Old 05-09-2017, 03:39 AM   #301
antlockyer's Avatar
Hi, I'm trying to get my XR10 pro setup for 13.5 boosted TC.
Can someone tell me the difference Auto vs RPM has on boost activation?
Option 2: Auto
In Auto mode, the ESC adjusts the Boost Timing dynamically as per the throttle amount. Only at full throttle, the actual Boost Timing is the value you had previously set.
I notice the 13.5 Open BL profile uses Auto, but most people I talk to use RPM. I did try auto once (by mistake) and it seemed to run a lot hotter on the motor.
antlockyer is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12544 10-09-2017 09:03 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 11:43 PM
Help with hobbywing ESC setup RCveteran Radio and Electronics 19 01-15-2011 05:36 PM
Tags
esc, firmware, hobbywing, settings, xtreme
