Like Tree18Likes
Old 11-05-2004, 10:54 AM   #1321
Charlie O's Avatar
Default Diff spring.
[QUOTE]Originally posted by dr_hfuhuhurr
[B]That is absolutely the problem with the diffs. Our local shop called AE and they sent him the replacement gears. Went in the shop the other day and I had gears waiting on me. There is a difference in the gears for sure. Enough to see with the naked eye.
Has anyone else had a problem with the diff spring being bent slightly? that was my problem with the diffs, not the thickness of the gear, a few others i have talked to at SoCal had the same problem.
Charlie O is offline   Reply With Quote
Old 11-05-2004, 10:58 AM   #1322
Bob Nilsen's Avatar
Andy M - I had the same problem with my TC4 steering rack, and I chose to countersink the hole in the chassis that allows for servo-saver adjustment.
Bob Nilsen is offline   Reply With Quote
Old 11-05-2004, 12:14 PM   #1323
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Charlie - yes the springs in my kit were bent, one of them to the point that it would not fit in the outdrive.
The diff gears also appear to be too wide.
Andy M - I had the same problem, but I am hesitant to put any shims under the rack because I don't want to mess with the steering geometry without knowing what I'm doing. I guess I'll just have to run the servo saver tight and hope that my servo survives.
Does anyone else get the feeling that this kit might have been a little rushed? I know it sounds strange coming from AE, but the quality control just doesn't seem to be there.
Josh
Speedo is offline   Reply With Quote
Old 11-05-2004, 12:19 PM   #1324
raving-monkey's Avatar
Send a message via MSN to raving-monkey
weni had the tc3 (i know it aint a tc4 but ahhj well) i just took the spring out of the steering rack and tightened it down and then fitted a proper servo saver to the servo its self...i know a lot of others did this to but its better than the built in ones
raving-monkey is offline   Reply With Quote
Old 11-05-2004, 12:26 PM   #1325
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
IMHO...I think people have been spoiled by the quality of the XRay kits. The bar has been raised.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 11-05-2004, 12:34 PM   #1326
Registered User
tomlau's Avatar
will a TC3 center shaft fit the TC4?
thanks
tomlau is offline   Reply With Quote
Old 11-05-2004, 12:40 PM   #1327
Moderator
Speedo's Avatar
The main driveshaft? Yes. The front and rear input shafts are the same also, as far as I know.
I've never had an Xray, so I can't compare.
Josh
Old 11-05-2004, 12:41 PM   #1328
Go to AE's site and see if the part numbers are different.
JWATT is offline   Reply With Quote
Old 11-05-2004, 12:43 PM   #1329
koabich's Avatar
Send a message via Yahoo to koabich
thanks
The drive shafts are the same length, but I think the pins are different sizes, so a TC3 shaft might not fit correctly in the TC4 drive cups.
koabich is offline   Reply With Quote
Old 11-05-2004, 12:44 PM   #1330
Moderator
Speedo's Avatar
The driveshaft on the TC4 is different than the TC3, so the part numbers will be different. The TC3 shaft should still fit, unless the ends are too large to fit into the new beefier drive cups.
Josh
Old 11-05-2004, 01:46 PM   #1331
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Josh
TC3~TC4 same drive shaft lenght.. but in order to use the TC3 shaft you need to use the input cups from the TC3 also.. the TC4 ones will not work
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-05-2004, 01:53 PM   #1332
Default problem with steering
I have just about finished building my TC4 with only a few minor problems. 1 bent hinge pin and 1 screw with a messed up head.
By the way thanks for all of the tips, especially the NTC3 front bumper mod.
My question is, does anybody notice that the front knuckles seem a little bit tight in the c-hubs compared to the tc3. Seems to be binding very slightly. Will this loosen up over time? I will be using a fet servo so steering shouldn't be a problem, but just thought I would ask.
Do some people shave the top and bottom of the knuckle were the screw and ballstud go in?
Thanks in advance.
Can't wait to finish car so i can drive it. Just have to be careful as spare arms are not in my hobby store yet.
rcdave905 is offline   Reply With Quote
Old 11-05-2004, 01:57 PM   #1333
Anyone heard a delivery date for the Factory Team Kit?
Old 11-05-2004, 02:07 PM   #1334
myclod's Avatar
Send a message via AIM to myclod Send a message via Yahoo to myclod
yeah...what JDM said....also the imput shafts are the same, i like the IRS aluminum shafts for the TC3 and they slid right into the 4
myclod is offline   Reply With Quote
Old 11-05-2004, 02:07 PM   #1335
Neil's Avatar
Send a message via MSN to Neil
Don't worry about things being tight after a couple runs everything loosens up. Mine was relatively tight, but after bumping the pipes a couple times my suspension arms are very sloppy. I need to get some caster blocks so I can get my setup closer. My car would oversteer on power when I would exit the corners any tips?
Neil is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
