Old 11-07-2004, 09:34 PM   #1411
ghoppa's Avatar
Trader Rating: 48 (98%+)
Default Re: Re: front bumper..
Originally posted by Charlie O
Yes it's the nitro TC-3 bumper system, i just pulled mine straight off the gas car & stuck it on the TC-4. what you need is the RPM NTC-3 plastic bumper, NTC-3 rubber grommets, and the NTC-3 foam bumper, & if you want added security use the NTC-3 screws there slightly longer.
thanks Charlie,
I'll do that....(does the bumper clear fine under Mazda6 "skin"????(or does it need trimming?????
ghoppa is offline   Reply With Quote
Old 11-08-2004, 12:37 AM   #1412
Hey guys, I just got a TC4, and I'm have a question regarding steps 2, 4, 6, and 8 in Bag D - Suspension. It says to use the 4-40 x 3/8' screws which are part number 9292 in order to screw in all of the arm mounts and shims. However the there were 8 longer screws included in this bag. Not the shorter ones that are pictured in the manual. Did anyone else have this same issue or notice that the manual might be incorrect? I do not know the part number or lenght of the screws that were included in the bag...I just know that they are the same flat heads, but longer in length. Hope this all makes sense. Thanks for the help guys.
TC4 Rider is offline   Reply With Quote
Old 11-08-2004, 03:21 AM   #1413
I also had 8 longer screws in the bags but used them. I presume it may be a slight change to the kit which the manual has left behind.
They will keep the arms more secure anyway
Andy
Andy M is offline   Reply With Quote
Old 11-08-2004, 05:42 AM   #1414
myclod's Avatar
Send a message via AIM to myclod Send a message via Yahoo to myclod
the Nitro bumper setup fits nice and tight in the mazda and the alfa bodies, keeps front end from cracking
myclod is offline   Reply With Quote
Old 11-08-2004, 08:33 AM   #1415
ghoppa's Avatar
thanks Myclod....
(so no trimming right??)
Old 11-08-2004, 10:24 AM   #1416
myclod's Avatar
i didn't do any
Old 11-08-2004, 02:39 PM   #1417
Anyone know of a site that I can get a final gear chart ratio of the TC4?
JWATT is offline   Reply With Quote
Old 11-08-2004, 02:40 PM   #1418
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Gear chart.com
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64d
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-08-2004, 06:09 PM   #1419
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Just wanted to let everyone know that the TC4 option parts are starting to roll in. We already have some caster blocks and the rear toe-in blocks. We are expecting the graphite conversion kits by the end of this week.
Kraig
KT Hobbies
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-08-2004, 06:12 PM   #1420
Kraig
KT Hobbies
You got me right!
-Dave
Old 11-08-2004, 07:15 PM   #1421
Bob Nilsen's Avatar
Do I really have to buy an aluminum rear toe block in order to get down to 2 degrees of rear toe in? I dislike having to "upgrade" to a "team" part in order to try a different setting on the car.
Didn't someone here try to use on of the other arm mounts (square, triangle, or circle?) to get closer to 2 degrees rear toe? If so, can they share the details?
Bob Nilsen is offline   Reply With Quote
Old 11-08-2004, 07:21 PM   #1422
Trader Rating: 21 (100%+)
I swapped the the 2 arm blocks to reduce rear toe and it works great! You will have to dremel a little off the front diff case and/or front toe block to make it fit, but it is possible. I will be putting it back to stock and using the aluminum blocks this week when I get them.
Colin
Time Zone Raceways www.Timezonehobbies.com
www.ColinBranch.com
C Branch is offline   Reply With Quote
Old 11-08-2004, 07:58 PM   #1423
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
I used a front inner arm mount on the rear inner position and also left the 3 degree rear block on, this gives you near 0 degrees toe in. Thats how I run my TC3 as well.
Very free car, loose is fast
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 11-08-2004, 08:03 PM   #1424
Loose is right! The car rotates like none I have ever driven before. It works really well on a high grip track in stock class.
Colin
www.ColinBranch.com
Old 11-08-2004, 08:11 PM   #1425
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
No, it gives you near 2 degrees of toe in
Speedo is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
