Like Tree26Likes
Old 12-15-2014, 01:18 PM   #13216
scirocco14's Avatar
Originally Posted by RotorTruck View Post
It is a VTA car with the HPI vintage d-compound rubber tires, yes. I can try to tip the front shocks in. I am running the black sway bar front and rear and really like how it calmed the car down. I think I'll keep those.. couldn't imagine running a thicker bar in the rear. Thanks! Tuning adjustments are free!
Anyone who has run a front ball diff.... what suspension changes are needed ?
I run a front ball diff on my USVTA car. I've found that a light sway bar is OK to help reduce body roll, but thicker bars will increase the inside front wheelspin under power because larger sway bars will lift the inside wheel as the car rolls.
Heavier springs than the stock blue ones also help keep the body lean to a minimum and keep the inside front wheel planted.
Lower roll centers help keep the inside front wheel planted as well.
Increase the front droop to keep from picking up the inside front wheel off the track as the body rolls.
You'll still get beaten off the corners by the cars with gear diffs and spools, but the ball diff can carry more speed into the corners and turns better in the center of the corner. It's a trade-off.
Good luck!!
Mark
Mark C. USVTA #115 TC4 & Xray T4 '13, USGT #115 TC5
USVTA-F1 #115 F103.5 & F1R3 & F1R
Tamiya M05 M06
Bush River RC, The RUG at King, Ho B Max Raceway, Easley RC
scirocco14 is offline   Reply With Quote
Old 12-15-2014, 04:14 PM   #13217
Smile
Stiffer rear springs also helps with front tire lift... Ball diff with ofna diff lock lube(#10230) stays tight enough to pull the car well on corner exit...
bertrandsv87 is offline   Reply With Quote
Old 12-15-2014, 08:12 PM   #13218
Trader Rating: 35 (100%+)
@gooba: thx for the feedback--seems like finer adjustments can be made with the 64p...luckily there's an actual hobby shop on the island where I can get some quickly.
Stanford55 is offline   Reply With Quote
Old 12-17-2014, 01:39 PM   #13219
RotorTruck's Avatar
Good luck!!
Mark
Thanks Mark. Say.. how tight do you tighten that front ball diff? Couldn't that help a lot with inside wheel wheelspin?
RotorTruck is offline   Reply With Quote
Old 12-17-2014, 01:51 PM   #13220
scirocco14's Avatar
I set the ball diff according to the Team Associated TC4 instructions. Just barely tighten the thrust bearing bolt to where the diff doesn't slip. Usually a 1/4 turn CCW from where the bolt feels "tight".
IMHO, as a mechanical engineer, I believe that "tightening" a ball diff past the point where it stops slipping does not increase its limited slip capabilities, it simply destroys the diff balls, the diff rings, the thrust washers and balls.
Mark
Tamiya M05 M06
Old 12-18-2014, 05:26 AM   #13221
Originally Posted by YoDog View Post
Hey TC4 guys...
Soon to be released is a TC4 Carbon conversion that will accommodate TC4 Club racer, TC4 FT and Diggity designs DC4 parts.
The conversion will include a 2.5mm carbon chassis plate, a 2.0 or 2.5mm carbon top deck, a floating servo mount, battery stays and all required hardware to update your TC4 to the next evolution in performance.
Remove all the drive train and suspension from your Tub Chassis TC4 and bolt directly to this new kit. You can choose to use the front and rear side braces or remove them for a more flexible setup.
More details to come soon.
Any thoughts/possibility on a thinner chassis or adjustable battery mount system for shorty packs? (something adjustable front to back similar to ExoTech on their other chassis's)
Robbob is offline   Reply With Quote
Old 12-18-2014, 11:20 AM   #13222
YoDog's Avatar
Trader Rating: 26 (100%+)
Adding more mounting points for the battery stays are easy for accommodating shorty packs. figuring out balance is another subject. As it is, the prototype is nearly perfectly balanced with the gear I have installed. Now...
A thinner chassis could be possible however, it's likely most will prefer a 2.25-2.5mm chassis plate with a 2.0mm top plate. We want to introduce some flex characteristics but too much flex will be influenced by drivetrain forces. This will make the car unpredictable. When I tested last on carpet, the car was quite stable and has tons of steering. This is with a 2.5mm chassis and top deck. I believe changing just the top deck to 2mm will yield the additional flex some setups will prefer. There are also anchor point options that can greatly influence flex as well.
Another possibility would be a 2mm Aluminum chassis as an option.
Thanks for the input.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-18-2014, 12:16 PM   #13223
I run a shorty Orca pack in my Diggity up against the stock front mounting holes and my Tekin RS behind it and I can tell you its too light left rear.
2.25 was more of what I was curious about but you got good point with the drivetrain.
You run any shims under your lower arms or just dropped on the chassis?
Old 12-18-2014, 12:53 PM   #13224
gooba's Avatar
I run a front ball diff if in my tc4 and built it per the manual then loosen it just slightly so the car rotates a little better in the front. However I do not get beat out of the corners by any belt drive car. I've had to have my car teched after a race(even one I didn't win) because I could out accelerate everyone
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 12-18-2014, 01:40 PM   #13225
scirocco14's Avatar
Care to share your setup? I'm still fighting inside front wheelspin out of slow corners.
Mark
Tamiya M05 M06
Old 12-18-2014, 02:46 PM   #13226
RotorTruck's Avatar
SWEET! How steerable is it thru a slow, tight 180* hairpin. I've had minimal steering thru those. I just loosened the rear ball diff 1/8 of a turn and will see if it turns better on Sunday's race (with the front a spool)... and if it pulls more to the left. At least now the rear tires turn in opposite directions when in the air and slowly turning one tire by hand. Before that 1/8 turn out both rear tires would rotate in same direction, and it would spin the driveshaft too.
Old 12-19-2014, 03:30 PM   #13227
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Should have some interesting DC4 pic's to post up later tonight
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-20-2014, 09:57 AM   #13228
gooba's Avatar
For 17.5 I run medium swaybars on both ends, lightweight diffs with ceramic balls in both ends, red front springs gold rears, x 2.0 rear toe block, and every carbon piece I could find. I run both diffs per the manual with the front slightly tighter. I've really focused on tuning with roll centers and squat and anti squat which has really helped me get my car to rotate. we only have one tight 180 corner on my local track which has kind of a funny line thru it to set up for the next corner but I seem to be able to hold closer to the inside than the guys running spools. I did have a problem with 3 wheeling visiting a different track and running mod a few weeks ago. I was lifting the inside front coming onto the straightaway but it didn't affect the handling any and wasn't prematurely wearing out that tire so I jsut tightened that diff a tad a drove it like a dirt car
Old 12-20-2014, 10:17 AM   #13229
scirocco14's Avatar
Thanks, Gooba!
What roll center heights are you running? I'm running -4mm on the front, and -3.5mm on the rear (USVTA tires).
Mark
Tamiya M05 M06
Old 12-20-2014, 10:32 AM   #13230
hairy's Avatar
Can anyone tell me what the numbers represent on the shaft of the turnbuckle eyelet that fits on the shock?
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
