Like Tree4Likes
Old 02-13-2017, 06:00 PM   #196
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Originally Posted by rhodopsine View Post
Don't know... was just stating what I found in 20+ years of pan car racing...
Martin Paradis
For foam that might be the case although I've run 1/12th scale on and off for almost 30 and never ran toe out. Toe out on rubber tire cars makes them twitchy.
BP SHADOW is offline   Reply With Quote
Old 02-13-2017, 06:06 PM   #197
Regional Moderator
disaster999's Avatar
Originally Posted by Test Driver View Post
I run upwards of 3deg toe out on the front to stop mine being so sensitive to steering input at speed. Doesn't necessarily sound logical but it does work.
+1 to that! Seems counterintuitive as most setup guide will tell you the other way around (toe in for straight line stability...) but my experience with pan cars, both oval and road course, has been that toe out makes the car more stable on straight line.
Martin Paradis
Yeah it does sound illogical at first. All setup guides say toe in would make the car more stable on the straights but difficult on turn in and toe out is exactly the opposite. Doesnt hurt to try I guess. Its a simple setup change.
Originally Posted by BP SHADOW View Post
Try adding 1-2mm of front droop
How much droop do you have in the rear pod? Should only be 1-1.5mm
Go softer on the center spring
Reduce camber to -1 or less
Take some caster out
Also add some - expo in your radio to desensitize the steering
I do have some droop both front and rear. I didnt really measure it tho but around 1-2mm looks about right with the stock springs
Ill try a reduced camber and caster and see how that works out. Thing is I have a similar setup on my other F1 and that car handled like its on rails. The WRC with a similar setup is all over the place down the straight.
Ill try some negative expo on the steering as well.
Thanks for the tips guys
disaster999 is offline   Reply With Quote
Old 02-13-2017, 06:23 PM   #198
BP SHADOW's Avatar
Also what is your shock angle like?
The more angled the shock is the more sensitive the steering will be. The shock height and angle are very much like the rear roll center for the chassis
Old 02-13-2017, 06:28 PM   #199
Regional Moderator
I took out one shim on the rear to lay the shock down a bit more from stock since it I feel like it was too angled. Ill start taking out more to lay the shock more and see if that helps.
Old 02-14-2017, 01:24 AM   #200
Test Driver's Avatar
Don't know about foam tires and toe in/out but for my f-one 2014 and my f-one 2016 on rubber tires I definitely need a fair bit of toe out to make it less twitchy and stable at speed.
My suggestion is to try it yourself. It's an easy setup changeable makes a huge difference.
Test Driver is offline   Reply With Quote
Old 02-14-2017, 06:23 AM   #201
Regional Moderator
Doesnt hurt to try, just a few turns on the turnbuckle anyways.
Did you have the problem where the F1 fishtail uncontrollably down the straight when you give it a little steering input?
Old 02-15-2017, 11:16 AM   #202
And more. The car would fishtail a couple of times then spin. Just felt like someone turned full lock at speed.
Old 02-15-2017, 07:24 PM   #203
Regional Moderator
Yeah I had exactly the same problem with my WRC F1. Steering adjustment down the straight will lead to uncontrollable fishtailing and ultimately spinning into a wall.
Which ackermann angle did you use, forward or backward mounting holes?
Old 02-15-2017, 10:06 PM   #204
With the 2014, I would change it depending on track. (I race on outdoor asphalt). My new 2016 I am still working on what feels right for me.
Old 02-15-2017, 10:28 PM   #205
Regional Moderator
Ah alright, Im running my 2016 on asphalt too. The setup has a long way to go compared to my Exotek F1R3
Old 02-16-2017, 09:57 AM   #206
billjacobs's Avatar
Trader Rating: 53 (100%+)
Default fishtailing
i have the f-one and because of the design, the front end has a lot of flex. If you have fishtailing and stability issues, I would run max caster, hard front springs, soft rear shock and side springs, 0 or -.5 front camber, and a harder front tire to limit the front end grip. You should also make sure the rear pod is free and not binding.
Current racing stable: xb4, sct410.3, b6, t5, t3 '12, x1, MGT7 :: Sponsored by my day job.
billjacobs is offline   Reply With Quote
Old 02-18-2017, 08:33 AM   #207
jpx
jpx's Avatar
Racing on asphalt:
is 5mm ride hight front and rear the way to go?
AE TC7 / 17.5T blinky GT
WRC f-one '016 / 21.5T F1
jpx is offline   Reply With Quote
Old 02-18-2017, 08:51 AM   #208
BP SHADOW's Avatar
Originally Posted by jpx View Post
Racing on asphalt:
That would depend on the surface and amount of bite. I would definitely run a softer setup, let the chassis roll more to create grip. Ride height would really come down to how bumpy the track is and how much suspension travel is needed
Old 02-23-2017, 11:00 AM   #209
jpx
jpx's Avatar
Sure you're absolutely right.
But still I need a good starting point for my first time out with an F1 on asphalt.
Track has some little bumps.
Old 02-23-2017, 03:08 PM   #210
I run between 4-5mm myself.
Track as some little bumps.
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13562 Yesterday 09:24 PM
European 2wd 1/8th pan car on-road Classic class djmachinist Nitro On-Road 4197 07-24-2017 11:50 PM
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-24-2015 11:28 PM
Change the Hobby for the Better - TODAY - FreqETag Electric On-Road 225 11-10-2009 07:54 PM
