Like Tree36Likes
Old 12-30-2014, 03:37 PM   #13291
PIIHB!'s Avatar
What steering rack is that on yodogs chassis??
PIIHB! is offline   Reply With Quote
Old 12-30-2014, 04:19 PM   #13292
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Originally Posted by RotorTruck View Post
Hi Terrance, thanks for sharing the setup! If you don't mind me asking, what's the idea behind running 0* castor up front, I never heard of that before. Is the car stable and doesn't wander on the straights? Is there enough camber gain thru the turn?
Also, all the hing pin spacers, is that to raise the inner end of the lower a-arms so they'll be parallel to the ground due to the low ride height? I've always questioned running any angle on lower a-arms. In my autocrossing experience, my truck (yep truck) always handled better when the lower a-arms were parallel to the ground, even better than if the truck was lowered more because that caused the a-arms to angle up.
I would guess that after adding all the hing pin spacers, the upper inner links needed to be lowered to make the upper links parallel to the ground (or parallel to the lower links). ?
Thanks again, congrats on the TQ and win! The setup is obviously working :-)
Thanks for the congrats! :-)
"0" caster is stock caster block for a TC4. As I understand it the caster is in how the Circle and triangle mounts are shimmed to each other. Get this right before you start adding caster with the 2 or 4 degree caster blocks. <<< Again how I understand TC4 setup.
The spacers are same amounts given in the TC4 Club manual.
The main reason for shorter ballstuds is >> the manual has two spacers per ballstud and the TC4 was UN-driveable, after removing those, it was almost SWEEEEET!! TC4 had NO twitch on the straights with the shorter ballstuds.
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 12-30-2014, 05:16 PM   #13293
Looking good YoDog.
I have my Diggity setup with Shorty. Best balance is pack all forward with ESC mounted behind it. With my 200g pack it puts me ~6g heavy on LiPo side, front to rear balance is about 10g heavy in front with steel diff and full size servo.
GimpyGolden is offline   Reply With Quote
Old 12-30-2014, 07:29 PM   #13294
YoDog's Avatar
Trader Rating: 26 (100%+)
It's the stock TC4 dual crank steering rack. The latest pics show the FT aluminum version for NutDriver (RCTech member). This is his chassis.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-30-2014, 07:39 PM   #13295
YoDog's Avatar
Originally Posted by GimpyGolden View Post
Looking good YoDog.
The latest chassis update will have a 15mm range of adjust-ability for both full size and shorty packs in both front and rear mounting configs.
Old 12-30-2014, 09:01 PM   #13296
So I was digging through boxes today and found a brand new TC4. I built it tossed it in a box and never touched it again. What in the world should i do with it? Drift car? Just asking because 887 pages is alot of pages to read through lol
OKCIS is offline   Reply With Quote
Old 12-31-2014, 06:33 AM   #13297
Super Moderator
tmail55's Avatar
Which TC4 >> tub or FT?
Tube try VTA
FT try TC
IF I remember right the FT info starts around page 318, don't know where the "Club" info starts.
Old 12-31-2014, 09:28 AM   #13298
Its a tub I wouldn't be against swapping it over to a flat CF chassis if they aren't overpriced but from reading it seems like alot of parts are basically impossible to find.
Old 12-31-2014, 06:53 PM   #13299
gooba's Avatar
hopefully yo dogs kit will be affordable but I run my tub tc4 in 17.5 class very competitively. Im right at minimum weight with my car and don't want to add a bunch of ballast just to make weight. Now somebody figure out how to retrofit xray's active rear suspenson to my car and id be all over it
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 12-31-2014, 08:43 PM   #13300
Super Moderator
tmail55's Avatar
That's why I'm racing a tub, hopefully YoDog chassis won't cost a arm and a leg!!!
Old 12-31-2014, 08:54 PM   #13301
NutDriver's Avatar
Trader Rating: 15 (100%+)
@gooba, you haven't seen Jeff Jenkins' 3D-printed rear arms?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 01-01-2015, 03:24 PM   #13302
gooba's Avatar
NO!? but now I must find them. got a link?
Old 01-01-2015, 04:45 PM   #13303
Right here Goob's
Team Associated TC4
Wondering if Jeff will give us an update on the outcome after some running, Jeff?
Old 01-01-2015, 05:14 PM   #13304
Robert421's Avatar
Right here Goob's
Team Associated TC4
I may be looking at the picture wrong, but is the motor mounted in the front on the chassis in your link? I see the spur and the steering rack as well as the motor mount.
Associated TC4 stock
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Robert421 is offline   Reply With Quote
Old 01-01-2015, 05:17 PM   #13305
Trader Rating: 35 (100%+)
Josh Keller is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
