Like Tree59Likes
Old 11-10-2004, 05:23 PM   #1471
RCGaryK's Avatar
that's a rubber setup Preston. That's what he was looking for...
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 11-10-2004, 05:49 PM   #1472
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Preston-Novak 2002, look at the dates lol
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 11-10-2004, 07:10 PM   #1473
lazyboy's Avatar
Send a message via AIM to lazyboy
so whats your point?
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 11-10-2004, 09:16 PM   #1474
Jeel's Avatar
Trader Rating: 16 (100%+)
I am looking for insight on the TC4 and how it compares to the HPI Pro4. I currently run a XXX-S in the stock class at my (very competitive) indoor carpet track and I am looking at either of these cars as a immediate replacement. I have enjoyes running my XXX-S and I am run well with it, but I am looking for a more aggressive car.
Thanks and BTW I understand that this is probably not the best place for unbiased answers. BUT, I know that there are some serious racers out there who may offer some insight based on their experiences.
Jeel is offline   Reply With Quote
Old 11-10-2004, 09:45 PM   #1475
RCGaryK's Avatar
Did you look at the setup I posted before you said you thought it was a foam setup? It says right on there he used Yokomo tires and inserts....it was a rubber setup man. The Novak Race was all rubber tire until 2003 0r 2004. sheesh
HorizonHobby.Com
Old 11-11-2004, 01:17 AM   #1476
Default Re: Re: Re: Re: Re: It`s done
Originally posted by JDM_DOHC_SiR
Looks sweeeet! Did you use the Associated Titanium Turnbuckles that comes with the TC3 and make them red, and use them with the RPM ball ends? Seems like this would be a good combo since the tc3 turnbuckles shorter than the tc4 ones, and the RPM ball cups are longer than the TC4 ballcups.
TC4 Rider is offline   Reply With Quote
Old 11-11-2004, 01:27 AM   #1477
Bob Nilsen's Avatar
For those having trouble with the links on CompetitionX... try this:
http://www.streamload.com/tphalen/Racing_Setups/
Bob Nilsen is offline   Reply With Quote
Old 11-11-2004, 07:55 AM   #1478
stormperson's Avatar
Send a message via AIM to stormperson
Jeel- You running at BBT or madness? If you run at madness I would say either stick with you losi and get set ups from dumas, or switch to an xray if you want to try out a new car, the AE is very good, but from I have been told there are a few pretty decently dialed xray's at that track, and Chris Marcy normally i think has every single part for that car in stock. TC4 parts he should have as well, but right now, they a little tough for everyone to get in large quantities. Chris also probably has some pro 4 parts since I know that at least one person runs one there and does quite well with it as well.
If you are running at BBT, Scott Futardo has a dialed XXX-S set up you shouldl get off him, his car is really good (Btw, if you want an agressive set up, scott is defently the man for that). For the TC4, eric has been working really hard to find a really fast set up, and from what he told me, his car is quite good, but parts again can be an issue for a little while. I dont think anyone really runs a pro 4 there who figured it out for that track (And BBT is funky set up wise in comparison to most other tracks). Also I dont think steve has any pro 4 parts.
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 11-11-2004, 08:21 AM   #1479
Jeel's Avatar
Hey Storm,
Thanks. I am running at BBT and ran my first race on Sunday. You'll love this one...Scott Furtado got rid of his XXX-S! I think I should probably go TC4, as you stated as I need to learn more about setup. I ran 3rd in the A with 25 laps, but I realized that my car is ready for retirement due to wear and tear. You run a TC4, correct?
Old 11-11-2004, 12:30 PM   #1480
Peter Busch's Avatar
R/C Tech Charter Subscriber
Peter Busch is offline   Reply With Quote
Old 11-11-2004, 12:38 PM   #1481
rcinsight's Avatar
Stogie:
What exactly did you do to the TC4 rack to tighten it up?
The shims went under the bearings and the knife was for what again?
I just want to get it even tighter knowing it will all loosen up as I drive it..
rcinsight is offline   Reply With Quote
Old 11-11-2004, 03:27 PM   #1482
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Originally posted by speedxl
trust brandon he knows his stuff!
whats up brandon! its hector!
Yo what's up Hector. I am coming down to FL next month for that race at Superior, see you there if you make it. I thought all my rubbers had been put away for the year .
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 11-11-2004, 03:34 PM   #1483
lastplace's Avatar
Send a message via Yahoo to lastplace
TC4 set up
I checked out the set up sheet from Comp X site... 6 Deg caster block? I've heard of 2 & 4 Deg Blocks, when did they start making 6 Deg blocks and why would you use them?
lastplace is offline   Reply With Quote
Old 11-11-2004, 03:37 PM   #1484
JDXray's Avatar
Send a message via AIM to JDXray
Originally posted by lastplace
TC4 set up
not sure if AE is same as Xray which it probably is since its just c-hubs, but 6* will make you go into the corners more agressive then 2 or 4 i think. Someone should double check me.
Jon
JDXray is offline   Reply With Quote
Old 11-11-2004, 03:45 PM   #1485
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
i think to get 6 deg you have to use the losi chubs
Javen13 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
scirocco14
