Old 10-18-2012, 08:22 AM   #1606
wtcc's Avatar
Originally Posted by CristianTabush View Post
Our new purple spring is a 16.4 and is pretty close. This is my new favorite spring.
Mine too. The car is just more awesome in tight corners and chicanes
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 10-18-2012, 08:33 AM   #1607
DARKSIDE's Avatar
when will these be back in stock
RSD TC6 Suspension Block Locks
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Summer Slam
July 28-30
DARKSIDE is offline   Reply With Quote
Old 10-18-2012, 08:40 AM   #1608
CristianTabush's Avatar
Myron, right now, not sure. I am going to try to source them out to a different vendor. The issue we have is that the vendor that makes these for us recently re-located facilities. With that, several of our items are being delayed a bit.
I am also going to re-design them a bit. I will see if I can come up with something even better. I have a few ideas in my head at the moment. However, i want to maybe make whole blocks and incorporate pillow balls. We'll see if it is at all possible.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 10-18-2012, 09:03 AM   #1609
Rick Hohwart's Avatar
Originally Posted by DARKSIDE View Post
...speaking of the Club Racer?...its gain alot of popularity lately...any chance of RSD making any upgrades for it...I know there are tons out there...but you guys make some really nice upgrades...just saying..
This car is selling very well; even more so than we anticipated. AE has some upgrades but it would be nice to seem some modern upgrades from RSD.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 10-18-2012, 09:11 AM   #1610
Thanks for the info Rick. We recently became an AE/REEDY re-seller through one of your authorized distributors. We are expecting our first batch of parts to come in this Friday/ next Monday. Among our plans are to carry a "club" racer line of parts including VTA and TC4 items. We will definitely see what we can come up with for the car.
Old 10-18-2012, 01:16 PM   #1611
G4ZZ4's Avatar
Hi guys Does your messaging system work on the web site?
cheers Garry
YOKOMO BD7, 21.5 boosted M11x
S2H bodies
G4ZZ4 is offline   Reply With Quote
Old 10-18-2012, 02:04 PM   #1612
I just checked it, and I have not received anything in 2-3 days. I will call our hosts to see what's up.
Old 10-18-2012, 02:24 PM   #1613
Just ordered some rsd parts
using assoc. green springs all around on my tc6,1, what rsd spring would be best to start with instead?
Xray T4`16 - Hobbywing - Highest - Sanwa - Gens Ace
Xray XB2 - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 10-18-2012, 02:37 PM   #1614
G4ZZ4's Avatar
:/ I just wanted to fix up an order i did but the order went out so quick it was too late anyway.
cheers Garry
S2H bodies
Old 10-18-2012, 03:27 PM   #1615
Got it fixed. Sorry. We try to be as quick as we can Sometimes Mondays are a bit overloaded.
Bappe, if you were using AE Greens, try starting with RSD Yellow to start off.
Old 10-18-2012, 03:38 PM   #1616
JustWill75's Avatar
Send a message via AIM to JustWill75
Hey Christian, have you tried the DCJ's front and back setup yet? I would like to learn what the advantages are if any.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 10-18-2012, 03:49 PM   #1617
Not yet. I run my car fairly narrow in the rear, so I cannot get them to fit with a gear diff. with the V2 DCJ's, which should be available in Early December, we'll be able to do it. All current DCJ's will be able to be upgraded to the V2's.
Old 10-18-2012, 05:09 PM   #1618
JustWill75's Avatar
V2 DCJ any pics
Old 10-18-2012, 05:11 PM   #1619
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Thumbs up
Cristian how is the servo mount going to work will we just be using the one screw on the inside of the chassie if so what is going to keep it from moving
When under a load if the screw is not tight
Was thinking of using one of your servo savers and turning the servo
And mounting the link to the screw that holds the akerman
I think this will work or at least worth a shot
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 10-18-2012, 05:51 PM   #1620
VAzRACER's Avatar
Trader Rating: 17 (100%+)
The servo mount uses the existing screw hole and one that is slightly behind and to the right of the first hole, it is in the center line of the chassis.
I've heard of the servo being turned on the TC5, I think Hebert did it. I've never seen it done on a TC6. It wouldnt produce the same results as the RSD6 but I imagine the steering would be quicker and more direct.
Reflex Racing / Psycho Cells
VAzRACER is offline   Reply With Quote
