Old 11-20-2012, 07:04 AM   #1726
Finally caved in.
RSD6 for me also
Really looking forward to try out 1:10 touring again after 10+ years with Mini-Z and some offroad in the summer.
I think this is the first RSD6 here in norway, but hopefully not the last.
Two general questions.
Any recomendations for spur gears? What are concidered the best these days?
Body choice for smaller technical tracks?
Reflex Racing, Mini-ZNorway.com
Runerg is offline   Reply With Quote
Old 11-20-2012, 07:45 AM   #1727
briankstan's Avatar
Originally Posted by Runerg View Post
Finally caved in.
RSD6 for me also
We run a smaller carpet track, I'm using kimbrough gears, geared at 4.44 (45/100). I've also run the Mazda speed 6 and LTC-R, I prefer the LTC-R as it seems to have more steering than the Mazda body.
I'm running RDS springs (14.5 Rear, 15.5 front) with AE 40 oil in the back and AE 47.5 in the front. I'm also liking the Sorex 28R tires with Paragon on them.
www.slmini-zstore.com
www.saltlakemini-z.com/forum
www.howfastareyou.com
briankstan is offline   Reply With Quote
Old 11-22-2012, 09:40 AM   #1728
Thanks. Sorex Tires were the tire to use earlier also, and seems to be the best these days also. 28's are used as a spec tire at the nearest track.
Are you racing mod or stock?
Old 11-22-2012, 10:57 AM   #1729
briankstan's Avatar
we are racing 17.5 blinky for our TC class we have about 11-13 drivers most days.
Old 11-24-2012, 05:44 AM   #1730
CT, I've noticed the hold down system for the RSD is out of stock, do you know when it gets back in stock? It's the last (missing) item for my shoppingcart @ reflexracing ;-)
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 11-24-2012, 08:52 AM   #1731
CristianTabush's Avatar
These are probably 3 weeks out.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-24-2012, 10:46 PM   #1732
any word on those new pistons ?
ed
Edwin Pibal is offline   Reply With Quote
Old 11-26-2012, 11:48 AM   #1733
Default Pistons and Big Announcement.
Hi Ed, the pistons arrived today. Just have to get everything prepped and products added to the site.
We also have a big announcement coming today, please stay tuned.
Old 11-26-2012, 12:17 PM   #1734
oohhhhhh
its like being a kid in a candy shop 8)
thank you for the update!
Old 11-26-2012, 12:45 PM   #1735
Default RSD6.2 EVO
RSD6.2 EVO
After a year of testing, we have learned a lot from the RSD6 platform, and the RSD6.2 EVO is a reflection of this. The new chassis design has been developed to provide higher versatility and better performance on both carpet and asphalt.
It's all about the little details, and the attention to them, and this is what the RSD6.2 EVO is.
New features:
-2.25mm Carbon Fiber Bottom Deck- Makes the chassis more versatile. If you need more flex, use the RSD top deck. Less flex, use stock top deck. With a 2.25mm chassis, we no longer have the need for a 2.0 and 2.5mm lower deck.
-Aluminum Center Mount Servo Holder
-Adjustable Position Battery Stoppers: The battery can be moved fore-and aft 4mm with the use of shims on battery stoppers. Furthest back position in 2mm further back than RSD6 and 5mm further back than the TC6. The RSD battery hold down system will STILL BE COMPATIBLE with the Evo, but excluding it allows us to sell the kit at the same price point.
-V3 bell cranks: The Bell Cranks have been moved back 1mm in order to allow for more ackerman possibilities and better angles.
-Chassis is now compatible with TC6 Center post Bell Crank, and will be sold with and without the Dual bell Crank Set Up in order to provide a lower cost alternative to the RSD6.2 EVO
-Chassis now has 2 small pin balance holes drilled in the chassis.
-Chassis has less cut-outs to provide better high speed stability.
Pre-orders will go up tonight. Chassis kits are due to arrive in about 2 weeks.
Old 11-26-2012, 01:22 PM   #1736
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
Cristian. Sent you an email about an Order I had a week ago. See if its in your spam folder.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 11-26-2012, 01:29 PM   #1737
K, checking on it now.
Old 11-26-2012, 01:46 PM   #1738
erchn's Avatar
Hi all,
I find it difficult to get the right spacing under the battery hold down system (RSD038) and get the graphite piece to line up correctly over the battery. I ended up spending quite a bit of time with various shims to get it just right, and I think it only works for me because I use the plastic battery braces, which flex a little bit.
I think removing the slot for the graphite would make it much easier, as you could spin the graphite to the right location. I think Awesomatix's version is quite a bit easier to adjust.
Thoughts, maybe a v2 option?
erchn is offline   Reply With Quote
Old 11-26-2012, 01:55 PM   #1739
Well, we put the slots in there to get them to not rotate. At speed, the parts can vibrate loose and this is just an extra "fail-safe".
One thing that I have seen is people adding Mylar tape to their batteries to get the spacing just right since all batteries vary just a bit. Some have also used heat shrink to cover the tabs where they touch the battery.
For me, I would always use +-0.5-1.0mm shims for different packs. 0.5-.75mm of slack will not really hurt anything.
Where are you having your problem? Are you trying to make them too snug, or maybe to precise, where they just rest on the battery?
Old 11-26-2012, 04:09 PM   #1740
erchn's Avatar
I ran the Awesomatix ones for about 4 months, never had a loosening issue. But I suspect that a little bit of knurling of the aluminum where it meets the graphite would have solved it also, while allowing flexibility in placement.
Yea, trying to get them too precise probably. I was shooting for about .2 or .3mm of space between them and battery. This time around (new car) I'm going to just add spacers to get the rotation correct, then add spacers between the graphite and aluminum to get the height correct.
I'm just being anal I know, but thought I'd give a little feedback.
Thanks,
Ethan
