Old 12-27-2012, 12:09 AM   #1846
CristianTabush's Avatar
Default New items!!!
RSD070 RSD TC6.1 V2 DCJs Narrow Axle
RSD071 RSD TC6/TC6.1 V2 DCJs Wide Axle
RSD072 RSD XRAY/ Spec R R1 DCJ (Narrow Axle)
RSD073 RSD XRAY/ Spec R R1 DCJ (Wide Axle)
RSD070-1 RSD DCJ Coupling with Spring Retainers
RSD070-2 RSD DCJ Narrow Axle
RSD072-1 RSD XRAY/ SPEC R R1 DCJ Bones
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 12-27-2012, 01:01 AM   #1847
So the Narrows fit the TC6.1 C-Hubs with no trimming?
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 12-27-2012, 01:06 AM   #1848
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Order placed. Thanks Christian.
Old 12-27-2012, 04:27 AM   #1849
Nice CT!
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 12-27-2012, 10:33 PM   #1850
racer x 1's Avatar
Trader Rating: 27 (100%+)
will the tc6 range of springs fit the spec r r1? curious as im a little hesitant to place that order without knowing...
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 12-27-2012, 10:35 PM   #1851
Yes, They should fit great. The Spec R Shocks are designed to fit 13 and 14mm springs
Old 12-28-2012, 12:50 AM   #1852
racer x 1's Avatar
from your experience do you prefer the tc6 springs or the xray style springs from spec r?
Matt Bell
Old 12-28-2012, 10:33 AM   #1853
I only use RSD springs.
Old 12-29-2012, 12:43 AM   #1854
Mini-Mod's Avatar
V2s look awesome. The rings are a way better idea than just a set screw.
E.Albano
Yokomo / Hobbywing / JConcepts / A Main Performance Hobbies / Solaris Racing Products / ProTek RC / Schelle / Boom RC / TNP (TopNotchPaints)
Mini-Mod is offline   Reply With Quote
Old 12-30-2012, 05:33 AM   #1855
USPS brought my RSD order today, thanks CT. I am really impressed with the Xray/R1 DCJ's and aluminum spool outdrives. The use of a CS screw in the bottom of the cup is a great design; looks like 52 mm bones will clear with no issues!. I also love that I can run the DCJ's and then rotate the pins to another hole if any slop develops. These DCJ's seem to articulate much smoother without the set screw and shrink wrap. Plus they're a breeze to lube and service. Thanks again man. You have yourself one very satisfied customer here!
Old 12-30-2012, 06:01 AM   #1856
Christian.
I actually have a TC6 standard kit.
If I order you a RSD6.2 Evo Full Conversion Kit, does I need something more ? (battery holder...).
Thanx.
Cedric.
kerb is offline   Reply With Quote
Old 12-30-2012, 12:15 PM   #1857
Andrew, that's awesome! Glad you like them.
Cedric, no you don't need anything else.
Thanks!
Old 12-30-2012, 12:18 PM   #1858
So the TC6 standard batterie holder can be installed on the RSD6.2 ?
Another question : For a big european outdoor asphalt track, witch set of spring should I chosse ?
Old 12-30-2012, 12:33 PM   #1859
No, it can not be installed. The evo comes with battery stoppers. Please look at the product pictures on the website. When used with tape, they are more than adequate to keep the battery in place.
I am not sure about springs, but personally I run on a large track over here and I use pink, black and purple mostly. I think 2 sets of each should take care of your needs, unless grip is too low. However even with low grip, I tend to like stiffer springs.
Old 12-30-2012, 01:21 PM   #1860
Ok, thanx.
