Team Associated TC4
#1291
anyone know how those new ft shocks are they look really nice
#1292
LoSixx-S...
didn't you sell your TC4? Just wondering what difference it makes to you.
Diskostew it feel lazy because it's so sloppy. Sloppy arms, sloppy hubs, sloppy, sloppy , sloppy. I did notice the new aluminum blocks help tighen the arms up some.
#1293
First upgrades
What upgrades would you guys recommend getting rightaway before building the car? I'm looking for the most economically efficient parts that will make a difference on the car.
#1294
i think the car is pretty set out of the box you may want the graphite parts or those nice aluminum hinge pin blocks but i think the car is nice as is
#1295
I recommend...
the carbon kit, lighten screw set and change to the NTC3 bumper. Otherwise get some tires and tunning parts.
#1296
yeah definitly get the rpm bumper it REALLY helps
#1297
#1298
Re: I recommend...
#1300
TPhalen- You have PM.
#1301
Lightened steel diff question
Hey guys,
What parts do you need to change the plastic diff to a steel one?
I know you need the regular rings no d-rings, but will the bearings work? and what kind off diff nut do you need? the plastic one that has a locknut in it or do the new steel outdrives have a place for the regular lock nut to fit into?
Tyler
Tyler
#1302
The aluminum IRS diffs use the D rings and lighter then steel
#1303
Re: First upgrades
#1305
Super Moderator
For those of you waiting for the swaybar kits just take a long rpm ball cup and attach it to the swaybar end. Then you can feed a screw through the bottom of the arm into the cup. It works but not like the original parts.
Kraig
KT Hobbies
Kraig
KT Hobbies
