Old 09-09-2004, 06:51 PM   #1
Default What gears for my new ride?
Here is my first electric car I'm about to build:
Associated TC3 Factory Team Kit
Novak Super Sport Brushless System
(2) Epic 3000mAh NIMH Sport Battery Pack
HPI Dodge Viper GTS-R Body 190mm
(2) HPI Racing Slick Belted Tire 24mm (2)
Futaba 3PM 3-Channel FM/2 S3003 Servos 88
My question is, what gears do I need? Spurs and what not? What setup would you recommend?
Also, what do you think of this setup?
fubarman is offline   Reply With Quote
Old 09-09-2004, 11:15 PM   #2
Speedo's Avatar
R/C Tech Charter Subscriber
I think the FT kit comes with a 72 (?) teeth, 48 pitch spur. I would stick with that while you're getting started, but if you want a quieter car go with 64 pitch. 64 pitch is finer and will give you more gearing options, however it is not as durable, meaning you will have to pay careful attention to setting the pinion/spur mesh. 64 pitch is much quieter, but if you are going to be running the car in anything less than very clean conditions I would not recommend it.
As far as a 64 pitch spur, I believe I have a 100 tooth in my car, which is a nice even number and about as large as you can get with a TC3. I have no idea about gear ratios for a brushless motor, so someone else will have to give you some advice on what size pinions to buy. Brands to look at would be Robinson Racing, KW spurs (dist. by Shumacher USA), and Titanium Racing.
Good luck,
Speedo is offline   Reply With Quote
Old 09-10-2004, 01:18 AM   #3
Go to www.teamnovak.com and you will find a section on how to properly gear the brushless system. If you gear it like a standard brushed motor you'll have problems.
Lano is offline   Reply With Quote
★ Robinson and Kimbrough Pinion Gears and Spur Gears - All NEW! ★ All-Star R/C Items: For Sale/Trade 40 01-21-2009 01:59 PM
WTB: Rc10t4 Spur Gears, And Pinion Gears Associated-08 R/C Items: Wanted to Buy 0 03-10-2008 08:19 PM
Lot of 14 Pinion Gears, 2 Pinion Holders, and 3 Spur Gears (64 Pitch) MyRCTrader R/C Items: For Sale/Trade 4 02-04-2008 06:08 AM
1/10th Pan Car Setup - CORALLY C10X - Gears, Gears, Gears? paul73rc Oval, Larger Scales and More 4 04-06-2007 09:10 PM
Layshaft Gears, Pinion gears for 1/5 scale.. MaxPower Oval, Larger Scales and More 0 04-08-2003 05:16 PM
SEO by vBSEO 3.5.0
