Old 05-30-2011, 04:33 PM   #136
Originally Posted by drsmooth View Post
Well, I'm not really sure with the SS motors. The timing is changed by turning the colored ring & there's no timing marks. Not sure what's considered zero timing. So I just set it half way between. That might be zero, or advanced. I really would like to know where zero timing is on these motors.
Factory Timing
http://tinypic.com/r/o6dxza/7
Full Advanced
http://tinypic.com/r/33xykg1/7
Reduced Timing
http://tinypic.com/r/2mxzlg/7
Novak normally sets there motors for "30" degrees. But, I found when using their ballistic motors, going below "15" degrees, the motor starts to cog. So, I actually think their 30 might be closer to 15to20deg.
When I ran my WGT car yesterday, I had problems with my car being really slow, so I moved the timing ring to the fully reduced timing setting, and the car really picked up pace.
Shawn
Shawn68z is offline   Reply With Quote
Old 05-30-2011, 05:50 PM   #137
drsmooth's Avatar
Trader Rating: 33 (100%+)
Thanks shawn. That's what I thought. I'm running a turbo esc & my SS motors seem to like the timing in the middle.
Till next time.......
KEEP ON RACING!
drsmooth is offline   Reply With Quote
Old 06-07-2011, 04:47 PM   #138
So, I have been working with a CRC WGT car over the last couple of weeks, and I have been trying to figure out some speed. This following setup is not perfect, but its REALLY close. Very similar to my indoor setup, but I have a 13.5 motor, changed rollout, and bring the timing in at a higher rpm.
Old 06-08-2011, 10:30 PM   #139
cherry2blost's Avatar
Originally Posted by Darrin70 View Post
I got this one off a freind, told him there was no capacitor with it.. I have to get it from him but just wanted to test it with out one...Found the manual, does not explain anything about it..
Hi there we have both the original Caps and the newer upgraded caps in stock and will ship then to Canada for free if it helps.
http://www.racersinexile.org.uk/High...0_2750527.aspx
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 06-08-2011, 10:49 PM   #140
Default capacitors
will probably order one of these later, silly question but how do you connect them up? does the black simply go to the negative battery lead and the red to the positive? the instructions are poo!
Mb3195 is offline   Reply With Quote
Old 06-08-2011, 10:54 PM   #141
Yep absolutely correct, red to pos black to neg on ESC, don't do it to the wires do it direct to the solder tabs on the ESC to reduce resistance, best idea is if you have the room get the 4 part upgrade caps they just give more brakes, power and just feel much better.
Hope it helps
Old 06-25-2011, 02:00 PM   #142
That's a very good question the power caps are very important but there is no where on the instructions to say where to solder them on. I know most rc apt people would have an idea. But a novice could do some proper damage,and I think should be added even a separate slip off paper with instruction's how to connect the power caps on would be better than guessing.
big paul is offline   Reply With Quote
Old 06-29-2011, 12:44 PM   #143
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Originally Posted by defcone View Post
Any chance someone would have a x12 setup? (17.5t or 13.5t)
That what I need to for X12 13.5t 20x30mtr tight carpet track
Craig W is offline   Reply With Quote
Old 07-06-2011, 04:10 AM   #144
Back in the first few pages there are some good setups for the X12 13.5's
Old 07-06-2011, 10:23 AM   #145
Default corally pro red
any good set ups for a coally pro red 13.5t in a tc? medium sized indoor carpet track.
got a really good setup for a speedpassion now but i know the corally's are a different fish altogether!!
Old 07-12-2011, 10:17 AM   #146
TryHard's Avatar
Here's a copy of a "what USB link software gives what ESC software" file I've just made up. Useful as a quick reference!
HiH
Ed
Old 07-12-2011, 10:35 AM   #147
adri-13's Avatar
Hello,
Anyone can give-me a set-up for my speedo ( HW Xtremestock ) with a 10.5 motor ( GM #350 )?
I would like use it with boost timing...
regards,
Adrien Antomarchi.
PETITrc driver
www.PETITRC.com
http://rcracereportsigm-racing.blogspot.com/
adri-13 is offline   Reply With Quote
Old 07-19-2011, 04:44 PM   #148
auzzy_mate's Avatar
Default SC 13.5
Moved to offroad.
HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
auzzy_mate is offline   Reply With Quote
Old 08-06-2011, 12:47 PM   #149
Maxxican's Avatar
Trader Rating: 65 (100%+)
can i install software ver 1.508_No timming on a Extreme Stock 60A ESC without damaging it?
Will the ESC display a "blinky" light to show it is is Stock mode (no timing or boost)?
Carlos F.
RoadRunnersRC.com
RC AMERICA || XRAY || HUDY|| ACTIVRC || HOBBYWING NA || PROTOFORM
Maxxican is offline   Reply With Quote
Old 08-15-2011, 06:41 AM   #150
auzzy_mate's Avatar
Default 12th scale + 120a 1S + 4.5t
I just put a new 120a 1S HW ESC into my 12th scale pan car and attached it to a Speed Passion 4.5 (v3).
Do I need to update the ESC before I run it, or will it be okay for the mod motor right away?
NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE COBRARACING Radio and Electronics 12535 07-24-2017 08:53 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 10:43 PM
Help with hobbywing ESC setup RCveteran Radio and Electronics 19 01-15-2011 04:36 PM
Tags
esc, firmware, hobbywing, settings, xtreme
