Old 04-18-2011, 12:33 PM   #91
anyone know where to get this setup sheet from i went on the website thats at the bottom of the image but can't find it.
cheers for anyone that helps
mavrickf1 is offline   Reply With Quote
Old 04-18-2011, 12:38 PM   #92
westy1969's Avatar
chk first post of this topic.
CRC Gen-X 10 200mm indoor-setup | CRC PX10W full 235mm
westy1969 is offline   Reply With Quote
Old 04-18-2011, 12:46 PM   #93
cheers mate should of looked at the start, thanks again
Old 04-18-2011, 12:52 PM   #94
i've just noticed on the setup sheet thats there is a 213 software i can only find 211 anyone know where this is, its not on the hobbywing site
Old 04-18-2011, 02:30 PM   #95
213 isnt out yet only a few people have it ...
stcc ssb tires, ko ,gm motors, demon products lipos, hobbywing speedo
mwoods is offline   Reply With Quote
Old 04-18-2011, 04:35 PM   #96
getpip's Avatar
Default 8.5t 2wd 1/10 off road
Hello fellow hobbywingers.
I am a longtime user of HW products but this is a new project for me and I need some help.
I am installing an 8.5t motor into a 1/10 ep buggy with an HW speedo.
Can anybody give me a pointer as to the best software profile to run and maybe some ball park settings.
Thanks chaps.
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 04-18-2011, 11:03 PM   #97
MENTAL DENTAL's Avatar
Originally Posted by toms dad View Post
Have you tried setting the low voltage protection to 2.8v?, worked for me.
I've even disabled it. Thing is, it doesn't happen with another 60A esc.
I've reflashed the esc several times.
MENTAL DENTAL is offline   Reply With Quote
Old 04-22-2011, 11:56 AM   #98
JRXS_chris's Avatar
Default A great days testing....
Hi Guys, just sharing what I've been working on today;
Associated TC6
LRP X12 10.5 (Massive Heatsink and Fan)
Extreme Stock w/211 firmware
Sorex 32 (knackered)
Orca 6000mah 60C
LTC-R
Track - Halifax, UK (Massive, High Speed with great traction)
Track Temp - 43*c
Air Temp - 22*c
Ratio - 6.96
3
37
12
19
13000
0.4
550
Great punch throughout the track, noticable even with it being a revvy track. Top speed excellent, same speed as a guy preparing his 1/10th IC car for the BRCA Nationals!
Motor came off at 90*C. Would be alot hotter without the fan.
Bit pink now from the sun and need a beer
JRXS_chris is offline   Reply With Quote
Old 04-23-2011, 06:32 PM   #99
drsmooth's Avatar
Trader Rating: 33 (100%+)
Ran 17.5 class today. Track was low grip due to water weeping up from the cracks in the asphalt. But the Type R was very good. I was the only one to turn 20 laps, & that is including the modified class also.
Here are my settongs:
MOTOR: NOVAK SS 17.5
FDR: 7.81
F/W: 211
MOTOR TEMPS: 119
ESC TEMPS: 85
RUNNING MODE: FORWARD/BRAKE/REVERSE
DRAG BRAKE: 0%
VOLTAGE PROTECT: CUSTOM 6.2
DDRS: LEVEL 9
BRAKE FORCE: 87.5%
REVERSE FORCE: 50%
INITIAL BRAKE: 0%
NEUTRAL RANGE: 6%
BOOST TIMING: 35
TURBO SLOPE: 18 UNITS/0.1 SEC
OVERHEAT PROTECT: ON
TURBO TIMING: 30
BOOST START RPM: 4000 RPM
TURBO DELAY: 0.3 SEC
TIMING ACC/SLOPE: 350 RPM/UNIT
Till next time.......
KEEP ON RACING!
drsmooth is offline   Reply With Quote
Old 04-24-2011, 09:41 AM   #100
ali_g's Avatar
anyone has a base setup for 4.5t motors with 211 software?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 04-24-2011, 11:39 AM   #101
Holmenkollen's Avatar
Try Tryhard┤s setup a couple of pages back. I used it today on a very large track with a SP 4.5t. Good power, low motor temps (60C) Air: 20C.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 04-24-2011, 02:13 PM   #102
chinaman's Avatar
Anyone got any setups for 1224? Thanks.
... wyrd bi­ ful ŃrŠd ...
chinaman is offline   Reply With Quote
Old 04-25-2011, 01:28 AM   #103
Monkeys punk's Avatar
Does anyone know if the extreme stock with fw211 can be programmed just on The speedo as I have lost my 2 in 1 box. The manual says it can but wasn't sure if the new functions on thus fw would be ok to do on the button only ?
Monkeys punk is offline   Reply With Quote
Old 04-25-2011, 04:16 AM   #104
xrayal's Avatar
the instructions say it can only be done via the lcd box.......... cherry will be at the stcc next week and i shall be at the btcc at wlrc, i have a brand new one also 3 brand new 13.5 motors
associated b5m
team c tm4
sanwa mt4
lrp flow tw
mardave
xrayal is offline   Reply With Quote
Old 04-25-2011, 11:04 AM   #105
ali_g's Avatar
i have tried with a x12 octa wind, 13mm rotor. loads of power, but motor temp is high bit at 90deg.
Which parts shld i tame it down?
☆ JU.C RACING ☆
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12534 Yesterday 08:31 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 10:43 PM
Help with hobbywing ESC setup RCveteran Radio and Electronics 19 01-15-2011 04:36 PM
Tags
esc, firmware, hobbywing, settings, xtreme
