Barracuda from Alex racing
#826
last one
#827
My Pal.
#828
Originally posted by Tsubasa Sakai
My Pal.
My Pal.
#829
Originally posted by fReShJiVe
SWEET!!!i'm a sucka for silver stuffs
#830
Re: Re: PAL CE-4 Parts
For 14000yen bulkheads,I prefer to custom modify the original one.
How much are the lower shock towers?What is the point to use it?
Also I had installed the HPI Pro3 front sway bar for my CE4 rear one.Do you see any front sway bar for CE4??
Most of the people that tried the front sway bar over her have taken them off.... they CE-4 dosen't respond well with one... Well at least mine anyways
BTW here's the Pic' sorry
-Dave
#831
JDM_DOHC_SiR: Wow,your CE4 is very new and clean.Nice.
#832
My CE4
#836
Re: Lot's of red Jive'
Originally posted by JDM_DOHC_SiR
Your "Cuda" looks great!!
I also see that you have the new R2 arms on now too
-Dave
BTW how did you mill out the battery slots.??? and who makes that front brace on the bumper..??
-Dave
battery slots were milled by my buddy named "dremel"
front bumper brace made by "fReShJiVe"
#837
by milling the slots wider i felt that more air could pass through the batts from the bottom and cool the batts as there's more gap between the batts and the chassis.....and also lighten the batts side so i dont need to add that much weight the the motor side...but then again i could be having more flex on the batts side...so i guess everything is a compromise
#838
Re: Re: Lot's of red Jive'
Good job!! ..with your buddy.... "THE DREMEL"..
When I get back to Japan.....( when ever this Iraq B.S. is over ) .... I'll have time to take pic's of all the new stuff that I have
#839
I want to try something different, would you recommend a Speedway Pal Cuda or an R2? I know the Pal is more $, but is it worth it? Thanks.
#840
You're in Iraq? What are you doing right now?
-Leon
-Leon
