Like Tree19Likes
Old 11-07-2004, 09:14 AM   #1396
lastplace's Avatar
Send a message via Yahoo to lastplace
Diff problems, check out RPhalen's reply (back a couple of post)
lastplace is offline   Reply With Quote
Old 11-07-2004, 09:28 AM   #1397
TPhalen's Avatar
R/C Tech Charter Subscriber
That would be "TPhalen".....
Sometimes my fingers don't cooperate, either....
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 11-07-2004, 09:37 AM   #1398
ghoppa's Avatar
Trader Rating: 50 (98%+)
Default front bumper..
what exactly was the front bumper mod????
I know it is posted way back in the thread, but what was it?
-was it to get the RPM NTC3 front bumper kit and it "bolts right on" (both pieces)
-or was it totally something different....
ghoppa is offline   Reply With Quote
Old 11-07-2004, 09:39 AM   #1399
ghoppa's Avatar
Default i noticed
Hey JDM_
I noticed you used the Bomber middle Shaft in your car, what drive cups are you using (and out drives as well) on you TC4???
your car looks great!!!!!
Old 11-07-2004, 10:07 AM   #1400
JimmyMac's Avatar
Very Nice Dave! Now quick... send me your car!! hehe.. Would go with my Orange and White paint scheme...
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 11-07-2004, 01:27 PM   #1401
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: i noticed
Originally posted by ghoppa
Hey JDM_
Team Bomber Drive cups front and rear..and the outdrives are IRS litedrives that have been.. let"s just say worked over
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-07-2004, 01:28 PM   #1402
Originally posted by tcmerf
Should have known you would beat me in coming up with something other than blue.
Sorry
-Dave
Old 11-07-2004, 01:50 PM   #1403
Registered User
tomlau's Avatar
JDM...sweet car!
Can anyone tell me if the turnbuckle lengths of TC4 are the same as the TC3?
Also i read somewhere back that the stock plastic outdrives werent up to modified racing? is this true?
thanks
tomlau is offline   Reply With Quote
Old 11-07-2004, 03:03 PM   #1404
Bob Nilsen's Avatar
Second week of racing my TC4... second broken rear bearing carrier... second week of no parts at my hobby shop
Bob Nilsen is offline   Reply With Quote
Old 11-07-2004, 03:37 PM   #1405
PIIHB!'s Avatar
Damn, you guys must be really beating on your cars cuz mine has yet to break and my driving is far from good.
~Team Wrecking Ball~
**Tamiya TA07 Pro**Gens ACE**Hobbywing**
PIIHB! is offline   Reply With Quote
Old 11-07-2004, 04:07 PM   #1406
I saw one in action last night at the Local Track and they guy had a huge Crash!!!! Cartwheels and about 3 feet of Air .. came of the run with only a bent rear body post and a broken wheel.. Man I thought that it was going to be one of those 30$ plus crashes But it held up pretty good... and that track has some "wonderful" wood boards that don"t give at all
-Dave
Old 11-07-2004, 04:29 PM   #1407
rcinsight's Avatar
Tomlau:
TC4 Turnbuckle lengths are withing a few mm's of the TC3 so you can use your FT TC3 turnbuckles.
I only had to correct the alignment a couple of degrees everywhere for camber and toe.
Take the time to reposition all of them to adjust the same way one way so you won't have to guess at each one.
Has anyone found a solution to eliminating all the slop out of the steering?
I still have almost 2 degrees of toe play after tightening everything again. TC3 rack was a lot less sloppy.
Weighed in under 1490g race ready.
rcinsight is offline   Reply With Quote
Old 11-07-2004, 04:41 PM   #1408
I was able to get rid of some of the Play in the Rack it self.. by using some Metric shims from Yokomo.. I belive that they were .3mm and I used them between the upper plate and lower arms but I have yet to get rid of a small amount in the A-arms... but it seems normal .. not to much of a issue yet..... because I will e running the car for the 1st time in about 6 hours...so I"m sure it will get loose a bit.. but I"ll just re-shim
-Dave
Old 11-07-2004, 07:00 PM   #1409
JimmyMac's Avatar
Yes, I believe I used some Alex Racing shims in my steering setup. Before I noticed some play.. so I just tossed on some shims. There's still alittle slop. But I believe most of it now is in the ball cups.
The suspension has some slop as well. But I think the optional aluminium suspension blocks should take care of that.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Old 11-07-2004, 07:12 PM   #1410
Charlie O's Avatar
Default Re: front bumper..
Yes it's the nitro TC-3 bumper system, i just pulled mine straight off the gas car & stuck it on the TC-4. what you need is the RPM NTC-3 plastic bumper, NTC-3 rubber grommets, and the NTC-3 foam bumper, & if you want added security use the NTC-3 screws there slightly longer.
Charlie O is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
