Old 11-06-2011, 10:43 AM   #166
Originally Posted by peter george View Post
any body use the xerun 60A for twelve scale? gonna try to race it in 13.5 boosted class in a yokomo r12.Any set ups for 12 scale?
You can find my 17.5 boosted setup in this forum. Just lower your rollout to the 65-75mm range and you should be fine. Watch your temps though, in the first few runs. My motor comes off at 140F.
Hobbywing ESC Settings ONLY
Shawn.
Shawn68z is offline   Reply With Quote
Old 11-07-2011, 03:58 AM   #167
peter george's Avatar
Trader Rating: 328 (100%+)
Shawn.
thank you Shawn.
Team Underdog-Team UPURZ-Island Raceway & Hobby-If we trade lower feedback always ships first.#41-#18. Team Associated B6-B5m-CRC-Durango DEX210-DESC210-Intech-Tylenol
peter george is offline   Reply With Quote
Old 11-09-2011, 10:33 AM   #168
Default HOBBYWING XERUN Black V2 Brushless Motor 60A ESC SL963
Does this ESC work with 1S Li-Po?
In the specs I can't read that.
I want to use it in WGT with a 10.5T, EFRA-rules Europe.
Any setup available for that on this forum? (to start off with)
Kensei is offline   Reply With Quote
Old 11-09-2011, 11:38 AM   #169
The 60A is 2s-3S, the 120A is available in both 2s-3s and 1s-2s ( http://www.hobbywing.com/english/Pro...%28Sensored%29 )
The 1s-2s has a BEC booster, the other two don't have it, but work in 1s if you add an external BEC booster.
FFred is offline   Reply With Quote
Old 11-09-2011, 11:46 PM   #170
I looked at the website.
As I see it the only option then is the XERUN-120A-1S-SD (V2.1) Brushless ESC for 1/12 and 1/12 Car (Competitive Race)?
(a bit heavy: 105gr)
Old 11-10-2011, 03:12 AM   #171
WildManDriving's Avatar
Trader Rating: 29 (100%+)
Same old question but here it is again. What is the starting point for TC with 120Av2.1 / SP13.5v3 and 930 software on both a tight short tarmac track and a med length open course?
Michael
. . . - - - Now enjoying Proline tyres - - - . . .
Scale race models: RCHobbyzone, Mugen, Reds, Xpert, Contact, Neo+.
Toy cars: Xray T4'15, Hudy, Nosram/Muchmore, Protoform.
No longer defined as a Off or On-road racer, but simply a RC enthusiast.
WildManDriving is offline   Reply With Quote
Old 11-10-2011, 07:46 AM   #172
Michael
Go back a page to my orca setup.
Make sure the SP is fully advanced on the timing. Also, go lower on the FDR, maybe around 6.8??
Mb3195 is offline   Reply With Quote
Old 11-11-2011, 11:55 AM   #173
Default HW extreme stock
- can it be used with a 1S LiPo?
- what to use than with it, booster or RX pack?
- what software for this esc, in case of 1S LiPo?
- or just buy HW 120A 1S? (right software and no external booster or rx pack)
Old 12-07-2011, 01:07 AM   #174
Any suggested setups for a X12 17.5 motor running the V3 9030 stock software.
I use to run a SP V3 17.5 and got it running nicely, but I doubt the same settings will work with a X12 17.5 motor.
Thx.
SeanV is offline   Reply With Quote
Old 12-30-2011, 06:09 PM   #175
guinnes.s's Avatar
I have installed an 8.5t motor into a 1/10 ep 2wd buggy with an HW xstreme stock esc.
what software is best for this combo? at moment im using the 119stock with every setting to zero other then the boost at 35 but the esc get pretty hot.
any suggestions ?
thanx
guinnes.s is offline   Reply With Quote
Old 01-01-2012, 07:18 PM   #176
Darrin70's Avatar
Just run 508 zero timing software... If you want more, gear accordingly and add motor timing if it has it..
HYPERHOBBIES
YOKOMO
SKYRC
SWEEP RACING
SMC
Darrin70 is offline   Reply With Quote
Old 01-02-2012, 11:27 AM   #177
EpuL Leman's Avatar
Send a message via Yahoo to EpuL Leman
guys,
really need some help of best ESC setting for my setup below
ESC: Xerun 60a extreme
motor: team power 10.5t
ratio: 7.25
my track has 60m straight and return in technical corner.
current esc setting
Punch: 7
Neutral range 6
Start rpm 4000
Boost 38
Turbo 36
Turbo slope 12
Turbo delay 0.2
Timing acc 300
running in 5 minutes time around 60degC playing at night (24-26dC)
thanks in advance
If you are in a spaceship that is traveling at the speed of light, and you turn on the headlights, does anything happen?
{Steven Wright}
XRAY T3 | DSM DX3e | HW Xerun 60a Extreme | Team Power Plutonium 10.5T
EpuL Leman is offline   Reply With Quote
Old 01-02-2012, 12:01 PM   #178
scoyle's Avatar
First off sorry if this has been asked before...
I race at a track where I run 10th touring car on carpet with a 120a with pretty much everything maxxed with a ratio around 8.
I am going to try my hand at 12th using a 1s and I was wondering what settings people recommend for 10.5 and 6.5 motors.
Looking to understand what software I should use for each with the lower powered 3.7v battery etc.
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 01-02-2012, 01:48 PM   #179
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Thx.
FW: stock 119
1: 1
Drag Brake : 0%
Voltage Prot: 3.2 V/Cell
DRRS Punch :
Brake Force : 87.5%
REverse Force : 100%
Initial Brake : 0%
Neutral Range: 6%
Boost Timing : 25
Turbo Slope : 18
Turbo Timing : 25
Start RPM : 3000
Turbo Delay : 0.1 s
Timing ACC : 350
try something like this
Craig W is offline   Reply With Quote
Old 01-02-2012, 03:53 PM   #180
tmomedrano's Avatar
Default this is has been working...
is working for me for my x12 13.5
FW: latest
1: 1
Drag Brake : 0%
Voltage Prot: 3.0 V/Cell
DRRS Punch : 7
Brake Force : 100%
Initial Brake : 0%
Neutral Range: 6%
Boost Timing : 30
Turbo Slope : 12
Turbo Timing : 10
Start RPM : 5000
Turbo Delay : no delay
Timing ACC : 500
FDR 7.0 - keeping up on the straights yet smooth on the inside
[ Team Maxx Traxx ] http://iloveporrc.blogspot.com/ * http://timmedrano.com
tmomedrano is offline   Reply With Quote
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12534 07-19-2017 08:31 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 10:43 PM
Help with hobbywing ESC setup RCveteran Radio and Electronics 19 01-15-2011 04:36 PM
Tags
esc, firmware, hobbywing, settings, xtreme
