Old 09-09-2011, 09:48 PM   #46
Send a message via Skype™ to flyfish
Every F-1 fan desire to have one,I guess.
flyfish is offline   Reply With Quote
Old 09-10-2011, 10:13 AM   #47
njt
njt's Avatar
Originally Posted by CFR View Post
I'm looking into getting one also
Would like to see Cartman's AE side damper mod also
Here is the shock mod,
njt is offline   Reply With Quote
Old 09-10-2011, 08:36 PM   #48
CFR
CFR's Avatar
could you do a close up of each end to show how it's attached please
Spur Gears
do the kimbrough ones fit or do you have to use WRC items?
CFR is offline   Reply With Quote
Old 09-11-2011, 09:49 AM   #49
njt
njt's Avatar
Left side / right side of roll center shock and that is a custom made mount to suit the roll center shock and the main damper also
I use what ever the model shop has in stock A/E, Kawada , sometimes you have to use the bush of a f-109 spur to suit
The kit spur is ok also it has a bearing built in
WRC Racing F-One-mk-2-roll-centre-shocker-rc12r-.jpg   WRC Racing F-One-roll-center-shock-mk2-mototr-side-.jpg
Old 09-11-2011, 10:05 AM   #50
CFR
CFR's Avatar
thanks for the pictures
what oil weight are you using in the roll shock?
Old 09-11-2011, 03:37 PM   #51
njt
njt's Avatar
30wt oil. do you have one of these F-ONE ? or are you thinking of getting one ?
Team Powers UK are the agents
http://www.team-powers.co.uk/index.p...tegory&path=50
Old 09-11-2011, 04:28 PM   #52
CFR
CFR's Avatar
thinking, just asking lots of questions before taking the plunge
emailed TPUK a few days back, waiting on reply
Old 09-13-2011, 08:45 AM   #53
CFR
CFR's Avatar
Are you running the WRC foams, if so which compounds/shore?
or are you using other brands, which one's & compounds/shore?
Old 09-13-2011, 11:47 AM   #54
njt
njt's Avatar
Currently I'm running the F-ONE on WRC foams
front 40 shore and rear 28 shore , I have completed over 200 laps at my local club for the loss of 2mm off the diameter, so wear rate is excellent.
Have Team Powers been back in touch ?
Old 09-13-2011, 12:06 PM   #55
JamesHealey's Avatar
Whats the diameter and width of these WRC foams? and do they have the standard 12mm hex mount holes?
JamesHealey is offline   Reply With Quote
Old 09-13-2011, 12:49 PM   #56
CFR
CFR's Avatar
Is that on Silver Can & LiPo?
Yes thanks
Now need to decide if it's worth the extra cash over the F One '0' Nines etc
Old 09-13-2011, 12:50 PM   #57
CFR
CFR's Avatar
Hex yes
Width, no idea
Old 09-13-2011, 01:15 PM   #58
njt
njt's Avatar
Rear tyre - diameter 60mm ,width 43mm, wheel diameter 38mm
Front tyre - diameter 60mm , width 29m , wheel diameter 38mm
14mm hex
2 cell lipo and Team Powers 21.5 motor
Old 09-13-2011, 02:19 PM   #59
Send a message via ICQ to Cartman
nick cfr is glen from rcracechat, glen njt is nick t front rcracechat if you dont know
Cartman is offline   Reply With Quote
Old 09-13-2011, 02:23 PM   #60
nick did his same as mine glen
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12644 01-20-2017 08:56 AM
European 2wd 1/8th pan car on-road Classic class djmachinist Nitro On-Road 4192 01-09-2017 05:19 AM
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
Change the Hobby for the Better - TODAY - FreqETag Electric On-Road 225 11-10-2009 08:54 PM
SEO by vBSEO 3.5.0
