Like Tree4Likes
Old 05-06-2017, 11:37 AM   #226
Regional Moderator
disaster999's Avatar
What are your track temperatures right now? I find the GR tires work much better with warmer weather. They also need to be broken in as well. Its too bad you guys cant sauce the tires, can you heat them up tho? wouldnt hurt to heat them up a bit.
I THINK Im running 6degree caster on my car, that seem to work well. As Ive said before, moving the steering linkage to the front 2 holes made my car extremely twitchy down the straight to the point of undriveable. But my car have come a long way since then. Doesnt hurt to play with the ackerman and see if that helps with more steering.
Im using the stock front springs and it works pretty well on my track. Its just a general rule of thumb if the car isnt turning enough, you use softer front springs to get more steering.
Ive changed my side springs to the hardest WRC offers and it seem to work for me. Im not sensitive enough to actually tell the difference between medium or hard tho. One thing for sure, if i increase the preload on the side springs, it helped a lot with handling. To me, I think the preload helps the rear pod to return to center. You really need to spend some time experimenting with setting. It took me a while but my car is dialed right now.
Heres my car with GR tires, stock front springs, hard side springs, track surface temp is around 28c.
+ YouTube Video
disaster999 is offline   Reply With Quote
Old 05-06-2017, 11:47 AM   #227
jpx
jpx's Avatar
Looks quite good! Definitely more steering than I have had racing last weekend.
We may heat up our tires and thats what all of us did!
Don't know about the exact track temp. but air wasn't more than 17 and only very little sunny times so track might have been quote similar
I'll have to see, what changes I can check out untill the next race.
I don't whant to hurry and will pnly make one chane after the other and then live with the best I can do untill the next race.
AE TC7 / 17.5T blinky GT
WRC f-one '016 / 21.5T F1
jpx is offline   Reply With Quote
Old 05-08-2017, 06:55 PM   #228
Regional Moderator
If that was your first time out with the tires you might need a few runs in them to break them in. I generally sauce them once the first time on the track and after the rubber breaks in, I dont feel the need to sauce them again. I can just drop the car on the track, drive a lap or 2 to get some heat in the tires and they hook up.
17c air temp seemed a bit cold, I havent tried them that cold, but I believe if they are broken in they should hook up pretty well.
Old 05-13-2017, 07:27 AM   #229
jpx
jpx's Avatar
Because it's raining, there's no oportunity for testing until tomorrow.
So I spent the time installing a blinking tail light
Old 05-13-2017, 12:09 PM   #230
What are gearing options for both 21.5 and 25.5
We run 21 outdoors and 25 indoors so would need gearing for both tia
Felix v.
Ae sc10.2, xray t4 2016 usgt,wrc f-one 016, Tamiya m05 mini
Expensive is not always faster
Scionara05 is offline   Reply With Quote
Old 05-13-2017, 07:51 PM   #231
Regional Moderator
Depends how big your track is, I was running 84/44 in the video
Old 05-14-2017, 05:38 AM   #232
Indoors is 15 by 55 and outdoors will be about the same
The indoor track is where roar carpet nats was held this year and outdoors is Jackson RC raceway
Felix v.
Old 05-14-2017, 10:13 AM   #233
Regional Moderator
15x55 what? ft? yard? m?
I assume its not in ft as that sounds way to small. Yards or meters is more reasonable and its slightly smaller than the track you saw on my video. Try 2.0 first and see if that works and work your way up or down from there
Old 05-14-2017, 05:59 PM   #234
Sorry 115x55
My phone didn't register a 1
Felix v.
Old 05-17-2017, 02:04 PM   #235
jpx
jpx's Avatar
I had my second F1 race last sunday.
Quite happy with the car.
Changed caster from 3 to 6 and moved 35g approx. 4cm forward (just behind the servo).
Definitely less understeer than before but the rear end was still planted.
Some understeer when going off throttle into a fast corner after the longest straight - mayby only when I was too fast because of lifting the throttle too late ...
But car was still ease to drive so for me that's a good point to continue improving my driving.
For anyone who might be interested find my current setup below.
Maybe not agressive enough for a good driver but for me a solid basis being new to F1.
File Type: pdf F-One016_jpx_Althengstett_MCSS-Cup#2_170514_.pdf (485.7 KB, 23 views)
Scionara05 likes this.
Old 05-19-2017, 08:25 PM   #236
Indoor high bite black CRC carpet any setups for that or am I SOL and testing on my own lol
Felix v.
Old 05-20-2017, 04:11 AM   #237
Ph3nyx's Avatar
F-One 017 Build video
+ YouTube Video
Unboxing video (in french)
+ YouTube Video
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 05-21-2017, 10:10 AM   #238
What springs can be used on this car from and sides I know I can use x-ray for center
Felix v.
Old 05-21-2017, 12:55 PM   #239
jpx
jpx's Avatar
Sure you might use several brands - all I can tell is I'm using Tamiya front and side springs:
Roll spring set Tamiya #54352
> copper - silver - gold - black (with silver and gold to be quite close to each other)
Front spring set Tamiya #50509
Old 05-21-2017, 02:14 PM   #240
Thank you for the quick response will x-ray side and front springs work only reason being is that I'm in the states and parts support is almost none will be able to get x-ray springs and are fairly quickly at hobby shops local as for breakables I will be at the mercy of snail mail from Florida from Wallace motorsports
Felix v.
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13567 Today 01:28 PM
European 2wd 1/8th pan car on-road Classic class djmachinist Nitro On-Road 4197 07-24-2017 11:50 PM
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-24-2015 11:28 PM
Change the Hobby for the Better - TODAY - FreqETag Electric On-Road 225 11-10-2009 07:54 PM
