Old 03-29-2011, 07:05 PM   #1
daign's Avatar
Default What chassis's have a 275mm long wheelbase
Its worth it. I've been looking for hours for a car with that wheelbase.
If I cant find a chassis, how would a direct drive single shock chassis like this do nowadays with some power?
daign is offline   Reply With Quote
Old 03-29-2011, 07:20 PM   #2
Well the chassis you have pictured is an old Tamiya road car chassis (probably a Ferrari body of some type) based off of the F101/F102 F1 chassis. I believe the tub chassis car had the same wheel base as the F101/F102 which has the same wheel base as the F103...though I'm not sure that it is 275mm specifically. As for putting power in a direct drive car...Like any car that all depends on how much traction there is. If you have a lot of grip a direct drive car will handle it no problem. If grip is really low then a 4wd chassis will be easier to control. However that brings up another issue...I assume you have a 275mm body that you want to get a chassis for. You also need to take in account the size of the tires and rims the body is designed for as these will play a part in how well the body fits and looks on the chassis. If the body is made for the chassis you have pictured then the wheels and tires of a 4wd TC are likely to be too big and you might have to butcher the body to get it to fit.
Old 03-30-2011, 05:22 PM   #3
If you need something that's normal touring car size but with a 275mm wheelbase, the nearest will be the Tamiya Porsche Cayenne, kit number 58406, the wheelbase is 280mm but it should be easy with a bit of trimming to move the wishbones in to get the right wheelbase. It is 200mm wide.
If you fancy using a pan car chassis like you have posted, then the latest Tamiya F104 has a 270mm wheelbase, anything else would need to be modified to lengthen them to fit the body. as for "some power", if you are looking at running a powerful motor in a pan car you are better off getting a proper WorldGT car and extending the chassis to lengthen it, even so you will still find it difficult to get it to accelerate in a straight line if it isn't run on a prepared surface.
terry.sc is offline   Reply With Quote
Old 04-03-2011, 03:18 AM   #4
The discontinued HPI Super RS4 cars (electric, nitro and rally versions) had a 280mm wheelbase, but it would be very hard to find one of these now though.
majatra is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19920 04-03-2013 08:30 AM
SEO by vBSEO 3.5.0
