Old 08-20-2011, 03:07 PM   #151
Default Loading 119 mod onto the 35amp esc
has any one done this. Is it safe or will it blow?
scoop is offline   Reply With Quote
Old 08-22-2011, 07:07 AM   #152
After posting on other HW post, i find out that the front page (1) software are not (?) linked to the right program: V1.63 (1224) is loading as V1.63_110105 and does not have the software V3.0_101224 on it (which I am looking for)
Maybe all the links could be checked to make sure they are all working fine, then maybe I am looking for the wrong version/program but so far wasn't able to load what I am looking for.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 08-22-2011, 09:47 PM   #153
Groomie's Avatar
Default 17.5 setup
Hi All
Does anyone have a setup for 17.5 timed with a duo3 motor
The track im running at has a 50m long straight and a fairly flowing infield
any ideas would be muchly appreciated
Regards Groomie
WSRC open and ready to race
Check us out at
http://www.facebook.com/WesternSydneyRaceCentre
Groomie is offline   Reply With Quote
Old 08-23-2011, 01:24 AM   #154
After numerous tries, it appears that 224 version is not loading on my Window 7 from that link, but works fine on XP.
Old 08-23-2011, 01:44 PM   #155
As you can see from my rantings on the supercharged thread ive just got the HW usb link to work and i have 224 as an option!
How does 224 differ from 211?
Ive just read from a search that you cant upgrade an ezrun with another programme. Is this right?
Old 09-23-2011, 01:33 PM   #156
Just got the xtreme stock and looking for a starting point setup. Will be running touring, 13.5t HPI flux pro,high grip Carpet, tight but with 25-30m straight. Very heavy handed on the throttle.
As a safe starting point i was going to run
FDR 6.95
boost timing 36
turbo open 6/0.1
over heat on
turbo 24
boost start 9000rpm
Delay 0.3
boost acc 450
Anything anyone would suggest different and what should i be looking to change first or setup in what order?
Any help or suggestions appreciated.
YZFAndy is offline   Reply With Quote
Old 10-28-2011, 01:22 PM   #157
Default 13.5T TC Setup
hi all has anyone got a setup for the following
Teams powers 13.5T copper can motor
24 meter lenght track indoor
software on esc v3.0_110930 stock
setup so far
MOTOR: Teams powers 13.5T copper can
FDR: 6.9 on 64dp
F/W: 930
MOTOR TEMPS: 165F
RUNNING MODE: FORWARD/BRAKE
DRAG BRAKE: 5%
VOLTAGE PROTECT: 3.0v
DDRS: LEVEL 9
BRAKE FORCE: 100%
REVERSE FORCE: 100%
INITIAL BRAKE: Drag Brake
NEUTRAL RANGE: 6%
BOOST TIMING: 64
TURBO SLOPE: 18 UNITS/0.1 SEC
OVERHEAT PROTECT: ON
TURBO TIMING: 0
BOOST START RPM: 5000 RPM
TURBO DELAY: OFF
TIMING ACC/SLOPE: 500 RPM/UNIT
I can only about 0.5 sec of each lap of the leaders, i went round the track with them while racing and noticed that they get good pull of after slow corners.
Any help would be great thanks and good racing.
mavrick2k5 is offline   Reply With Quote
Old 11-04-2011, 07:56 AM   #158
yokemad's Avatar
Hi ALL
I'm looking for a Setup for ORCA RX2 13.5T motor +Xtreme Stock Speedo...
35x14mtr indoor Carpet Track
Thanx in Advance for any Help
yokemad is offline   Reply With Quote
Old 11-05-2011, 12:48 AM   #159
Originally Posted by yokemad View Post
Hi ALL
Awesome combo, use the same myself!
For/brake
Brake 87.5
Reverse 100
Neutral range 6
Start rpm 4000
Boost 48
Turbo 12
Turbo slope 18
Turbo delay 0.1
Timing acc 400
Punch 9
Fdr 7.87
Chck temps after 2 mins, if too hot increase timing acc to 450.
Mb3195 is offline   Reply With Quote
Old 11-05-2011, 12:51 AM   #160
setup so far
FDR: 6.9 on 64dp
F/W: 930
MOTOR TEMPS: 165F
DRAG BRAKE: 5%
DDRS: LEVEL 9
BRAKE FORCE: 100%
REVERSE FORCE: 100%
NEUTRAL RANGE: 6%
BOOST TIMING: 64
TURBO TIMING: 0
TURBO DELAY: OFF
Try the settings I just posted for the orca motor below. Your timing acc, start rpm and fdr are killing you out of the corners.
Make sure you check your temps!
Old 11-05-2011, 05:26 AM   #161
yokemad's Avatar
For/brake
Brake 87.5
Reverse 100
Neutral range 6
Start rpm 4000
Boost 48
Turbo 12
Turbo slope 18
Turbo delay 0.1
Timing acc 400
Punch 9
Fdr 7.87
Thanx Very Much Mate
Old 11-05-2011, 10:17 AM   #162
Hi ALL
I'm looking for a Setup for Trinity D3 17.5T motor +Xtreme Stock ESC
36x12mtr indoor Carpet Track on Sorex 28JB's
Thanks for any Help
Would these settings be any good?
For/brake
Brake 87.5
Reverse 100
Neutral range 6
Start rpm 4000
Boost 48
Turbo 12
Turbo slope 18
Turbo delay 0.1
Timing acc 400
Punch 9
Fdr 7.87
markrobinson is offline   Reply With Quote
Old 11-05-2011, 09:45 PM   #163
peter george's Avatar
Trader Rating: 323 (100%+)
any body use the xerun 60A for twelve scale? gonna try to race it in 13.5 boosted class in a yokomo r12.Any set ups for 12 scale?
Team Underdog-Team UPURZ-Island Raceway & Hobby-If we trade lower feedback always ships first.Team Associated B5m-CRC-Durango DEX210-DESC210-Intech-Eagles of Death Metal-Tylenol
peter george is offline   Reply With Quote
Old 11-06-2011, 12:03 AM   #164
Originally Posted by markrobinson View Post
Hi ALL
Thanks for any Help
For/brake
Brake 87.5
Reverse 100
Neutral range 6
Start rpm 4000
Boost 48
Turbo 12
Turbo slope 18
Turbo delay 0.1
Timing acc 400
Punch 9
Fdr 7.87
these look pretty good to me, not sure on the fdr with these motors as i understand they have a pretty small window. if you stick with these esc settings and mess about with the fdr you should get pretty close.
Old 11-06-2011, 07:52 AM   #165
OK Thanks
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12531 05-24-2017 01:41 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 10:43 PM
Help with hobbywing ESC setup RCveteran Radio and Electronics 19 01-15-2011 04:36 PM
Tags
esc, firmware, hobbywing, settings, xtreme
