M8
Has anyone modified their M8 so that the third channel can be used in oval to get full servo travel when the dual rate is turned low? Such as some Futaba radios can be programmed.
:confused: |
Why would the third channel be needed to do this? On the 3pk only one channel is used and you can set it so that the lap counter button (well at least one of it's most common uses) can be used to get full steering travel either only when you hold it down or it gets full travel after you press until you press it again. As far as I know the M8 doesnt have any buttons that are easily accessable like the one on the 3pk and I dont think the M8 has any programmable buttons either. I dont think the M8 has second dual rate (that's what it's called) either so you would have to find some way to change the dual rate and then change it back quickly, as far as I know it doesnt have any thumb dials so you couldnt do that either. I can't see how you would modify it without adding buttons or dials and reprograming it.
