Like Tree4Likes
Old 03-14-2014, 05:18 PM   #151
Airwave's Avatar
http://www.rc-pro-shop.com/fr/23-wrc-f-one ^^
Airwave is offline   Reply With Quote
Old 11-20-2014, 07:54 AM   #152
Conrad's Avatar
Could someone remove a front wheel and measure the height (top to bottom) on the front kingpin mounted on the car with wishbones and hub in place. Cheers.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 11-20-2014, 11:38 PM   #153
Ciao Conrad,
if i understood correctly you'll like to know how many mm the king pin extrude fromthe lower bottom arm.
If i'm not wrong it should be a couple of mm. however i'll check this evening and i'll confirm you.
Which model do you use???
Ciao
Max
Touring: WRC STX
F1: WRC F-ONE 200 and 180 mm
ESC:Viper VTX10R; Motor: too many; Radio: Sanwa MT4
Don't follow me.... at the end of the straight there is the hairpin and my wall.....
mtaddei is offline   Reply With Quote
Old 11-21-2014, 06:00 AM   #154
Conrad's Avatar
I'm looking for the total length of the kingpin, I'm looking to use some of these parts on a project car and need to know if it will fit inside the wheel with enough clearance for suspension movement.
Old 02-15-2015, 02:11 AM   #155
Any Australian or Asian retailers for this chassis? From the website it looks like this part of the world is not covered very well...
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 03-26-2015, 08:32 AM   #156
The WRC F-One '014 looks very good to me - one of the better F1 designs I think.
TC(17.5) - USGT - F1(21.5) - 12th(17.5) - USGT(FWD) - VTA
--MTC1----T4'17----X1'15-------X12'17-------FF17--------TA07
DavidNERODease is online now   Reply With Quote
Old 05-09-2015, 09:10 AM   #157
Tony Vredenberg will be driving the WRC F-One Formula 1 kit from the Italian company for WRC and The-Border in upcoming F1 races.
Because of that, he’s build the WRC F-One kit and we’ve made some pictures of it since there aren’t a lot of closeup pictures on the internet yet of the car.
After having seen the build kit up close, you can’t deny the spectacular engineering and design feats of this car: the dual servo arm system is beautiful and very tightly constructed which makes the car great to drive.
The very beautiful matte finish on the carbon gives this already luxurious car an even more luxurious feeling, all parts are beautifully machines. You can see the dedication in the smallest details such as the king pins which have been CNC machines from large blocks as to create a ultra thin integrated edge so there’s no need for any C-Clips on the king pins.
The heightened front end and short main chassis is a system that hasn’t been seen before in F1 together with the dual servo arm system which both seem to work out great for the car.
The front arms have an engraved ‘180’ on top, indicating that this is the 180mm front end. WRC offers a separate front end for the car in to upgrade the front end to an 200mm F1 car, creating an even wider front end for more stability and grip.
Thaan is offline   Reply With Quote
Old 05-12-2015, 02:42 AM   #158
Test Driver's Avatar
Does anyone have a setup for the F-One '014 for out doors asphalt. medium grip level. flowing layout. track temp probably around 30 deg Celcius.
thanks
SSE - SmallScaleEngineering
DASH-1
1/12 scale Eurostock
Test Driver is offline   Reply With Quote
Old 05-13-2015, 02:35 AM   #159
thanks
This is the setup sheet from the manual, already filled in:
Setup Sheet WRC F-One '014
I'm currently in contact with WRC to obtain an empty setup sheet.
Old 05-13-2015, 02:57 AM   #160
thanks. What motor do you guys run? 17.5t or 21.5t or another?
DASH-1
Old 05-13-2015, 05:36 AM   #161
21.5T, the blue Hobbywing (that's the motor you can see in the pictures).
We'll be present with the WRC F-One '014 at the ETS in Slovakia.
We didn't fill in that setup sheet though, WRC did.
Old 05-13-2015, 07:44 PM   #162
thanks. Yeah, just checking to see if the gearing spec'd is for 21.5t or faster motor. We run 21.5t mostly here in Australia. (some clubs run 17.5T)
DASH-1
Old 05-14-2015, 07:14 AM   #163
Here is an empty setup sheet for you to use!
WRC F-One '014 empty setup sheet.
Old 04-11-2016, 08:58 AM   #164
cardinal's Avatar
Hi everyone!
Has anyone ever built/ran the 2016 version of the WRC F-One?
Team Associated | Mugen | HoBao | Kyosho | MST | Traxxas | Tamiya | Hobbywing | Trinity | SMC | JConcepts | AKA | Sweep | Sanwa
cardinal is offline   Reply With Quote
Old 04-11-2016, 11:14 AM   #165
Originally Posted by cardinal View Post
Hi everyone!
There's quite a lot of them around actually, the 2016 is quite popular, just not many of those drivers are here on the forum.
Daniele Ielasi drove it in the last ETS RD3 & last year, 2 WRC's from The Netherlands drove the ETS in Slovakia at the Hudy Arena.
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13562 08-15-2017 09:24 PM
European 2wd 1/8th pan car on-road Classic class djmachinist Nitro On-Road 4197 07-24-2017 11:50 PM
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-24-2015 11:28 PM
Change the Hobby for the Better - TODAY - FreqETag Electric On-Road 225 11-10-2009 07:54 PM
