Old 01-15-2013, 12:26 PM   #256
AdrianM's Avatar
Originally Posted by Pulse_ View Post
Hello,
I just received two 1S HW 120A ESC.
Any help of settings on a 12th scale with a 10.5 with zero timing (blinky)? It's for an indoor carpet track that is small and technical. Here is a vid:
https://www.youtube.com/watch?v=6d4A7e1w9Xc
For now I didn't upgrade any software or anything.
You have to update the ESC firmware to "No Timing 508_V3" to get blinky mode. There are just a few settings for blinky.
Basic Tab
Run mode: Fwd Only w/Brake
Drag Brake: 0%
Low Voltage Cut: Disabled
DDRS Start Mode: 9 (great punch and fast race starts)
Max Brake Force: 100% (Blinky brakes are weak)
Advance Tab
Max Reverse Force: 100% (Related to brakes, high numbers hear increase brake strength)
Initial Brake Force: 0%
Heat Protection: Disabled (This disables the motor heat sensor)
Adrian Martinez
Old 01-18-2013, 11:10 AM   #257
Pulse_'s Avatar
Basic Tab
Drag Brake: 0%
Advance Tab
Thanks! Now I know with what to begin
https://www.youtube.com/channel/UC1CAwFfuz1K3chBSVpIlSew
Pulse_ is offline   Reply With Quote
Old 01-25-2013, 01:08 PM   #258
Hi guys,, this is my 1st post
I use ESC 120A V2.1,, already update to V3.0 Stock,, Turbo and Boost is open,,
My question,, can I use firmware 3.1 into ESC 120A V2.1 ??
coz V3.1 setting is more detail
any info please...
thx before
sorry my english is bad
cheatoz is offline   Reply With Quote
Old 01-25-2013, 02:29 PM   #259
idbdoug's Avatar
Trader Rating: 33 (100%+)
any info please...
thx before
According to website u can run latest Ver 3.2
idbdoug
idbdoug is offline   Reply With Quote
Old 01-25-2013, 02:38 PM   #260
ByteStream's Avatar
any info please...
thx before
If I understand your question correctly .. the answer is NO.
1. The picture on the left shows the options for the V2 line of ESC's.
2. The picture on the right shows the options for the V3 line of ESC's.
You can't get the software options of the V3 onto the V2 via software.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 01-25-2013, 03:30 PM   #261
Im pretty sure hes asking if he can use the V3.2 USB software on the v2.1 ESC which you can.
This is from the hobbywing website:
Hobbywing USB Link Software V3.2
Software Versions
Version 3.2_121204
The Version 3.2 is suitable for the following ESC:
XERUN Series*Car*ESC (Version 2.0/2.1/3.0/3.1*and later)
EZRUN Series* Car ESC (Version 2.0*and later)
PLATINUM Series helicopter/airplane ESC
SpecRC is offline   Reply With Quote
Old 01-25-2013, 03:43 PM   #262
ByteStream's Avatar
Old 01-25-2013, 03:45 PM   #263
ByteStream's Avatar
Software Versions
Version 3.2_121204
He is already using V3.2 USB Link from the pics he has .. look at the window title.
I believe he is asking if the "more detailed" software can be used on the V2.
The "more detailed" software is strictly for the V3.
The pic on the left is what you see when you connect a V2 to the PC.
The pic on the right is what you see when you connect a V3 to the PC.
The V3 has more options.
Old 01-25-2013, 06:08 PM   #264
idbdoug
I already use V3.2 USBLINK from web....
so it's mean v2.1 and v3.1 is different hardware ??
when i connect my esc to program box it show v3.0 stock
hopeless I can use setting v3.1 at my v2.1
my attachment show database for v2.1
Old 01-26-2013, 08:33 AM   #265
ByteStream's Avatar
Correct. The V2/V2.1 and the V3/V3.1 use different hardware.
Correct .. some of the software for the V2 ESC has the name v3.0_xxx. It is a little confusing to some.
You cannot .. those settings are for the V3 ESC, firmware v1.11_xxx which you cannot load onto a V2 ESC. You will only have that option in your Database if you connect a V3 ESC.
None of the software in that Database will give you the settings that a V3 ESC has. The V3/V3.1 ESC has more options and that is why some people buy it.
Old 01-26-2013, 08:37 AM   #266
Default Titc v3 setup
Hi guys...
I'll be going to race using v3 this February in titc rc addict on open brushless
Do you guys have a good setup for the v3 esc...I'm using 13,5 motor...
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 01-26-2013, 11:54 AM   #267
thx ByteStream.... now i'm understand....
hope next firmware from HW give ESC v2 more detail setting even though not like V3.1....
by the way,, can u give some advice which firmware best for esc v2,, i used it for drift at carpet
Old 01-26-2013, 08:55 PM   #268
Ah i see "click" very true
Old 01-30-2013, 07:08 AM   #269
Pulse_'s Avatar
Basic Tab
Drag Brake: 0%
Advance Tab
Finally I just installed the latest firmware as I don't have to run the 10.5 with zero timing considering there's no 1/12 race here anyway..
Now I need to choose a setting to start with considering I have the firmware v3.2 with access to all the settings
Old 01-30-2013, 04:37 PM   #270
Aravan's Avatar
Anybody got a good base setup for a 120A 1s with a D3.5 17.5t boosted in a 12th scale racing indoors? Guessing 930stock will be the best firmware to run?
Thanks.
Aravan Eagleheart
Corvictoria.com
//Schumacher: Cougar SVR, SV2, Cat K1//Losi SCTE 2.0//Kyosho SC-R SP//CRC XTi//
Aravan is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12542 Yesterday 08:11 PM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 10:43 PM
Help with hobbywing ESC setup RCveteran Radio and Electronics 19 01-15-2011 04:36 PM
Tags
esc, firmware, hobbywing, settings, xtreme
