Like Tree26Likes
Old 11-16-2014, 08:38 PM   #13141
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Almost finished building up the DC4LE... should have some picks up in the next day or two...
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-17-2014, 05:10 PM   #13142
RotorTruck's Avatar
Default 3/32" Ceramic Diff Balls, are they worth it?
3/32" Ceramic Diff Balls, are they worth it? Why? Eighteen bucks.
http://www.teamassociated.com/parts/details/6584/
RotorTruck is offline   Reply With Quote
Old 11-18-2014, 05:05 AM   #13143
I just rebuilt a diff in my diggity with ceramic diff and tungsten thrust - smooth as glass. My opinion ... worth the coin.
Think I paid about 13$ through TQ Racing for another brand.
Robbob is offline   Reply With Quote
Old 11-18-2014, 06:08 AM   #13144
gooba's Avatar
+1 on ceramics diff balls smoothest diffs you can build.
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 11-20-2014, 08:55 PM   #13145
I just bought a Factory Team TC4 with the full carbon fiber chassis and I need some help figuring out how to mount a 2s standard hard case lipo. I keep searching and coming up with nothing. I have seen a few pictures of people using straps with brackets, but I can't seem to find anything when I search around to try and buy the brackets. The car didn't even come with the stock strap so right now I have nothing. Any help would be greatly appreciated.
killeraxemannic is offline   Reply With Quote
Old 11-20-2014, 09:08 PM   #13146
Robert421's Avatar
Originally Posted by IndyRC_Racer View Post
Just make sure the setup station has holes that are big enough to accept an 8/32" axle (on the part that holds the car off the ground). Some setup stations have smaller holes/are made to work with the metric axles on most of the cars out there.
I have found that out the hard way, I guess I was looking for the manufacture who made a setup station that worked with the 8/32 axles. I bought an Integy setup station and was trying to get a tool maker to mill some 8/32 adaptors for me, but he is dragging his feet.
Does anyone know of a tool maker who would do this? Thanks for the help
Associated TC4 stock
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Robert421 is offline   Reply With Quote
Old 11-21-2014, 12:45 PM   #13147
gooba's Avatar
@killeraxe a popular choice is to use strapping tape. But if you want the strap you can download the fttc4 manual from associated and it will give you all the part numbers you need
Old 11-21-2014, 12:48 PM   #13148
gooba's Avatar
@robert421. Do you have a pic of how the setup station attaches to the car?
Old 11-21-2014, 01:05 PM   #13149
Robert421's Avatar
I could get a picture of it, may take a day or two to do it.
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Old 11-21-2014, 02:47 PM   #13150
NutDriver's Avatar
Trader Rating: 14 (100%+)
You will have to slightly enlarge the axle holes in new wheels to enlarge them from 4mm to 8/32, too.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is online now   Reply With Quote
Old 11-21-2014, 10:20 PM   #13151
I know how to find the stock battery strap, but that is for NiMh packs and not lipos. I have seen some people who have aftermarket brackets that they are using to hold the lipos in place. That is what I am looking for. I will look in to the strapping tape. That may be the cheapest option.
Old 11-21-2014, 10:51 PM   #13152
beemerfan's Avatar
Trader Rating: 34 (100%+)
Would this work?
http://www.diggitydesigns.com/Associ...race_Wide.html
USVTA Member #155
Associated TC3 Faithful
beemerfan is offline   Reply With Quote
Old 11-21-2014, 11:26 PM   #13153
turtlehill's Avatar
Default Knurled nuts
I found 8-32 pitch knurled nuts on Amazon.com. They work with my setup station. The 8-32 axles are snug, but they fit. Check out the pic below.
http://www.rctech.net/forum/members/...urled-nuts.png
Team Associated TC 6.1 VTA, TC 6.2 TOURING, TC4 VTA
Tekin RS Gen2 Spec
APEX RC supporter
turtlehill is offline   Reply With Quote
Old 11-22-2014, 05:40 AM   #13154
gooba's Avatar
@killeraxe the factory team carbon fiber strap is flat and works fine with lipos. Also you can flip the stock strap upside down and use it that way
Old 11-22-2014, 06:28 AM   #13155
IndyRC_Racer's Avatar
The FT TC4 Battery Strap #31126 (http://www.teamassociated.com/parts/details/31126/) will work with lipo batteries.
I own a FT TC4 and have used several different lipo batteries with that battery strap. An additional option would be to use the FT TC4 battery strap above and instead of using body clips to hold it on, use FT Battery strap thumb screws #1787.
Personally I feel the legs on the FT TC4 battery strap are a bit short. What I have done in the past is use longer hex head screws to hold the battery down. You could use a longer 4/40 threaded rod and the thumb screws.
Another thing about the FT TC4 battery strap is that the lipo battery isn't a secure side to side as I would like. My solution was to use velcro on the top of the battery/bottom of the strap to keep it more secure. You could also use double-sided tap if you only use one battery in your car (which is what I did when running VTA).
It may be hard to find the FT TC4 battery strap at this point. I believe that the TC5 battery strap parts would also work on a FT TC4 but may require some minor modifications.
If you do use strapping tape to hold the battery down, be advised that it will pull off any decals on the batteries (unless you use something to protect them - such as plastic shrink wrap for battery packs).
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
