Like Tree19Likes
Old 08-08-2014, 10:29 AM   #12841
boudin4evr's Avatar
Trader Rating: 18 (100%+)
what offsets for 190mm bodies? 3mm or 6mm?
im sure 9mm is prob for 200mm wide fender drift or GT type bodies?
I have no local hobby shop!
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 08-08-2014, 01:21 PM   #12842
beemerfan's Avatar
Trader Rating: 34 (100%+)
No offset (0) is required for 190mm bodies.
beemerfan is offline   Reply With Quote
Old 08-08-2014, 01:54 PM   #12843
mugler's Avatar
TC4 fans have a look here.
SoCal Mini-Z Thread
FIRST SUNDAY OF THE MONTH MINI-Z TRACK DAY AT
BALDWIN PARK, CA.
NEXT >> MAY 7TH, 2017.
mugler is offline   Reply With Quote
Old 08-08-2014, 04:34 PM   #12844
Does someone know a way to tighten up the steering? Mine seems to have some flex between servo and where the part mounts to the rack is actually fastened.
Solo1 is offline   Reply With Quote
Old 08-08-2014, 04:42 PM   #12845
NutDriver's Avatar
Trader Rating: 14 (100%+)
TC4 is (allegedly) 190mm stock. 3mm offset wheels will get you close to 200mm wide. 6mm offset wheels might be just over 200mm. I think I'd buy a pair of 3mm offset and see how they fit with the body, then decide.
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 08-09-2014, 07:56 AM   #12846
gooba's Avatar
@boudin for HPI 200 mm bodies you want 3mm off set in the front and 6mm in the rear. Some of the wider bodies(mustangs,gtrs,vta bodies,etc) can run 6mm in front and 9mm out back.if you run 9mm though and race your car will push like a bulldozer
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 08-09-2014, 11:17 PM   #12847
HornyToad's Avatar
Trader Rating: 26 (100%+)
Just finished reading the whole thread
Too late to write something intelligent...
Will srart bugging you guys tomorrow
Good Times Racing
Sponsors: Visa, AmEx, My Wife, My Children's College Fund...
In God we trust.... All others must bring data.
HornyToad is offline   Reply With Quote
Old 08-10-2014, 10:59 AM   #12848
HornyToad's Avatar
What I did was put a plastic bag ( the one the replacement bearings came in) between the bearing and the arm and pushed the beAring in. That took some of the play betweenthe bearing and the mount.
I'm not that good @ explaining things, but as soon as I get my car back will take pics...
Good Times Racing
Old 08-10-2014, 11:13 AM   #12849
HornyToad's Avatar
What I don't understand is why some people use big pinions (36T plus)
Isn't it better to use the smallest pinion/spur you can get away with?
Maybe I'm missing something....
Btw, we run a spec class: tub chassis, hpi saturn 20t motors, 1,420 grams, radial tires, production car bodies...
Good Times Racing
Old 08-10-2014, 11:17 AM   #12850
longuylander's Avatar
The smaller the spur and the larger the pinion, the more top speed the car will have, though it will lose acceleration. Depending on the motor, the track, and the heat (the motor will overheat if the car is geared for too much speed), different gear ratios are used. For people running 17.5 motors, their low rpms need to be geared for speed. Thus, people going to 60t spurs and 36+t pinions.
longuylander is offline   Reply With Quote
Old 08-10-2014, 02:58 PM   #12851
NutDriver's Avatar
You can run a 4:1 ratio with a 15/60, 18/72, 25/100, etc. If you're running brushless, the gearing parameters are different as they make more torque, but don't turn as many RPM when compared to a brushed motor. For VTA (25.5 motor), a good place to start is with a 4.0 final drive, which would mean a 1.6 spur/pinion combo. With a 60 tooth spur, that means a pinion of 37 or 38. For USGT (21.5) or 17.5 TC, you would want a numerically higher (but what people refer to as a "lower") ratio.
USVTA member #111
Old 08-10-2014, 06:55 PM   #12852
HornyToad's Avatar
Thanxs for the info guys... But what I really dont understand is why so many people use such big pinions when you can get the same ratio with a smaller pinion and a smaller spur? For example, instead of using 66/25 wich gives 2.64 I've seen pics and read of people using somerhing like 98/37 wich gives 2.648. ( numbers are used for reference only)
I left the hobby mid 90's as the first brushless motors were being used by the pros in speed runs on ovals. Came back in 2012 and I've tried brushless, but am sticking to this 20t class because is what I know. Have a bd5 for running mod collecting dust.
But we are changing to brushless next year, that's why im curious....
Good Times Racing
Old 08-10-2014, 07:20 PM   #12853
beemerfan's Avatar
Running the largest combination possible will give you the best gear mesh and the smallest adjustment increments going up or down a tooth on the pinion. However, larger gears also mean more rotating mass and you may run into physical limits on how much you can adjust the motor. Also, on shaft drive cars like the TC4 you can use the motor to balance your car side to side by using different size gears combos. If you are trying to balance out a heavy battery, then the largest combo you can fit would help.
Old 08-11-2014, 02:34 AM   #12854
I think what you're missing is the pitch of the gears. The TC4 came with a 48 pitch spur gear (pitch measures the angle of the side of the tooth). Because of the lower angle, the teeth are further spread apart. That means fewer teeth along the circumference of the gear. They tend to be stronger, but louder, and don't allow for as fine adjustment. There are also 64p gears. Since the angle of the teeth is steeper, more teeth fit on the same diameter gear compared to a 48p. So given to two examples you gave, the gears themselves are actually close to the same size, but the 64p gears (98/37) allow for more fine adjustment of the final drive ratio.
Old 08-11-2014, 01:15 PM   #12855
HornyToad's Avatar
Thx!
Good Times Racing
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
