Old 01-26-2005, 09:46 PM   #31
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I just built 4 packs of gp3300s this afternoon. Our cells come with a shrink over the label. If your cells dont I recommend doing so. I take my dremel on low and lightly scuff the ends. I lightly tin all my bars and cell ends. Then I slap them in my dean jig. Be sure to check that your polarity is correct and that you are building them the direction you need for the cars you run. I have a digital esd weller iron that get very hot with a medium size tip. I make sure to press down on the bars to squeeze any solder out and get a good joint. With the pack still in the jig I drop a bit of CA between the cells. For bars I prefer the gold orion bars.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 01-27-2005, 05:30 AM   #32
cr250 is offline   Reply With Quote
Old 01-27-2005, 06:09 AM   #33
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Originally posted by mafiaracers
Whats wrong with solder fumes? Breathe deep son....it puts hair on your (diff) balls.
Well as someone stated above. They said use the deans solder. Well deans has lead in it. So you dont want to inhale that or any other solder. But if it came down to inhaling solder. I would not want to get even the slightest wiff of the deans.
Lead can do some serious damage to your body. Stay away or wear a mask or ventilator or do it outside if possible, with a fan blowing things in the opposite direction.
Its not a joke, dont breathe anything like this. It wont put anything anywhere except for retardation into your brain.
Artificial-I is offline   Reply With Quote
Old 01-27-2005, 07:44 AM   #34
Thraex's Avatar
How to build A battery pack in 9 steps!
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Battery building Dragonfish Rookie Zone 6 07-26-2008 09:53 AM
battery building buffalobill989 Electric On-Road 9 04-25-2007 07:30 PM
Battery Building Nismospeed Electric On-Road 2 12-29-2001 07:03 PM
Battery Building Nismospeed Racing Forum 1 12-29-2001 05:30 PM
SEO by vBSEO 3.5.0
