Old 09-04-2004, 07:29 PM   #46
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
The "matching" feature on the LRP is a cycling feature. It's similar to what there is on the GFX but the problem is that the numbers are misleading that it gives you because it's only done at the 10 amp discharge. Now if you cycle a pack on it when it's new, note what numbers you get, then cycle it on the same charger in a couple months, it can give you an idea as to what your packs are doing by comparing nubers. As long as you charge at the same rate with the same threshold settings as well. Everything needs to be equal.
Jon Kerr is offline   Reply With Quote
robitronic equalising tray help minnesh Rookie Zone 2 06-24-2007 08:45 AM
Pulse vs Linear DISCHARGING (also vs Multi-step discharging) akuhon Electric On-Road 5 01-01-2007 10:58 PM
help with discaharging and equalising top-timm Electric On-Road 4 12-31-2006 06:41 PM
Integy Equalising Tray Paladin Australia For Sale/Trade 2 03-29-2006 07:31 AM
Rush Equalising tray FUK_WRX Electric On-Road 4 06-12-2005 01:21 AM
SEO by vBSEO 3.5.0
