Like Tree33Likes
Old 09-02-2014, 01:51 PM   #12901
boudin4evr's Avatar
Trader Rating: 18 (100%+)
question
Im looking for dual cvd's for my TC4 for more steering throw(angle) Old losi i think 3344 dc'd
does the cvd's for TC6.1 fit the tc4?
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 09-02-2014, 02:00 PM   #12902
boudin4evr's Avatar
I'll try again
Im putting my Factory team tc4 back in service for onroad parking lot modified racing
currently I have a 8.5 motor in it and have down to a 5.5 and upwards to a 13.5
do you guys that have experience with this car, take out the center spline or put the X shaped one in it?
how are yall setting up diffs front and rear?
any pave or cement parking lot setups?
tires? i know fall is upon us soon so I'll have to keep that in mind!
Marc Richard
Old 09-02-2014, 02:38 PM   #12903
NutDriver's Avatar
Trader Rating: 15 (100%+)
The TC6.1 axles are metric, so you'd have to change the steering hub or bearings. With the inserts used on the TC6.1 front uprights, it might not be as difficult as some other projects. If you know someone with a TC6.1 or TC6.2, you could get them to pull the outer hinge pin and test fit it. I don't know about the length of the shaft when compared to the TC4.
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 09-02-2014, 03:01 PM   #12904
boudin4evr's Avatar
I do not know anybody with a tc6
looking for losa3344 cvd's replacements!
Marc Richard
Old 09-02-2014, 03:13 PM   #12905
DesertRat's Avatar
I own a TC4 and a TC6, I'll take a look when I get home.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 09-02-2014, 03:42 PM   #12906
gooba's Avatar
Very interested as well because the losi parts are about non existent now
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 09-02-2014, 07:09 PM   #12907
DesertRat's Avatar
Upon checking on my two cars, the TC5/6 caster block pin is considerably larger than the TC4, meaning that in order to fit the TC6 caster block into the TC4 arm the arm would need to be drilled out. As far as I can see, the TC6 steering block will fit in the TC4 caster block, but that would probably require drilling out the caster block to fit the 3mm size hardware that threads into the steering block. This also has the problem of the arm on the TC6 steering block being MUCH longer than the TC4 arm, changing your steering throw needs considerably. You can remedy this by drilling your own holes or not running that much steering throw, but neither is optimal.
I think if there is a metric car you would steal hardware from to run on a TC4 to get Cardan Joints, you could pull it off with a TC6, but it wont be as easy as you think. Fastest way is probably to just put the TC6 steering block in the TC4 caster block, fit the hardware, and live with the change in steering geometry.
Old 09-03-2014, 06:08 AM   #12908
boudin4evr's Avatar
yes, I have been searching high and low for the losi cvd's
Marc Richard
Old 09-03-2014, 04:51 PM   #12909
gooba's Avatar
@ boudin i switched over to a ball diff in the front in both my cars. They don't have quite the pull out of the corners but they are easier on parts and can be found easily. I personally have begun to really prefer them I can hold tighter lines and don't have any noticeable chatter. They just require a little extra maintenance
Old 09-04-2014, 12:37 AM   #12910
Thumbs up
Yeah, you and every other TC4 owner...I think you are only about a year late
THEBIGBULL is offline   Reply With Quote
Old 09-04-2014, 06:23 AM   #12911
Conrad's Avatar
I have a set, built but otherwise new and unused. Postage would be from the UK but I am open to offers on them (PM ME) as they are just sitting in my TC4 spares box doing nothing just now.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 09-04-2014, 04:06 PM   #12912
DesertRat's Avatar
I can't honestly say that I have ever run a car with a ball diff in the front that was faster for it when racing rubber tire. Also, the front end is still chattering, you just can't hear it.
Team AE consistently lets us down when it comes to universal joints.
Old 09-04-2014, 09:36 PM   #12913
RotorTruck's Avatar
Looking for a setup for tc4 club tub racing vta 21.5 motor rubber tire on a medium size high grip recently resealed asphalt track outdoors. I have the stock spool up front.
Video of track
http://m.youtube.com/watch?v=fiTuVijplq4
RotorTruck is offline   Reply With Quote
Old 09-05-2014, 06:54 AM   #12914
gooba's Avatar
@desert rat. I've always liked having a diff in the front. I've always raced on small tight tracks and I've felt I can dive in to a corner harder and hold a tighter line with the ball diff I may lack a little acceleration coming out of the corner but it's never hampered me. As far as chatter I know they do just not nearly as bad as with a spool.
Old 09-05-2014, 10:21 AM   #12915
IndyRC_Racer's Avatar
I also race on a small indoor track and I would echo what gooba has said. The only challenge is setting up the car to not slip the front diff/inside tire coming out of corners. What little bit I may lose coming out of corners I'm usually able to make up going into the corners, so I don't feel it hurts my lap times.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
