Like Tree26Likes
Old 11-03-2014, 06:44 AM   #13126
does it matter if i have the green or orange timing sensor in the ballistic boss VTA? I see the exploded view novak has online is orange w/ no fish paper, mine came with green w/ fish paper.
InceptorOne is offline   Reply With Quote
Old 11-03-2014, 09:06 AM   #13127
IndyRC_Racer's Avatar
I don't think it matters. I have swapped parts around in a few ballistics when I was being cheap and just bought a different turn stator. The color in the timing part of the motor seemed to match the same color as the stator. For example the Novak 17.5 motor I bought had yellow inside the timing end to match the yellow of the stator. I turned that motor into a 25.5 Ballistic and didn't have any issues.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 11-03-2014, 11:18 PM   #13128
Default Just got my TC4 team kit!
Just got this discontinued baby won off an Ebay auction. Never been used for $130 shipped which I think was an awesome deal. Plan on building a 100+ mph basher!
tc4basher is offline   Reply With Quote
Old 11-09-2014, 10:11 PM   #13129
Default Update on my TC4
Whats up RCTECH! Here is an update on my TC4 speed car/basher.
Current setup:
Castle 5700kv 4 pole motor
Mamba Max Pro
Robinson racing 38t pinion/ 55T spur
Zippy 4s 3000mah 20c-30c / Turnigy Nanotech 3s 4000mah 40-80c
Top speed so far is 105 mph on BSR F3040 foams. I'm waiting on some bigger pinion gears and a better 4s lipo. Ill update my future progress.
Team Associated TC4-105-front.jpg   Team Associated TC4-105-rear.jpg   Team Associated TC4-105-gps.jpg
Old 11-09-2014, 11:10 PM   #13130
RotorTruck's Avatar
How do you setup the front of a TC4 club to gain negative camber as the suspension compresses?
RotorTruck is offline   Reply With Quote
Old 11-10-2014, 06:24 AM   #13131
I think pretty much all setups will do that. If you're looking for a larger amount run a shorter front camber link.
anr211 is offline   Reply With Quote
Old 11-10-2014, 10:48 AM   #13132
I'm thinking about buying a freinds tc3 was just wondering what the differences are.
race maniac is offline   Reply With Quote
Old 11-11-2014, 12:21 PM   #13133
turtlehill's Avatar
What size shims do I need to remove the slop from the stub axles? Will 5mm work?
Team Associated TC 6.1 VTA, TC 6.2 TOURING, TC4 VTA
Tekin RS Gen2 Spec
APEX RC supporter
turtlehill is offline   Reply With Quote
Old 11-11-2014, 05:04 PM   #13134
gooba's Avatar
How much slop do u have? A little won't hurt anything in fact you want a SMALL amount. Shimming it out can cause drivetrain bind
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 11-11-2014, 07:29 PM   #13135
If you want to use shims on the axles, Team Associated makes some shims specifically for that purpose. Here is a link on their website (http://www.teamassociated.com/parts/details/7368/)
You can also use the transmission shims - (http://www.teamassociated.com/parts/details/3911/)
Basically any shim that has a 3/16" (or larger) inner diameter should work.
Old 11-16-2014, 01:33 PM   #13136
gooba's Avatar
Got to do some mod racing yesterday with my tc4 finished 5th in the A. Was really hard to put the power down out of the slower corners. I ended up taking my 6.5 out and dropping in my 10.5 which helped but just couldn't put a good run together when it counted
Old 11-16-2014, 03:16 PM   #13137
Robert421's Avatar
What setup station can be used with the TC4?
Associated TC4 stock
FT TC4
SC10 4X4
VTA FTTC5
SC10 2wd
Robert421 is offline   Reply With Quote
Old 11-16-2014, 08:23 PM   #13138
Just make sure the setup station has holes that are big enough to accept an 8/32" axle (on the part that holds the car off the ground). Some setup stations have smaller holes/are made to work with the metric axles on most of the cars out there.
Old 11-16-2014, 08:28 PM   #13139
This thread has seemed slow lately and I just realized that Bert hasn't posted recently. Did a quick search on his recent posts and it turns out his account was been suspended for a month (starting 11/03/14).
Old 11-16-2014, 08:31 PM   #13140
jeff jenkins's Avatar
Trader Rating: 75 (100%+)
You can use any setup station. But you will have to ream out the holes for the axles to fit. No big deal.
RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
