Like Tree33Likes
Old 10-12-2014, 10:05 AM   #13006
theproffesor's Avatar
Trader Rating: 55 (100%+)
Need to see ot mounted rtr in the car. If these fit, its temping to take a goodblooknat this kit with the bitty designs graphite conversion.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-12-2014, 10:58 AM   #13007
NutDriver's Avatar
Trader Rating: 15 (100%+)
Bitty designs? If you mean Diggity Designs, I have one you can put your hands on.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 10-12-2014, 11:33 AM   #13008
jeff jenkins's Avatar
Trader Rating: 75 (100%+)
Originally Posted by JDM_DOHC_SiR View Post
Hey guys... look what fit's
there only needs to be a little bit of material removed from the gear diff housing on 4 ribs ( about 2mm worth and does not even come close to effecting the strength of the diff case)
The only other tow issues we might run into is the out drive lengths and proper machining of the input shaft for the bevel gear.. but that is nothing that a lathe can't fix .. other than that your looking at a 2.47 final drive ratio vice the 2.5 and your adding about 10~15Grams per diff
I am assuming those are the b44.3 diffs. all that is needed are proper input shafts. cool lucky for me I have access to all the equipment needed to make those. just need to get my hands on some diffs. if anyone is interested I'm sure we could work something out on some input shafts.
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 10-12-2014, 11:51 AM   #13009
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Yes they are B44.3 diffs.. it would be nice to get a set of input shafts that are made out of Ti or a hardened Alloy that might hold up with metal gears.. that might have some sore of weight savings to offset the weight of the added weight from the gear diff
But anything that would help get a set of input shafts made I in for
I will also post up a few pic's of the area's that need to me ground off to make it spin freely in the TC3/4 case
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 10-12-2014, 03:38 PM   #13010
gooba's Avatar
@ford02 parts are fairly easy to get as far as stock parts(arms,shock towers etc,) and any standard tires and bodies will fit. Tower,amain,and tq rc always have parts in stock. My LHS is really good about getting parts too. Upgrade parts are fairly easy to get as long as you don't want all the factory team parts as they are starting to get scarce
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 10-16-2014, 10:12 AM   #13011
Smile
I just finished painting my blitz gsf body, and it weighs 60grams versus the lightweight Protoform Mazda Speed6 that weighs 91grams... Also I could lower the blitz gsf body down two more holes on the body posts without issues... The CG of my tc4.1 got lowered significantly, and the gsf has been making a name for itself around the world....Peace.....
bertrandsv87 is offline   Reply With Quote
Old 10-16-2014, 11:16 AM   #13012
NutDriver's Avatar
What am I thankful for today? The ignore function.
USVTA member #111
Old 10-16-2014, 11:34 AM   #13013
Good for you bert!! Now does anybody who is fast and actually knows what there talking about wanna share some stuff that makes people want to visit this thread?? Lets get these gear diffs working . Anybody need some input shafts?
Old 10-16-2014, 12:55 PM   #13014
Working the input shaft situation right now for the gear diffs and going to do away with the E-clip and put a screw in it's place that should hold the smak gear in place just fine... just have to wait for the machine shop to get me the parts back.. should be about 1~2 weeks..
Old 10-16-2014, 01:23 PM   #13015
Cool
I write here for the real tc4 enthousiasts, not the haters !!! I am sure some secrets will come out in the process, that's life... At least the newbies will have an idea how to make the tc4 TQ and win, thanks to BERT....
Feel free to use your ignore rights; you have nothing to add anyway !!!
Old 10-16-2014, 02:04 PM   #13016
I used a screw on the geardiff i made a few years ago. Im not a fan of the screw as it has a chance to come out and ruin the geardiff. But it worked.
Old 10-18-2014, 03:15 PM   #13017
Tc4 in the IIC Amain.... I guess someone did listen to BERT after all...lol... Let's hope he wins guys.... Show your support...
Old 10-19-2014, 06:15 PM   #13018
Had a great day today at the track . Took my diggity designs dc4 le for a practice day and dusted off the cob webs. Pulled the fastest laps of the day. I modded the chassis a few nights ago by narrowing it by 18mm and drilling and slotting it for use of shorty packs. All i can say is i was impressed with how well this car drove in 17.5 . Going to work on a a.r.s system for the rear and get the gear diffs in to get some more corner speed but going to actually put some effort into this car now. Here are some pics of what it looks like with my modded dc4 chassis.
Team Associated TC4-20141018_000510.jpg   Team Associated TC4-20141018_000550.jpg
Old 10-19-2014, 06:31 PM   #13019
NutDriver's Avatar
Awesome! You might want to post this to the Diggity Designs thread as well. I have a DC4LE I run in USGT.
USVTA member #111
Old 10-19-2014, 09:11 PM   #13020
Nice job with the narrowing of the chassis.. and I like the idea of that shorty as well
What did you use to cut the carbon fiber down... and what did you use to countersink the holes you drilled
Might have to do this to my DC4 Chassis
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
