Old 11-10-2012, 04:45 PM   #1711
bjanzen's Avatar
Originally Posted by CristianTabush View Post
Barry, you should be ok with the regular TC6 parts. The set-ups don't really change much. There is a slight geometry revision in the rear arms to the 6.1, but nothing that will make the car work completely different.
The set-ups from the TC6 to RSD6 are sightly different. The RSD6 has a bit more of a rear ward weight bias so this allows you to run the same oil and spring F/R more often than with the TC6. There are a ton of set-ups on our website. Anyone of them would be a good starting point. Just look for one that matches your track conditions.
Thanks for the help Cristian, I have swapped over my TC6 to the RSD6 chassis. I have cut both ends of the stock upper deck. I have looked over the setups and every one is for a RSD6.1 (if it can be called that)...... So I am starting with my last setup and will have to tweak as needed. Guess I will need to update my chassis to 6.1 parts so I can swap setups. Maybe we could start being more specific with this product by calling it a RSD6.1 if it has the updated arms and hubs.......
bjanzen is offline   Reply With Quote
Old 11-12-2012, 09:14 PM   #1712
CristianTabush's Avatar
Default New Items
RSD059 RSD 15.0lb Spring (Pink)
The RSD Pink spring is similar to the Yokomo Pink. It has the same spring rate and was developed to be used in carpet set-ups in the front end of your TC.
RSD058 RSD 17.0lb Spring (Orange)
The RSD Orange Spring was developed to be used on high grip asphalt settings. This spring is slightly stiffer than the RSD purple for when the purples are too "stuck"
RSD057 RSD6 Aluminum Floating Servo Mount
Made from 6061 Aluminum, this servo mount comes in at only 7 grams. While the RSD6 already came with a carbon fiber floating servo mount, the servo was prone to rotating in heavy collisions. This aluminum servo mount fixes the issue and makes the installation of a servo a breeze. Another plus is that you can now play with your servo position forward/back +-3mm as the servo position is moved back 3mm from the regular RSD6.
All items now available and shipping.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 11-12-2012, 11:00 PM   #1713
B00t13g's Avatar
Are your blue springs similar to the yoko blues if not, any plans for some? Any stock status for bd7 dcjs?
B00t13g is offline   Reply With Quote
Old 11-12-2012, 11:04 PM   #1714
The RSD Green springs are similar to the Yokomo blue. Our Blues are stiffer than Yoke blue but softer than pink.
DCJ's are out of stock at Spec R for the Yokomo, so sorry, I don' have a stock status update.
Old 11-12-2012, 11:05 PM   #1715
Does the floating mount work on the stock TC6.1? Any modifications needed to the steering parts?
HPI Sprint 2 Flux - GPM and OEM hop ups
AE RC10TC6.1FT - partial WC conversion, RSD hop ups
3Racing FGX - IFS, OEM Aluminum, Exotek hop ups
Vostok 7 is offline   Reply With Quote
Old 11-12-2012, 11:07 PM   #1716
No, this is not a TC6 upgrade, it is for the RSD6. I am sure it can be made to work, but you would have to drill and countersink at least 1 hole on the chassis to make it work.
Old 11-12-2012, 11:07 PM   #1717
B00t13g's Avatar
Thank you.
Old 11-12-2012, 11:09 PM   #1718
Got it, thanks.
Old 11-13-2012, 12:41 AM   #1719
evochick's Avatar
I really like the look of that servo mount. I think I'll give it a go on my 6.1wc chassis with some drilling
Beth
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 11-13-2012, 12:45 AM   #1720
Will order new stuff soon! :-) Mount is looking nice CT.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 11-13-2012, 05:09 AM   #1721
Does the holes line up for the BD7? Since the yok one is an upgrade
zzztech is offline   Reply With Quote
Old 11-13-2012, 08:11 AM   #1722
I don't think the Yokomo would be a go. Our holes are off-set due to the hole pattern on our chasisis. I think that you would be able to make it fit if you happen to drill a hole into the chassis, however it might overlap a hole. Not sure though, have not even thought about it.
One thing to note is that on some short servos that are thicker, shims are required to be used to space up the servo slightly off the bottom deck. We made it this way because we did not want to have people with the thinner servos have their servos 2mm off of the bottom deck.
Old 11-13-2012, 12:00 PM   #1723
i need some discount , haha my cart has so much items in it
Hope you don't come up with any new things soon Cristian.
株式会社 ヨコモ
Old 11-13-2012, 12:29 PM   #1724
heh, i know that feeling, i have a cart full of springs, just waiting for these new pistions to come out now 8)
ed
Edwin Pibal is offline   Reply With Quote
Old 11-19-2012, 09:18 PM   #1725
Default New item:
RSD060 RSD 13mm Lightweight Aluminum Spring Cups
