Old 02-19-2012, 07:42 PM   #211
Default need advise on setup of hw xerun 120a 1s esc
trying to setup my esc for 1/12th pan car i am new to electric rc so i dont understand how to setup the speed control. most of the guys where i would be racing uses either tekin rs,rs pro or lrp so not getting any real help with setup i downloaded some firmware from hw site to the program box but not sure of what i was downloading. so this is what i got running a revtech 17.5 motor with i revtech 6200mah 70c 1s lipo the gearing i just put in to get the car rolling the stock spur gear for crc xi 72 and a 51 pinion. please help with setup. also how do i know if i have the proper updates in the program box for 17.5 motors.
thanks for any help
bigtee is offline   Reply With Quote
Old 02-20-2012, 04:01 PM   #212
thanks for any help
Hobbywing ESC Settings ONLY
It will get you close.
I am not familiar with the RevTech motor, but if you can, dial as much timing out of the motor has you can. Run a race, dont worry about the speed, then temp the motor. Keep adding timing in 5 deg increments, and until it the motor temp is around 140-160F. You will notice the car getting quicker. From there you can play with Roll out. Anywhere from a 80-90mm would be in the ball park.
I use the newest firmware (V3_930_Stock).
What Cherry2Blost youtube videos. (Check message #1 in this forum).
Shawn
Shawn68z is offline   Reply With Quote
Old 02-21-2012, 01:01 PM   #213
Default need help please using hw xerun 120a 1s lipo esc
thanks for any help
this is what i have when i plug in the usb into program box
pwr up v1.06_10052 2 in 1 program box
hw usb link V1.64
hdwr version hw310v1.0
software version v1.06_100512
choice versions v1.08_111007
v1.07_110119
v1.07_101224
v1.06_100512
this is what i have when i hook up the ecs to the program box via usb
Basic
profile/ mode no. mode 0
profile name. profile0_car0
run mode fwd only with brake
dragbrake 5%
low voltage cut off 3.0v
ddrs start mode level 6
max brake force 100%
advance
max brake force 50%
initial brake force 20%
neutral range 12%
over heat enable
turbo level 4
boost start rpm 3000
turbo open delay 0.1 sec
timing punch -6
software
device type car_esc
hdwr version hw427_v1.0
software version v2.0_100528mod
choice versions v3.0_110930_mod
v1.10_090205_mod
v3_508_no timing
v1_508_zero rev
v3.0_110930stock
v3.0_110119stock
v1.10_090323a_m
how do i know what versions to use, whats the profile of each version
what are you suppose to put in the box below the word state
Old 02-22-2012, 09:02 AM   #214
big_ads's Avatar
Trader Rating: 75 (100%+)
Send a message via MSN to big_ads
I apologize if this has been asked and answered already, but has someone run or can direct me to a post with a starting point for using a Duo 2 13.5 in 12th scale boosted?
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Team Genesis R/C Products - Motiv R/C - Big Head Racing - Team PRCP
big_ads is offline   Reply With Quote
Old 02-29-2012, 10:50 PM   #215
Smile HW Xtreme stock 21.5T
Hi
Just got my Reedy 21.5T, i guess i need help with the setup, the track is very small and very tech, outside i have a Xtreme stock esc , from what i have read people have stated the reedy is very smooth therefore i need punch, fdr 5-7?
i am running a 416X outof the box setup, my back ground is 540 and F1 running (you guessed it 540) any help would be great thanks
andy21.5T is offline   Reply With Quote
Old 03-01-2012, 09:36 AM   #216
Ads, just call the hotline brother!
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 03-08-2012, 03:45 AM   #217
Default 111011 software
has anyone been able to use the 111011 software i downloaded it and have been able to only use the 111007 software and help would be great before i race tonight which is in 6 hours.
cheers everyone
mavrickf1 is offline   Reply With Quote
Old 03-10-2012, 10:53 PM   #218
Still Bill's Avatar
Subscribe...So I don't have to keep calling Frank...LOL
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 03-25-2012, 03:29 PM   #219
FelixC's Avatar
Default settings
hi guys pls help ill be running 13.5 hobby wing esc where do i start? what do i set first the car fdr or the esc settings boost? timing? drs? etc. much appricated.
Karera na!!!
FelixC is offline   Reply With Quote
Old 03-25-2012, 05:13 PM   #220
Hate to be an a-hole here, but try doing a search in this thread. Or, start reading it from post #1. It wont take you long to find what you need.
Old 04-14-2012, 01:26 PM   #221
Hi guys
Running an xerun 120a in my Durango short course truck with a tekin pro4 3300kv. When I have the sensor wire connected, the car will only move when I push start it forward. Otherwise it does not respond to throttle input.
If I disconnect the sensor, then it drives normal, but feels like I lose the punch I'm used to.
Any thoughts?
slater333 is offline   Reply With Quote
Old 04-14-2012, 10:46 PM   #222
Originally Posted by slater333 View Post
Hi guys
Any thoughts?
Sounds like either a fault sensor board, or a faulty cable.. What version of the FW are you running? Some motors need to be running the newer 930 firmware.
Shawn
Old 05-03-2012, 06:05 AM   #223
Default setting help
hi all, i have got myself a team powers 13.5t plutonium motor does any one have a setting for this type of motor using the extreme or 120a esc, its racing indoors on a 24m x 14m track.
Old 05-03-2012, 10:34 PM   #224
murfy's Avatar
Trader Rating: 9 (92%+)
Hey all, looking for setup help with my new HW 120A v3 running 17.5 duo 3 boosted. The track is medium to small. Any tips?
Justin Murphy
Team Xray | Hudy | Hobbywing | Sanwa
murfy is offline   Reply With Quote
Old 05-05-2012, 08:54 AM   #225
nother track now, has anyone got a set for the TP13.5P with the HW extreme or 120a esc, for a 45 meter straight outdoor,
cheers
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12530 Today 08:09 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 10:43 PM
Help with hobbywing ESC setup RCveteran Radio and Electronics 19 01-15-2011 04:36 PM
Tags
esc, firmware, hobbywing, settings, xtreme
