Old 11-29-2012, 03:15 PM   #1786
Originally Posted by CristianTabush View Post
Mike, it might be the type of tamiya yellow. There are so many that it's hard to tell which ones you may have. I tested the white powder coated type.
The way they are tested is at 1/8 in and 1/4 in compression with the spring slightly pre-loaded. It is an average of this. Since most springs are linear, the variation is within 0.1 lbs 99.9% of the time.
Thanks. My Tamiya yellows are the white powder-coated ones with the paint dot, that come with the TRF Special Damper set.
-Mike
Old 11-30-2012, 11:08 AM   #1787
Fantastic job on the spring chart!
Now, if only the postal service could speed things up
Reflex Racing, Mini-ZNorway.com
Runerg is offline   Reply With Quote
Old 12-02-2012, 05:20 PM   #1788
CristianTabush's Avatar
Just got word from the factory that the RSD6.2 EVO chassis are all done and on the way. They should start shipping from our shop on Friday/Monday.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 12-03-2012, 09:50 PM   #1789
RSD066 RSD XRAY/ SPEC R R1 HARD ANODIZED 7075 T6 ALUMINUM SPOOL CUP (1 PC)
These Hard Anodized 7075 T6 Aluminum Spool Cups were designed to be used with Plastic Blades on your XRAY or Spec R Touring Car front Spool. Due to the material these spool cups are nearly as light as plastic spool cups, but are more durable and much stronger.
These spool cups are ideal for stock racing and they also provide increased life of your front blades due to its larger diameter construction.
Old 12-04-2012, 12:17 AM   #1790
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Dialed!
Will they accommodate 52 mm ecs's with typical 1.5 mm spacing up front?
Old 12-04-2012, 06:29 AM   #1791
These look great and what a shocking price!
Greg
Hyper One is offline   Reply With Quote
Old 12-04-2012, 09:01 AM   #1792
Originally Posted by andrewdoherty View Post
Dialed!
Yes, they should. They were designed to have plenty of plunge. Any more and it would compromise strength too much.
Old 12-05-2012, 08:43 PM   #1793
Default Sticker Sheets
They are currently being made. They will be at the shop in like 10 days or so. The sheets will be 4x6" screen printed on clear.
We will provide a free sticker sheet in every order over 100.00 USD. Otherwise, they will be sold at 2.50 per sheet.
Old 12-06-2012, 08:06 AM   #1794
mtbboy's Avatar
It's kinda sad how excited I am for a sticker sheet.
You did such an incredible job with the spring chart Christian. Makes me wonder how amazing a CST comparison chart might be. Hint hint.
When will the evos be shipping?
Dave.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 12-06-2012, 10:26 AM   #1795
Evos shuld be early next week. If they show up today maybe we can get to a few of them tomorrow.
I don't have access to shock oil testing equipment, however sweep has a very good one comparing AE and their oil. You can find it on their website. Personally I don't use anything but those two. However with the thick oil in the six hole pistons I have been blending some spec r 2000cst with 1300cst to get 1650cst.
Old 12-06-2012, 10:50 AM   #1796
JustWill75's Avatar
Send a message via AIM to JustWill75
Hey CT, what's up with the new DCJ's for the TC6? Any pics yet?
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 12-06-2012, 11:19 AM   #1797
Nope, no pictures. Sorry.
Just received the chassis. We have a slight problem, so they will be delayed a bit until we can have this resolved. I will keep everyone posted.
Old 12-06-2012, 12:57 PM   #1798
frenchchris's Avatar
good afternoon all
Christian i will place a preorder for the evo 2 rsd 6 , what i need to fix correctly the battery as i drive on a bumpy track
do the carbon holder rsd 6 are sold with all the fitting or can i bought all the necessary fiting
thanks chris
frenchchris is offline   Reply With Quote
Old 12-06-2012, 01:30 PM   #1799
Originally Posted by frenchchris View Post
good afternoon all
thanks chris
Hi Chris, tape should be more than good enough to hold the parts in place, however, you can buy the carbon fiber battery braces and they will offer a little bit extra protection. If you order them, I will throw in the necessary hardware to get them installed.
Old 12-08-2012, 03:41 AM   #1800
Thumbs up
thanks christian
i will place my order right now rsd 6 evo + battery brace and hardware
so you will have also an rsd 6 racing in the south of france will send you picture
with the stickers
do you know where i can find some ceramic bearing 10 x 5 x 3 because i want to use my tc6 integy aluminium steering hub with your blasting cvd
have a niced weepk end
chris
