Old 09-06-2004, 10:05 PM   #1
AMainJay's Avatar
Send a message via AIM to AMainJay
Default 19 Turn Motor Questions and Opinions
Hey guys, I want to know what 19turn motors you guys are finding to be the Fastest as more and more companies make them. Any info would be appreciated, also can u name the characeristics of that motor. For example (High RPM, or Alot of Torque etc...works good with 766's ect....) and what base gear ratio you guys are running with it. The last thing is what brushes for that particular motor are people using. Thanks
The reason is im starting to get into 19 turn racing and just curious what to get first. and how to gear it.
Thanks in advanced nephews and nieces
I am Julian
"Look, are you gonna listen or no?"
-Alex Navarette
AMainJay is offline   Reply With Quote
Old 09-06-2004, 10:15 PM   #2
Depends what you're using the 19t for. I'm racing in a 19t class which permits adjustable timing rather than a tagged endbell.
I've found the new Trinity Ultra Bird to be really good geared to about 6.0 in a Touring Car (Losi XXX's) on an asphalt surface. The Ultra Bird comes with P94 4383 Trinity brushes.
I recently purchased a Team Paradigm 19t and a BTX (uses a D6 can) but I haven't tested these motors yet.
I set the endbell to 24 degrees which is the same as if it was tagged
AlanC is offline   Reply With Quote
Old 09-06-2004, 11:30 PM   #3
Tamiya TA04
Trinity Chameleon Pro 2 19T ROAR Legal (Locked Timing)
Pinion Tamiya 44T, Spur Tamiya 120T or Robinson Racing 96 Spur and 35 Pinion
GT7 ESC set to Aggessive Stock
Use Red Springs on Positive and Green on Negative.
Trinity 4504 Brushess.......the 4505 are also good but heavy on the comm....the 4504 have less silver content
My final ratio is (120/44*2.13) = 5.81 and (96/35*2.13) = 5.84
I use Robinson gears because the original Tamiya 64p spurs are soft and gets eaten up after about two races. This is how powerful the Chameleon is. Gear the motor as you would a 27T and then go up 3 teeth on the pinion.
hope it helps
Punkynutt is offline   Reply With Quote
i was looking for warp4 2 turn motor. instead i bought a ALIGN 430L motor rasserie Singapore R/C Racers 8 10-24-2008 10:14 PM
Your opinions on the fastest brushed motor Rapid Roy Micro and Mini Scales 8 01-28-2008 04:29 AM
opinions on new motor choice clebo3 Nitro Off-Road 33 12-05-2007 03:34 PM
Whats the fastest 19 turn and 27 turn stock motor? adr3naline fix Electric On-Road 104 08-26-2005 10:03 PM
Opinions on favorite motor builders? polesitter61 Electric On-Road 57 03-25-2005 10:55 AM
SEO by vBSEO 3.5.0
