTabush View Post
Johnny, why YESSSS
HPI Blue
RSD in between
HPI Silver
HPI Pink
Yokomo Pink and
Yokomo Blue
Awesome.
erchn is offline   Reply With Quote
Old 01-22-2013, 10:21 PM   #1919
erchn's Avatar
Someone told me that on the Tamiya DCJs those clips are directional, the spec-r ones don't seem to mention any such thing, any opinion?
Thanks,
E
Old 01-22-2013, 10:47 PM   #1920
Thanks,
E
The Schumacher instructions for the Schui/Spec-R DCJs for the Mi4 are very clear about which way to orient the clips.
I think the reason is that if the clip were to catch the inside of the knuckle with the car rolling forwards, you want it to pull the clip tighter, rather than catching the tip and popping it off, if that makes sense.
-Mike
