Faster corner speed like pro
#391
Softer is NOT always Better
Cole Trickle;
I have noticed the same thing over the years when tuning. Sometimes, a slightly stiffer spring all around will provide better grip than going to a softer set-up (as opposed to what is currently in the car).
I've had this happen only a few times and I think it is only certain Tire and Track conditions that require it. A very slight change in Temperature and your back to your base set-up.
For the Rear coming around in your P-2, try less static Camber in the Rear (0.0-0.5) and/or 1 or 2mm more Rear Droop. This is a common problem with the HPI cars and these two things should help.
#392
Thanks Popsracer.
But what is the effect on the car when limiting uptravel beside flipping over when driveing over a corner dot.
-Whacky.
-Whacky.
#393
I'd had that problem with my TC3 out at Camarillo (medium bite) and, after talking with Hubbard, who's care was hooked up, he told me that the reason for that problem was that the car was moving too much weight rearward too quickly. . .
(mid corner, off-brake and on-throttle - oversteer)
To fix that he upped the oil-weight all the way around - the oil only changes the RATE of weight transfer, not the amount. That fixed his problem.
Unfortunately for me, I didn't ask until way too late in the game. . .
#394
limiting uptravel
Originally posted by Whacky
Thanks Popsracer.
Thanks Popsracer.
Whacky;
You will be limiting chassis roll with the screws/spacers while still using the same springs to get the grip you need. At the time I tried it, I was racing on a small permanent Track and didn't like the fact that the slightest touch of a corner dot would send you over on your lid. The Car seemed to be "Bouncey" also, like the springs were too stiff and the oil was too thin.
I wouldn't recommend it unless you are running on a large permanent racetrack with gobs of traction and you can avoid the corner dots completely.
Boomer;
What amount of oil weight change did 'Hubbard' recommend to correct the mid corner problem?
#395
Thanks popsracer!.
-Whacky.
-Whacky.
#396
Re: Softer is NOT always Better
Originally posted by popsracer
Cole Trickle;
Cole Trickle;
About camber, I've already reduced the rear camber. But maybe I should reduce even more (havent measured it yet, I dont got a setup system, so I use the system in our club). I was also thinking about increasing the rear droop.
I look forward to the sunday race, it's my biggest race so far. My equipment are in a good shape, and I only need to do some minor preparations. So I try to focus on mental preparations.
Today I was at a seminar. There was something about training top sportsmen. It was not the main topic, but there was several tricks, that I think I can use. Exciting.
#397
Cole Trickle;
I would recommend NOT making any radical changes to your set-up, if you have a BIG race coming up. Do the changes when you have plenty of time in practice to evaluate them properly.
The Integy (Team Atlas) Set-up system in only $65 usd, that's about $40 cheaper than the Hudy and I think it works just as good.
What ever you decide on Camber, use a Set-up to check it with or some set-up Disc's with an RPM Camber gauge.
Almost forgot, Good luck on your Race!
#398
Re: Faster corner speed like pro
#399
#400
Re: limiting uptravel
Boomer
Boomer
#401
Re: Re: limiting uptravel
I was running (and he had started with) 30wt Assoc oil. He moved to 40wt so it wasn't a huge step, I would say it was about the equivalent of one spring step, maybe two.
#402
ttt
#403
ttt
#404
Thanks.
