Like Tree33Likes
Old 09-26-2014, 12:07 PM   #12946
racer x 1's Avatar
Trader Rating: 27 (100%+)
Has anyone tried to fit tc6 suspension arms and all to the car?
Matt Bell
Mugen MRX5 • Ae R5.2 • X6^3 • M11x • All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 09-26-2014, 02:36 PM   #12947
gooba's Avatar
I don't know that it would work because the tc6 is metric and the tc4 is standard and I believe the geometries are different as far as angles and mounting points
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 09-26-2014, 02:58 PM   #12948
racer x 1's Avatar
I thought about that. The 6.1 arms and such are pretty good as far options. And i know ae is standard to metric stuff isnt to far off. Nothing a 3mm drill bit couldnt fix if the lengths are right was my thought
Matt Bell
Old 09-26-2014, 03:00 PM   #12949
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Wink
If anything... I would think the HPI Pro4/Cyclone arms would be the closest ... since the Pro4/Cyclone used the same length CVD's as the TC3/4 ... I might have a set that I could take a pic' of so you have a point of reference....
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 09-27-2014, 02:30 PM   #12950
Smile
Post your tc4/tc6 setups....The tc4 is so versatile, wow.....
bertrandsv87 is offline   Reply With Quote
Old 09-27-2014, 09:02 PM   #12951
gooba's Avatar
Ok I guess I have to ask what's the point of changing the arms out? You wouldn't be able to use the tc6.2 sway bar or the independent arm mounts. And I don't believe there's a geometry difference so it seems pointless
Old 09-29-2014, 05:49 PM   #12952
Smile
I just finished upgrading the tc4 tub car with all the possible lightweight stuff, and it weighed in at 1374 grams: that's with a novak impact esc, protek low profile servo(55g), spektrum receiver, aluminum screw kit, R1 wurks fan, gforce supercap(18g), thunderpower 2700mah(168g) lipo pack.... I might switch to the TP 3300mah(208g) just to make weight though...
Old 09-29-2014, 06:29 PM   #12953
i wish team associated would revise the tc4...make it more brushless & lipo friendly & make some gear diffs for it & maybe re-do the bulk heads
DESOTO RACING,,SERPENT S411 3.0 USGT,,S411 3.0 17.5,,MOTIV,,FRP PAINT WORKS
starrx is offline   Reply With Quote
Old 09-30-2014, 12:10 PM   #12954
gooba's Avatar
They did its called a tc6. The tc4 evolved into the 5 then the 6 and now the 6.2. No it isnt shaft drive or a tub chassis or 150 bucks but it is designed to race the premier pro class which is still mod tc. And sadly as power increased the torque steer and twist of the tc4 made mod racing very difficult. Tc is not a big seller for AE so making a new cutting edge car like the a700 or evo6 isn't going to happen we're probably lucky AE still makes a competition tc as losi and hpi gave them up years ago.
Old 09-30-2014, 12:46 PM   #12955
Smile
The tc4 was the evolution of the tc3 . The tc5 was was not an evolution of the tc4, but rather AE's entrance in the belt car market, which was a good business move... Not improving the tc4 was not a good business move though..... Even tamiya is paying special attention to their shaft cars now!!! AE should do the same !!! They left all the work for Diggity Design and BERT !!! That's not cool at all ...lol....
Old 10-01-2014, 09:39 AM   #12956
DesertRat's Avatar
I ran into an interesting issue with my car while running on high grip. The car seems to want to run a fairly soft front and rear spring combo, I had 17.5lb springs, 37.5wt oil with a Losi #56 piston mounted on the inner hole on the suspension arm on the front, and a 15lb spring, 35 wt oil with a Losi #56 piston mounted on the inner hole on the arm in the rear. Typically the car runs pretty well with this combo, but the grip at TQRC over the weekend was immense, and the car would bottom out in the corner and go loose. Running the hardest swaybars I own for the car helped quite a bit, but the car still seemed to wander… I also managed to traction-roll the car a few times. What do you think would help on that grip level? Harder spring/softer swaybar? And NO, I will not be unscrewing the droop screw all the way out so the car grip-rolls in every corner so don’t even mention it.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 10-01-2014, 11:32 AM   #12957
Smile
I would suggest you go with thicker oil(50wt to 60wt) in all your shocks to slow the transition speed enough so you will not bottom out in the time it takes to complete a turn... Other than that, I would make sure the track width is at 190mm all around, lower the body as much as possible, and I would spray clean the bottom of the chassis before every run... Low Cg in a tc4 makes a huge difference...
Also make sure all your wires are tied down, and try to use four scales to tweak the car( after tweaking the anti roll bar)....
Old 10-01-2014, 01:18 PM   #12958
gooba's Avatar
I will partially agree with Bert. I would try thicker oil and maybe some preload on the spring or harder springs if stiff sway bars helped stiffer or slower suspension may help
Old 10-01-2014, 01:18 PM   #12959
MOmo's Avatar
For folks still running the TC4 and who are competitive, Are you still using the TUB chassis or have you switched to the Diggity chassis? AE Chassis?
What all conversions our there that are still available are worth exploring?
-Diggity
-AE
-ExoTeck
-Penguin
-Etc?
I'm seriously looking hard at that option and would really like to make a competitive race car from my TC4. I just hate to pour a bunch of $$ into it.
(But since I have spares between it and my TC3, I might as well)
-I happen to have the ASC 1way Part #: 1728, will this give me any advantage in VTA?
-Are people favoring a Spool in the F or R or utilizing diffs?
-presume the AE FT Shocks from my TC3 would be the best option?
-Are there different arm versions like there were for the TC3. V2 vs V1 or are the V2 the new standard?
-is anyone running a Shorty? is a Std length pack best?
-For those with competitive TC4s, is there a list of "Must Haves" or "Mods" that will make this car MORE competitive.
I really am excited to get my car running again. I've tried looking now and then for a used Diggity roller, but they seem few and far between. Has anyone run the Diggity vs the AE version side by side? are there any advantages either way?
MOmo
RACE CARS: B44.1, RC8.2E FT, SC10.2 4X4, B5M, YZ-2
RADIO: Futaba 4PKS/3PKS. BATTERY: Venom
ESC: SpeedPassion. MOTORS: SpeedPassion / Venom
"Im not a racer, but I play one on the Internet"
MOmo is offline   Reply With Quote
Old 10-01-2014, 01:26 PM   #12960
fathead's Avatar
I made my own thicker swaybar when I found the standard ones weren't thick enough, just need to bend up some piano wire of the appropriate thickness, lots of hobby shops carry it.
Slavich Design
fathead is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
