Old 04-03-2011, 06:57 PM   #16
Originally Posted by Monkeys punk View Post
I have a temp sensor on mine running off my Spektrum DX3s and with 5.5 1s its hitting 65deg after 8mins but what is the max they will handle before they thermal ? If i know I can set my warning on my tranny.
Around 110 celsius (230F) in my experience. It will give you a warning it's about to thermal by slowing down and cutting power to the motor intermittently.
spongerX is offline   Reply With Quote
Old 04-05-2011, 06:25 AM   #17
Monkeys punk's Avatar
Cheers mate just wanted to check I wasn't pushing it to high but 65 in fine I guess.
Monkeys punk is offline   Reply With Quote
Old 06-29-2011, 02:30 PM   #18
Kingy 009's Avatar
Originally Posted by tjfmuk View Post
Hi, I am running a Tekin RS Pro with an Nosram 3.5 T PURE Evo BL Modified motor, with Spektrum DX3s
Problem: When I run for about 10 mins the car fails to respond to my radio signal, all the LEDS are flashing. I assume and read that it is a problem with overheating and not a binding issue.
The question I have is, how do I make it run cooler? Either without buying new stuff (prefered, obviously) or buying a higher turn motor, or buying something that would help, cheers.
Hey mate,
I have run a 2.5tekin motor with my car and it got warm very quickly and had no problems. But I never run for more than 6min. I would say with a 3.5 turn motor the battery would of been flat or almost flat after ten minutes and I believe that could of been your issue why you had no response. Lipo cutoff The tekin still gets power but doesn't put out power to the motor.
BRG Racing, XRAY T2
Dragrace concepts side winder
Kingy 009 is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Any TIPS on soldering up a TEKIN RS Pro?? intron Electric Off-Road 26 10-16-2010 01:07 PM
HELP: Mod 4wd, tekin rs pro, SP 7.5R... it's stock slow.. teeforb Electric Off-Road 23 09-22-2010 11:21 AM
TEKIN RS PRO QUESTION??? bluebon88 Radio and Electronics 8 09-20-2010 10:39 PM
SEO by vBSEO 3.5.0
