Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)
#1651
#1655
Christian,
I left you voicemail earlier.
Give me a shout when you get a sec.
Brad
Brad
#1658
Edit: Here are some pics. The Gens Ace battery is my VTA car, the Exotek T2'07 using the stock Exotek lipo hook thingies. The other one is my sedan, an Xray T3'11 with the Exotek chassis, using the Team SR battery holders. The stock Xray battery holders will work just fine though. Youll just have to shim up the battery overhang thingy.
#1662
Any 2mm pin will work. All other TC's in the market use this size pin.
With the TC6, you will also need 5x10x3mm bearings as they are a different size. For a crush washer, look for something the same width as the stock crush washer, but a smaller ID.
One thing you can do is take some old 5x10x4mm bearings, cut the outer race off and just keep the inner race as your crush washer.
#1665
Alu outdrives
Wondering when the alu. spool outdrives will be in again? Thanks
