Like Tree26Likes
Old 10-30-2014, 09:49 AM   #13111
Talking
Well 69/34 is at the limit of the tc4 motor cam... It might fit tightly, and burn energy.... It's best to get the 60t spur, remember the two most important tc4 gearing numbers: 89 and 103...Your total tooth count in 48p ,pinion plus spur, should always be between 89 and 103... Any higher or lower is not physically possible....
Ps: The Novak Vulcan 17.5 recommended gearing start is 3.5fdr, and that's probably for belt cars. Other racers have reported good results at 3.33fdr with their tc4's... It's novak or nothing!!! The 13.5 suggested gearing start is 4.5fdr, probably for beltdrives, so 4.2fdr for the tc4 sounds just right...
bertrandsv87 is offline   Reply With Quote
Old 10-30-2014, 10:01 AM   #13112
Conrad's Avatar
Originally Posted by JDM_DOHC_SiR View Post
The LOSA3333 will not work you will need the LOSA3344.. and they are very very... very...... hard to find.... you can find parst to build a set but even most of the stores that had spare parts to build the LCD's are out of stock... eBay has a few dog bones and axles now and then... but the LCD rebuild kit or center section is the one that will be a pain the butt to locate
Here are the part#'s if you want to build a set..
LOSA 3335 LCD rebuild kit
LOSA 3345 Axle
LOSA 3346 Dog bone
You mean like these I'm open to offers for anyone that needs them, built but other wise new and unused.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 10-30-2014, 10:07 AM   #13113
Smile
Conrad , you'll need about forty of those to satisfy the immediate demand....lol....
Old 10-30-2014, 11:29 AM   #13114
Smile
Another important part of the tc4 weight loss process is the selection of lightweight tires, even if they are spec tires... Tire Manufacturers sometimes make mistakes and put the wrong inserts in their spec tires, which can result in a significant weight difference, on top of the fact that each tire will still weigh slightly more or less than the next... Most of my sweep tires weigh from 27grams to 35grams each, and the lightest tires from Sorex can go under 23grams... That's a possible 12gram difference per tire or 48gram difference for a set of four...wow..... Imagine the rotational mass difference... Four Sweep Exp40 tires(136grams), Sorex 28 revlite wheels,blue inserts(94 grams)...
Make sure you weigh all your tires after taking them out of the bag, and group them accordingly... I suspect some racers might be keeping all the lightest spec tires for themselves.....lol......
I wonder why they did not make carbon rims or graphene(10gram per tire) for electric tc tires yet: tires would weigh less than 20grams each then...lol....
Old 10-31-2014, 01:02 PM   #13115
DesertRat's Avatar
Awesome find Conrad. Hang on to them unless you get a really good offer.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 10-31-2014, 05:07 PM   #13116
Conrad's Avatar
I bought them a few years ago, they have just been sitting in the box since. There was one chap on here after them but I haven't heard anything from him in ages. If anyone wants them then pm me, I'm open to offers.
Old 11-01-2014, 05:52 AM   #13117
PM sent
C.Harper is offline   Reply With Quote
Old 11-02-2014, 11:01 AM   #13118
Smile
Ok... Anybody here using the trinity motolyser in addition to a mms&rms???? It might explain the difference between average tc4 racers and the "fast guys"....
Old 11-02-2014, 11:31 AM   #13119
I have a brand new Novak VTA Ballistic 25.5 brushless motor installed with the Edge 2S ESC on a TC4. It doesnt have a pinion yet since the one I ordered with it was 64p by accident... Will have a proper one soon to set the mesh. However, with lightly feathering the throttle to test it with no load (yes I know it's not recommended but not going full at all), it's not a clean whining noise that you might hear, bit of a vibrating noise I wasn't expecting from a brushless. Should I see how it is with the proper mesh and a couple runs? Almost sounds like the bearing. New to onroad and VTA, just curious. I've been to the local indoor track using other VTA's and the motors seem very silent.
InceptorOne is offline   Reply With Quote
Old 11-02-2014, 11:36 AM   #13120
25.5 motors are very quiet indeed....Nothing wrong there...
Old 11-02-2014, 11:43 AM   #13121
That's the thing, it's not quiet, sounds like an iphone vibrating on a table, that normal until it has a pinion?
Old 11-02-2014, 01:01 PM   #13122
Talking
The only time that happens is when the sensor board is about to fail..... I would try a different sensor board, even if the current board is new...
Old 11-02-2014, 01:26 PM   #13123
funked1's Avatar
I have had a couple of these motors and they both sounded weird to me when revved unloaded. They are low rpm motors, and I think that must be why they sound odd to me. Both of my motors ran just fine - I've of the fastest cars on the straightaway in my class so far.
The Edge has a sensor test mode you can do if you aren't sure. And you can always lube the bearings lightly. But I think it will run fine.
Streetjam SJF01 / M05 Ver.II R / Spec-R S1 VTA / Speedworld Raceway
funked1 is offline   Reply With Quote
Old 11-02-2014, 01:59 PM   #13124
The test mode looks like it checks out... Shouldn't be anything to worry about then?
Old 11-02-2014, 02:23 PM   #13125
Smile
My problem is , I've only heard novak motors run... I'm not familiar with the other brands at all... The Novaks are really on the slow side, and need to be geared much higher than other motors... Novak recommends 3.5fdr start gearing for their 17.5t Vulcan motors, but on the tc4 I would start at 3.35fdr... As far as the 25.5t motor, I would start at 3.05fdr , but with a very free&light drivetrain and strong fan...
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
