Barracuda from Alex racing
#3543
i am building the shocks right now, and dont know which pistons to use. the kit includes to diffrent, but for me both piston holes are looking very small. does anyone know witch size they are?
i heard sth about 1,2mm should be ok..
what size are the hpi #2 ?
should i swich to the hpi ones?
is the topcap the same as yokomo?
#3544
alot of us use the HPI #2 piston, I believe it has (2)1.1mm holes. with 30-40wt oil, The new Rayspeed pistons look interesting also.
Congradulations on the R2 purchase, this is a very quick car, you will see
#3545
if i am building the car with the plastic center shaft holders, can the blevel gears be removed without damaging them, if i upgrade to the aluminium ones?
#3546
Originally posted by RedBullFiXX
hello Jan....er uh TC3
-Dave
#3547
-Dave
#3548
Originally posted by JDM_DOHC_SiR
the 1.1 pistions are a very good choise with the long span arms...but I prefer the 1.2 drilled pistions and heavier Oil..
-Dave
-Dave
will asso pistons work on the r2 shocks?
#3549
When putting the bevel gears in I would often strugle, I carefully cut a slight angle on the little notches, and I mean VERY slight, so they can slide in just a little easier, instead odf the flat surfaces just pressing against each other, notches still hold it in firmly and it makes it an awful lot easier to get in.
#3550
Fish
Look what the net brought in...
it came with...
Novak XXL
Futaba ESC 330CR
Reedy MVP
Nissan Altima
Sorex 28Rs
what else should I put in? hmmmmm...
it came with...
Novak XXL
Futaba ESC 330CR
Reedy MVP
Nissan Altima
Sorex 28Rs
#3551
Regional Moderator
Re: Fish
it came with...
Novak XXL
Futaba ESC 330CR
Reedy MVP
Nissan Altima
Sorex 28Rs
it came with...
Novak XXL
Futaba ESC 330CR
Reedy MVP
Nissan Altima
Sorex 28Rs
where you fish at so i can catch me a few like that
#3552
Re: Re: Fish
I live in a country thats got 7,101 (7,100 on high tide) islands... bound to happen any time. Any tips on a high bite-huge track?
#3553
Re: rc-zombies
Originally posted by Randman
rc-zombies - I have a job for you that could benefit the R2 arena
Can you compare the axles on the R2 to the axles on your SD. I think we might be running the same stuff as the SD is except for the diameter of the front axle is 6 rather than 5. If the axles are the same length, we can benefit by going to a larger front bearing (5x10 rather than 6x10) which should last longer... and Square makes titanium axles
The car shares other parts from Yokomo, lets pray this is one of them.
Yes... I've already thought about it... get back to you soon on the axles.
#3554
R/C Tech Elite Member
Tip on drilling them out, dont do it with an electric drill, get a small hand drill and slowly drill the holes. You dont want to twist at them once the drill is through either, just back it off otherwise you'll distort the hole.
#3555
Re: Fish
it came with...
Novak XXL
Futaba ESC 330CR
Reedy MVP
Nissan Altima
Sorex 28Rs
it came with...
Novak XXL
Futaba ESC 330CR
Reedy MVP
Nissan Altima
Sorex 28Rs
