Like Tree19Likes
Old 07-26-2014, 12:47 PM   #12826
The ball diff tighten is pretty good when the bolt is gooped up with blue loctite, and ceramic diff balls........
Originally Posted by gooba View Post
I was hoping for the gear diffs for their tunibilty. I've been trying to get my car to rotate tight corners quicker and a gear diff would help there.
bertrandsv87 is offline   Reply With Quote
Old 07-30-2014, 06:21 AM   #12827
longuylander's Avatar
Hi all, new to the forums. Running two TC4 club racers; one a speed runner with almost all graphite and aluminum parts, steel outdrives for the rear diff (the plastic ones melted), and a Castle 5700kv on 3S. The other much more driveable with a 9.5t. Great cheap fun for such a great chassis!
longuylander is offline   Reply With Quote
Old 07-30-2014, 10:15 PM   #12828
Can someone tell me what body mts i need to get so i dont have to put the rear 1's thru the back window of a parma cuda body
Solo1 is offline   Reply With Quote
Old 07-31-2014, 04:05 PM   #12829
gooba's Avatar
How far do u need them to be moved? Could you use a spacer and longer screw? Otherwise you may just have to live with the posts thru the window
I spend money I don't have on parts I don't need to beat people I don't know
gooba is offline   Reply With Quote
Old 08-06-2014, 05:54 AM   #12830
jkach's Avatar
I ran my tc4 last weekend what a blast, I think I'm going to like this VTA class. Are most of you running sway bars? If so which color, and are you running both front and rear.....parking lot racing, the track is sprayed with soda. Thanks in advance.
SC10.2
jkach is offline   Reply With Quote
Old 08-06-2014, 10:07 AM   #12831
DarthRacer's Avatar
I run the softest/thinnest bar F/R from the TC4 swaybar kit. Will need two kits to do this.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 08-06-2014, 10:16 AM   #12832
NutDriver's Avatar
Trader Rating: 14 (100%+)
If you go to the Team Associated site, they have numerous setups for the TC4 listed there. I am running VTA indoor and on carpet. I run the black swaybar in the front and the silver in the back.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 08-06-2014, 11:06 AM   #12833
boudin4evr's Avatar
Trader Rating: 18 (100%+)
anybody has a setup for the factory team dual deck carbon fiber car for outdoor parking lot racing
untreated cement and sometimes asphalt?
tires? diffs? gearing (13.5) etc...
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 08-06-2014, 02:50 PM   #12834
jkach's Avatar
Thanks guy's yes iI understand that 2 kits r needed, and yes I've seen the setup sheets. Will be ordering a few kits this week. Thanks again
SC10.2
Old 08-07-2014, 11:11 AM   #12835
boudin4evr's Avatar
what are the basic rules for diffs in TC4
drifting front one way and rear tight?
racing parking lot rubber tires diffs F & R?
Marc Richard
Old 08-07-2014, 02:02 PM   #12836
NutDriver's Avatar
Most folks run the TC4 in VTA or USGT. In those cases, most seem to run a diff in the back and a spool in the front.
USVTA member #111
Old 08-07-2014, 02:33 PM   #12837
IndyRC_Racer's Avatar
I run my TC4 in VTA with plastic ball diffs front/rear. However, I run as little rear toe as possible. This suits my late braking & turn-in driving style on a track with a lot of tight 180 turns.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 08-08-2014, 09:29 AM   #12838
boudin4evr's Avatar
new to drifting with one of my TC4's (tub car)
what bodies fit better, 190mm or 200mm?
or is it the width?
Marc Richard
Old 08-08-2014, 09:29 AM   #12839
boudin4evr's Avatar
double post somehow, sorry.
Marc Richard
Old 08-08-2014, 09:55 AM   #12840
DesertRat's Avatar
When a body is noted as a '200mm body' or a '190mm body' that is the width. 200mm cars are typically nitro touring, but I think VTA may use 200mm bodies as the VTA spec wheels have a large offset, especially the rear tires.
If you want to use a typical size wheel/tire combo, I would get the 190mm body.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
