Old 11-28-2012, 12:17 PM   #1771
CristianTabush's Avatar
Those will be a while. They are not too high on our priority list right now.
The sticker sheet design is done now. They have been sent to be quote already.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-28-2012, 12:22 PM   #1772
Originally Posted by CristianTabush View Post
You can always have decals made at upgrade rc, they have our logos.
And do great work!
I have a couple of radio skins with Reflex Racing logo's and they are top notch!
The 6 hole pistons sounds interesting really. Will definetly try them out.
Reflex Racing, Mini-ZNorway.com
Runerg is offline   Reply With Quote
Old 11-28-2012, 12:40 PM   #1773
Suspended
Originally Posted by dennisV View Post
I need that decal too . Congrats with your result!
how about a setup sheet??
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 11-28-2012, 01:32 PM   #1774
wtcc's Avatar
So when do I have to place an order to receive one sticker sheet?
AE / Reedy / RSD
wtcc is offline   Reply With Quote
Old 11-29-2012, 04:31 AM   #1775
hi chris , could you update the sping chart on your web site in the RSD6 TECH PAGE . with the new spings you have
thanks
vm2 ,tm e4,mi 4,cup racer,yokomo d1,TCX,PHI RDX,MI4CX,TC6,china made pro-d.
ps.just came back to this hobby this year after22 years .
oldnoob is offline   Reply With Quote
Old 11-29-2012, 09:35 AM   #1776
Johnny Wishbone's Avatar
Originally Posted by Johnny Wishbone View Post
Shock body I.D. = 10.00mm
Piston O.D. = 9.90mm
Shock shaft hole is either 2.50mm or 3.10mm depending on which shaft you use (RCXX or RCM shcok)
Let me know what you can do or what might work.
Hi CT, any luck with this?
Thanks CT, was curious if these are similar in size to the Tamiya shock? Or do you have the size specs on your pistons posted somewhere on your site? If so where?
Thanks again.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-29-2012, 10:06 AM   #1777
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Thanks again.
I think a page two two back Christian posted the sizes of the various makes of pistons. I think the Tamiyas were in the list he made. I might be wrong though. Maybe search for posts by Christian on this thread and look back the last 4 weeks.
AWD
Old 11-29-2012, 10:55 AM   #1778
The dimensions of the serpent shock are similar to the Tamiya. What is the thickness of the piston? That's where it would all be different.
Our piston is probably too big for the Serpent shocks. The AE piston size is a little bigger than 10.00.
We are still looking at alternatives. However, thickness dependent, you might be able to use Tamiya blank pistons, they come with 6 indentations on them, so you can probably make them work on the Serpent.
Old 11-29-2012, 12:34 PM   #1779
Default I'll do one better
thanks
been compiling this data for a while. The newsletter finally went out, so I wrote a little article about it, this is it:
http://reflexracing.3dcartstores.com...art_ep_58.html
Old 11-29-2012, 12:41 PM   #1780
Please feel free to link the page and spread it across the web, including the forum. This is VERY Valuable information that is not often accessed. The biggest advantage over other spring charts is that these are all tested on the same machine, using the same process, by the same person. It is extremely accurate, and we will add to it as we go along the way.
Old 11-29-2012, 12:52 PM   #1781
erchn's Avatar
This is great.
While terribly self-serving and probably expensive, any chance we could have the XRAY T4 springs tested? I would be willing to ship mine over temporarily for a test. Also, I notice HPI Pink's (from pro4 kit) are missing, any particular reason other than lack of test subjects? I'm guessing AME might be willing to send some test springs also, since they make a high quality product.
Thanks a bunch for this!
Ethan
erchn is offline   Reply With Quote
Old 11-29-2012, 01:03 PM   #1782
Ethan, send them and I will gladly test them. Hpi pinks are on hand now.
Old 11-29-2012, 02:14 PM   #1783
AWD
Found it, thanks Andrew.
Thanks, I'll take a thickness measurement.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 11-29-2012, 02:48 PM   #1784
Cristian,
Does your test rig let you generate force vs. displacement charts? I'm really curious to see the subtle differences between springs that are the same or similar rate. For example, according to your chart, a Tamiya Yellow is stiffer than an HPI Pro4 Blue, but compressing by hand the Tamiya yellow feels softer.
How much do you compress the springs to arrive at the rate in your chart? Is it a relatively small amount, like what an RC car would actually see on track, or is it all the way to coil bind, or somewhere in between?
-Mike
Old 11-29-2012, 02:55 PM   #1785
Mike, it might be the type of tamiya yellow. There are so many that it's hard to tell which ones you may have. I tested the white powder coated type.
The way they are tested is at 1/8 in and 1/4 in compression with the spring slightly pre-loaded. It is an average of this. Since most springs are linear, the variation is within 0.1 lbs 99.9% of the time.
